Question about ASUS P4B-M (P4BM1400WOLTINY) Motherboard
Good day! I have a P4B asus Motherboard quiet older since its memory is sdram with 2.26 mhz processor installed with Windows xp Professional 2 the thing is a day comes that when I tried to boot it it can not enter Windows. So i find solutions to fix it. I tried booting it so many times but I failed even properly installing its peripherals specially hdd but it wont. The second step I did was installing my hdd to the other unit since I can`t perform the repair os installation setup in the said unit. I`ve done the repair os installation twice then installed back then tried to do the repair setup but I can`t proceed because a message pops-up that usbehi.sys is corrupted from my cd installer although it function good in the other unit. Anybody could help me with my problem. Your bright ideas and opinions will be appreciated.
2 Suggested Answers
EMKartha
  • 163 Answers
SOURCE: Good day! I have a P4B ASUS Motherboard quiet
Sounds like your CD drive is having a Read issue. If it works fine in another unit, it should work fine in this old unit too. But there are chances of drives of different brands having different read write capacities. For Example, some major brands in the market wouldnt read a CD which is having slight issues, while some ordinary brands of CD drives will read the same disk. I have experienced this couple of times. Here i have an option for you. Put the CD in another unit, copy the entire files to the HDD of that unit using xcopy command..
At Dos Command Prompt...
Xcopy <Source> <Destination> /s /e
You will get all the data on the disk copied to the destination folder.
Write another fresh CD with RW speed at 8X or 16X and get it burned with this data..
Remember, that the data which is on original should be written on to the new CD the same way.
Try to install with the newly written CD, and you will surely get rid of this issue. I am advicing you to make a complete new CD using the other box which can read this disk, as there could be chances of more files not being read if you use this original CD on this unit which has trouble. Do write back if you need any further assistance. Thanks for your Troubleshooting request. Good Luck.
Posted on Mar 23, 2010
I currently use 256 mb ram,I want change 1 gb ram,pls ur opinion
Upgrading RAM on your ASUS P4B-MX Motherboards is easy, we carry compatible RAM Upgrade for ASUS P4B-MX Motherboards, the ASUS P4B-MX Motherboards takes the PC100/133 SDRAM DIMMs.
Supports ECC RAM Type, and comes installed with 0 MB (removable) of RAM. You can upgrade your ASUS P4B-MX Motherboards to up to a maximum of 3.0 GB RAM, the Motherboards has 3 sockets to install RAM, already with 0 MB (removable) standard RAM installed. For best Motherboards performance use the maximum amount of allowed RAM per slot for your system.
Buy our Motherboards RAM with confidence, we provide lifetime warranty on all RAM Modules purchased, backed with an excelled customer support. Choose the following RAM Upgrade for ASUS P4B-MX Motherboards.
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules
hope this helps you
Mar 20, 2012 | ASUS Intel 845 Chipset P4B-FX Motherboard
Can I use DDR2 memory with asus p5gv-mx
No you cannot.
This is the RAM specification for your model motherboard.
Memory Memory Type DDR SDRAM Supported RAM speeds 400 MHz • 333 MHz Max Supported RAM 4 GB
Jul 14, 2011 | Computers & Internet
Good day! I have a P4B ASUS Motherboard quiet older since its memory is SDRAM with 2.26 MHz processor installed with Windows XP Professional 2, the thing is a day comes that when I tried to boot it, it can...
Mar 23, 2010 | ASUS P4B-M (P4BM1400WOLTINY) Motherboard
Please identify RAM upgrade options for Asus PSCH-L motherboard. Thank you.
From the Asus spec site: Memory Memory Type dtrquestion.gif DDR SDRAM Number of Memory Slots 4 x 184 Pin DIMMs Supported RAM speeds 400 MHz • 333 MHz • 266 MHz Max Supported RAM dtrquestion.gif 4 GB
Memory Memory Type dtrquestion.gif DDR SDRAM Number of Memory Slots 4 x 184 Pin DIMMs Supported RAM speeds 400 MHz • 333 MHz • 266 MHz Max Supported RAM dtrquestion.gif 4 GB DDR SDRAM 400; 333; 266mhz
4 GB max 4x1024 184pin
Hope this helps.
Aug 26, 2009 | ASUS PSCH-L Motherboard
Memory upgarade
Yes, it will work. Remember that all memory will operate at the speed of the slowest memory though so unless you're completely replacing the memory it won't increase the speed of the memory.
Jul 21, 2009 | ASUS A7V400-MX Motherboard
Asus P4B 1.7 mhz P4 motherboard restarts every 10-15 minutes...
Check the CPU temprature from the BIOS. Sometimes if the CPU overheats the system will automatically reboot. High CPU tempratures goes form (60-70). You can also monitor the fan speed and cpu temprature using this utility
http://www.almico.com/speedfan.php
Oct 27, 2008 | ASUS P4B-M (P4BM1400WOLTINY) Motherboard
Regarding upgradation of SDRAM
hi dear
there is always speed mismatch problem occur when we use low processor & high ram
so try to use 256 ram
also try to use 1 slot of 256 ram & 2 slots of 128 ram diffrently
& compare the speed
hope it will help to u
Jul 08, 2008 | ASUS SiS Chipset CUSI-FX Motherboard
Lost motherboard driver of asus
i want a diver sound for motherboard asus P4B-M
Mar 03, 2008 | ASUS P4B266 Motherboard
Asus A7V8X 1 gb sim
Have you tried the 1gb in the motherboard on its own but in different slots. i.e try slot 1 then slot 2 then slot 3 and see if you still get beeps.
Aug 23, 2007 | Abit BL7-RAID Motherboard
ASUS P4B-M (P4BM1400WOLTINY) Motherboard Logo
106 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
