Question about Samsung DVD-R155
HCT HDVR960S now only shows black and white panels on TV
I turned on our new HCT HDVR 960S yesterday and it will not show any DVD's nor the video stored on its hard drive. We can still hear the audio.
All cables checked out perfect. All jacks on the new TV were also perfect when checked with other DVD players we have here. \
The left side of the screen is simply black and the right is white. No picture comes through at all. Any ideas to fix? Ken in ChiTown
You need to click menu scroll over to the right and select rest to factory settings.
Turn the machine on.
With the remote
1). Click Settings
2). With the right arrow (blue directionals) click 5 times slowly. Slowly so you do not go too quickly.
3). Click Enter
4). With the down arrow (blue directionals) click 2 times.
5). Click Enter.
This hopefully Resets your machine back to Factory settings.
Worked for me.
Posted on Oct 04, 2008
RETURN IT
Posted on Sep 12, 2008
Sgtken,
I also purchased the same unit. Please let me know if you figure out how to get the unit back to factory settings. I checked over the unit and do not see a reset button. Thanks!
Bill
[email protected]
Posted on Aug 10, 2008
SOURCE:
Panasonic DMR-HS2. Why doesn't DVD tray open or close and why is there no audio/video output?
Tray movement failure can result from a weakness in electrical or mechanical components.
"hooked up both RCA audio/video outputs to my HDTV". Often the RCA outputs are coded R (right audio), W (left audio), and Y (video). If these are not connected to corresponding inputs on the rear of the TV, you will not hear/see much.
Do I need to use a(n) RF modulator to connect to my HDTV to see video? No
Mar 04, 2016 | Televison & Video
Dvd playing hooked up to an old t.v. plays in color when i hook it up to my lg tv it plays in black and white?
My DVD player only plays in black and white - TOSHIBA FORUMS
forums.toshiba.com/.../My-DVD-player...plays-in-black-and-white/.../47...
39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
No Color When My DVD Player Is Hooked Up - Community ...
community.insigniaproducts.com/...DVD-Players/...Color...My-DVD-Pla...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
The picture from a disc player displays on the TV in black ...
Jan 17, 2016 | LG Televison & Video
I hooked up my DVD player to my hct tv. I am getting video but I am not getting any audio. I hooked them up the way it's color coded. Yellow for video red and white for audio still no sound help!
make sure you plugged them into AV as component in looks similar but is a different . Did you change the input source on tv to av 1 or av2 . make sure you did not plug into AV out it should be on AV in on the TV.
Apr 26, 2015 | Televison & Video
Black screen
you have an issue with video card or the screen is bad !!! a professional technician only can tell you what it is after diagnostic
Mar 11, 2012 | Sony VGN-FS620W: VGN-FS620P/W Pentium M...
The New TV.don't come on, keep showing no signal, don't know what is wrong, can you help us, to get it going. thank you
The TV is turned on. The TV showing "no signal" is an indication that is turned on. Its just that the TV is not recieving any signal whatsoever from an antenna, DVD player or dish.
I suggest you connect thee TV to a DVD player. Click source on the TV remote to AV 1. Use a RCA (yellow white and red wire) for the connection.
Yellow stands for video and white and red stands for audio. Connect yellow to "vidoe out' from the DVD player to 'video in' at the back of the TV. Do the same for the audio white and red.
Now there should be a display on the TV. If there is not display, check your connection.
Let me know if need more help.
Your sincerely.
Elect_Comp.
May 13, 2011 | Televison & Video
Anything I hookup to the componets ( DVD or SAT) shows in black and white only. I try a different three way cable too still in black and white.
Ensure the TV is set up the same as the components and noy one with Component Video and the other Composite Video.
Apr 17, 2011 | Televison & Video
My stero is not loud enough.
Check for the tape monitor being on or amp mute type function. Larry's Electronics
Apr 27, 2010 | Audio Players & Recorders
TIVO output is black and white only.
To solve this problem, I powercycled my TIVO.
Sep 17, 2009 | Humax DRT800 TiVo 80-Hours Video Recorder
Show movies in black and white no color
unit is in a progresive mode. need to turn back to interlaced.
Jun 01, 2009 | Sony DVP-NS575P DVD Player
My plasma, lcd tv only shows in black and white
Would you say say the color is intermittent, sometimes black and white an occasionally flashes streaks of color? The small signal board may be at fault. You can ask to have the board replaced or fix it at the component level. Parts for the board at component level could be PN#823827736071 location 1H00, this is i beleive a color crystal, and two capacitors , PN#223886975478, location #s are 2H08 and 2H09. This repair is very prettymuch the repair you will need. Theses are surface mount parts and will require a tech to do. Hope this will give you a good start for repair!!!!!
Apr 10, 2009 | Philips Magnavox 42MF521D/37 Television
Samsung DVD-R155 Logo
219 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
