Question about Acer Aspire 5610 Notebook
Aborted power up
My notebook will start to power up, the fan will run for a second or two and then it turns off. Pulled HD, tried on AC, DC...same results. Got any ideas?
Novice Acer Owner
    Genius:
  • 3,587 Answers
Sure...you are suffering from Motherboard fatigue. or you may have memory seating porly..open up the cover of the memory, extract it, then re install..
might be that simple..
Posted on Mar 30, 2008
MY ELONEX PRESENTIA IS FAILING TO START NO FAN ,FRONT SWITCH NOT STARTING COMPUTER....
check ac- dc power adapter is powered on and plugged into laptop
or
computer locked up - hold in power button for 30 seconds then try again to turn on.
Jan 06, 2017 | Computers & Internet
Why won't my computer boot up?
does not sound easy . Try holding power button in for 30 seconds and then try normal power up. Is the AC adapter plugged into laptop it may have a flat battery. If the Ac to DC adapter is failing to charge the battery this could cause a flat laptop battery and cause the symptoms you are experiencing.
Sep 17, 2015 | ASUS X200 Black 11.6" Notebook 1.5 GHz...
Toshiba A205-S5809 Wont power on
Try another cord/charger with the EXACT same power specs. If you have a multimeter, verify DC voltage at the AC jack plug. If the AC jack, in the laptop, has been pulled, damaged, it's may have a loose connection. You didn' say if ANY LED's, battery charge, work? If the battery is charged and it doesn't start on battery only, then you have other issues. It may need a ride to a Qualified Computer Tech.
Jan 08, 2013 | Toshiba Satellite A205-S5809 Notebook
My Toshiba Satellite M65-S809 Laptop will not turn on! However it turns on randomly sometimes when i toy around with it, but that happens rarely. I tried removing battery, and cable to take out the static,...
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Thank you for using Fixya...
Sep 18, 2011 | Toshiba Satellite M65-S809 Notebook
IBM X236 server will not power on, the AC light on the back of the server is Dim, the DC light most of the time is off though now and again it will go on and then off 2 or 3 times a second apart from each...
We just ran into this same problem with our x236 this past weekend. After some research we replaced the power cage, but same problem. It appears to be a problem with the PSUs. We moved one of the PSUs to another x236 that only had one PSU in it. Both AC and DC lights lit up, but when we pulled the first PSU, the suspect one could not keep the server running. After opening up both PSUs, I believe it is a problem with the 3 - 1800uf/16v capacitors. I have replacement caps on order, and will know for sure after they are replaced.
Oct 26, 2010 | IBM X236 Server
Boot problem
When you first press the power button do the fans start running. If not, then it could be that the fans aren't working properly and as a safety feature the computer shuts-off to keep from over heating. Also, try turning on the laptop without the battery in but with it plugged into the AC Adapter. If it doesn't even attempt to turn on when you press the power button, then the problem could be that either your AC adapter or your DC Jack on the motherboard have gone bad. Which results in your battery not charging up, so when you try to turn on your laptop the battery has only enough "juice" to make an attempt at booting up, and then shuts off from lack of power. Please leave feedback and a rating vote on the info I've supplied you with.
Jun 24, 2010 | Acer Aspire 4720 Notebook
My Toshiba Satellite AS205-5000, will not turn on nor does the fan come on. When the low battery sign came on, I plugged in the AC adapter to charge it, and it shut down and wasn't charging. After it shut...
You Need To Replace the DC Jack..this involves desoldering the old/faulty dc jack from the motherboard, then cleaning the board, then soldering a new dc jack in place of the old...
But First, Test Your AC Adapter - use a multimeter (available at any home improvement store for under $7)...
Nov 14, 2009 | Toshiba Satellite A60 Notebook
Toshiba Satellite A75-S209 (PSA70U-09700E) PC Notebook will not start.power lights come on for both the battery and DC. There is no fan or hard drive sound.power button does not light up. pushing the...
Take out the battery and try booting the machine on AC power only. If the machine boots up then let the operating system load up, the shut it down. Remove the AC jack and put the battery back in again, then power it up.
If it boots all is well if it doesn't then there could be a problem with the battery.
If the laptop won't start on AC power, what you could do is remove the system memory, clean the brass pins and the slots and then re-seat them/it.
Then try to turn the machine on.
Good luck.
Nov 13, 2009 | Toshiba Satellite A75-S209 Notebook
Laptop power shuts down after 2 seconds
hold F2 key and set up to default settings choose to boot to the hard drive save it and exit.
if that does not work then hold F8 chose to log in safe mode and from there try to find what issue is causing that particular problem...
otherwise try to download the ultimate boot cd (click here) and burn it into a bootable cd inserted on your pc and repair whatever is causing your nightmare.
Jan 09, 2009 | Computers & Internet
Laptop shuts off, and wont turn back on.
when power off, push compressed air through vent.
If you can reach fan and remove dirt,
Insist on compressed air to clean every vent.
Install temp monitor to check if CPU is getting hot.
Dec 17, 2008 | HP Compaq nc8000 Notebook
Acer Aspire 5610 Notebook Logo
37 people viewed this question
Brian Sullivan
Brian Sullivan
Mohammed Ebrahim M
Mohammed Ebrahim M
