FixYa.com
Tags:
Flat Panel Televisions
Generic problem for all Flat Panel Televisions
Plasma tv won't power up after lightning strike (by 4 users)
posted by letsgomurphy on Mar 30, 2008
Fuses and main power switch chech out ok, but am lost from here on out.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Comment by realtorkoko, posted on Jul 16, 2008
we had
Comment by SandMA, posted on Jul 03, 2008
I experienced a slight light flicker, and then my TV went out. I tried other power surge protectors and outlets, but nothing works. The two other appliances plugged into the strip work fine. Please help!
Comment by MountainDoo, posted on May 18, 2008
my fuse blew and after i turned the power back on my tv will not power on. im not brainy when it comes to stuff like this so idk what to do. i cant just can this tv because hell im not even done paying on it yet..=/
Best Solution
posted on Mar 31, 2008
Helpful (85)
dawnn
Rank:Wiz Wiz
Rating: 83%, 64 votes
are you sure you seen all the fuses on all of the boards, (they are numerous, and hard to spot, not like fuses you are used to looking for.) if so then your power supply is at fault and must be replaced.
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: Sony BRAVIA KDL-40S2000 40 in. HDTV LCD Television Panasonic TH-42PD50U 42 in. EDTV Plasma Television Panasonic TH-42PX60U Television Emerson EWL20S5 20 in. EDTV-Ready LCD Television Philips 42PF9630A 42 in. Plasma Television Philips Magnavox 42MF521D/37 Television Philips 37PF5521D 37 in. HDTV-Ready LCD Television
Can you Help with these Flat Panel Televisions problems?
iLO LCT32HA36 Television
iLO LCT32HA36
Can you give me the code number... Answer This...
Toshiba REGZA 42WLG66 42 in. HDTV-Ready LCD...
Bright colors flicker
Bright colors such as uniforms... Answer This...
Philips 50PF7321D 50 in. HDTV Plasma...
error code
green light a few seconds then... Answer This...
cannot get sky (pace box) to...
dont know how to tune remote... Answer This...
Sony BRAVIA KLV-40U100M 40 in. HDTV-Ready LCD...
No image from inputs 1 and 2
No video signal from inputs 1... Answer This...
Repair Service
Find Flat Panel TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
