Question about Fujitsu ScanSnap Manager
My Fujitsu scansnap s1500 just started to streak in colors (yellow and green). How can I fix it? Or where can I take it to be fixed?
2 Suggested Answers
SOURCE: My Fujitsu scansnap s1500 just started to streak
Wipe the glass strips inside with a scratch free cloth (both pieces).
Posted on Jun 09, 2010
Drivers for s1500 not installed
http://www.fujitsu.com/global/support/computing/peripheral/scanners/software/s1500.html
Go here for the drivers, depending on your OS, select the proper install. make sure to check to see if you will need to also install the update found in the Update tab (windows 7 + usually)
Oct 21, 2013 | Fujitsu ScanSnap Manager
NEED SCANSNAP 1500 DISK NEW SCANNER DISK IS LOST
don't know if you ever got this resolved but....
check under the operating system tab to select the right installer for you.
Mar 23, 2013 | Fujitsu ScanSnap Manager
Scansnap hardware error 0x00048004
I had this exact same problem. Turned out that I was using the wrong power adapter. Enough power to turn on the scanner lights and connect to the computer, but not enough to actually perform a scan. As soon as I realized I was using the wrong power cord, I switched it up and voila!
Jan 23, 2013 | Fujitsu ScanSnap Manager
Fujitsu s1500 can not get setup disc to work
Try setting up the scanner manually, click on start then control panel open scanner and cameras, in the upper left side click on add an imaging device, installation wizard will come up, click next then click on have a disk, browse setup disc and locate the driver of the scanner.
Jul 13, 2012 | Fujitsu ScanSnap S1500 Deluxe Bundle...
Scansnap s1500 wia driver
scansnam s1500 wia drivers for windows xp, 7, 8 (32/64bit) can be found at driverupdate us
I hope I have helped you...
Take a look, and enjoy
Jun 19, 2012 | Fujitsu Office Equipment & Supplies
My scanner keeps flashing and not pulling the paper through, I cannot seem to figure out why it will not scan. It does this quite often, what is the problem that is causing this? Scansnap S1500
Go to msconfig or if you have a registry cleaner, go to the startup menu. Disable and ssmgr (scansnap manager in pfu). Reboot. Open the ScanSnap 1500 and then start the ScanSnap manager. The scanner is now ready to scan.
Jan 26, 2011 | Fujitsu ScanSnap Manager
I need a driver for my Fujitsu ScanSnap S1500. I don't have the disk any longer. Anyone got any suggestions? Thanks!
You will probably have to call Fujitsu to advise them of your problem and get the Adobe Acrobat 9 license once again as well as the driver you require. You cannot move this scanner from one computer to another without first deleting it from the first computer. Fujitsu is very helpful and will give you great advice.(I kept forgetting to delete the program before moving it to another machine and they were very helpful when I called to ask what to do.)
Jan 11, 2011 | Fujitsu ScanSnap S1500 Instant PDF...
PFUSSMON HAS STOPPED WORKING ON MY SCANSNAP S1500
Find your specific scansnap product and update it:
http://www.fujitsu.com/us/services/computing/peripherals/scanners/support/downloads.html
A user had a similar issue and I found this update for the scansnap S1500 manager:
http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/s1500.html
This occurs with certain Intel dual core processors, so you might be effected accordingly.
--Rob
Jul 08, 2009 | Fujitsu ScanSnap Manager
Fujitsu ScanSnap S300 PfussMon has stopped working
--Rob
Apr 09, 2008 | Office Equipment & Supplies
Computers & Internet Logo
199 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
