Question about Casio FX-260 Calculator
Calculator statistics question, z score and std norm distribution
I need a calculator that has a function where you can enter the z-score in a standard normal distribution and get the area associated with it. My current calculator is Casio fx-260solar. I can upgrade but do not need a full graphing calculator. I need functions related to statistics to be available. Thanks so much!
  • Casio Master
  • 8,064 Answers
The Casio FX-115W/991W/115E/991ES have three functions P(, Q(, R( and t(: the last one calculates the normalized variable noted t.
The Sharp EL-520W ans several similar Sharps do it too. Here is a screen capture.
Posted on Jun 22, 2010
Where is normal distribution symbol?
I am sorry there are no statistical probability distribution functions on the FX-82ES calculators. Try with the FX-991ES.
Oct 07, 2015 | Casio Scientific Calculator Fx-82es Plus
Can I calculate p-value on the casio fx-115es plus?
Press MODE 3 AC to enter the statistics mode. Press SHIFT STAT 7 to bring up the distribution menu then 1 to invoke P( .
Nov 03, 2012 | Casio FX-115ES Scientific Calculator
How do you find the standard deviation using the list function when you place values in two lists? (Casio fx-9750GII)
It depends what the two list mean.
If you are doing 1-var statistics you may want to enter the frequency of a data element (if some are repeated) in the list L2.
In that case when you run the CALC 1-Var , you first press the F6 key to set the lists Data List1, and Frequency List 2.
Once you set the lists, press the F1 key to select 1-var. The calculator will give all the statistics of the distribution.
If you are doing 2-var stats SET the lists and press F2 2-var. The calculator will give you the x-statistics, followed by the y-statistics.
Sep 17, 2011 | Casio FX9750GII Graphic Calculator
In a standard normal distribution, what percentage of all scores fall below z=2.13
Press 2nd and Distr and find the InvNorm function. Enter InvNorm(2.13).
If you wanted to find the percentage that fall above, you would enter
1-InvNorm(2.13)
Dec 07, 2010 | Texas Instruments TI-84 Plus Calculator
Mar 23, 2010 | Casio FX-260 Calculator
Using the CFX9850G, how do you get to do normal distribution with lower,upper, mean and standard deviation? I can't find the menu to get to that function.
Press Menu to get the icons displayed. Highlight STAT and press EXE.
If you want to perform statistical calculations, press the F2:Calc key and choose the Type of stats :1-Var, 2-Var, and Regressions.
If you want to use the normal distribution, press F5:DIST then F1:NORM.
Feb 15, 2010 | Casio CFX-9850G Plus Calculator
How do i find the variance if i'm given the x
Set the [Mode] to [3:STAT]. You are offered the choices
1:1-Var
2:A+BX
3:__+cX^2
etc.
If you want to do 1-Var statistics, you press 1:1-Var. A column template opens where you put the X values. If a value is repeated you enter it several times. (there is no frequency column.)
When you enter all data you press [SHIFT][STAT]
You have several choices among them
4: SUM to get SigmaX^2 and Sigma X
5: VAR to get n, the mean X bar, the sample and population standard deviations
6:MINIMAX to get MinX and MaxX
7: Distr the Distributions.
If you want to perform 2-Var statistics
You press [MODE][STAT] and select one of the Regression models
2:A+BX
3:__+cX^2
etc.
The selection of any of the 7 regression models, opens a two-column template where you enter the X and Y values
When finished press [SHIFT][STAT]
The choices offered are
  1. Type takes you back to select type of statistics to perform
  2. Data To edit the data in the columns
  3. Edit To insert or delete a value
  4. SUM To access the calculated values of SigX^2,SigX,SigY^2,SigY,SigXY,SigX^3, SigX^2Y, SigX^4
  5. Var : To access the calculated values n, Xbar, Sample STD for x, S STD for Y, Pop STD for X, and Pop STD for Y
  6. MinMax : MinX, MinY, MaxX, MaxY
  7. Reg: Gives you the regression coefficients for the particular regression model you want to test.
The mean is represented by X bar.
The variance is the SQUARE of the Standard Deviation.
Hope it helps.
Nov 06, 2009 | Casio fx-300ES Calculator
Median for statistics
The TI-30XA doesn't give the median of a sequence of entered values, just the mean, std dev, and other one variable stats
Jan 27, 2008 | Texas Instruments TI-30XA Calculator
Casio FX-260 Calculator Logo
814 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
