Question about Sony Playstation 3 (PS3) Console
Sony ps3 starts up then shuts down 3 beeps red led flashing
Hi all i bought my sony ps3 60gb console of ebay and now it has gone faulty when i try to turn it on the fans spins then the console shuts down with 3 beeps and the red standby led flashing on & of ive tryd removing the hard drive but no difference can any1 help me is there any cure for this thanks
  • 6 more comments
  • jacco123 Apr 26, 2008
    same to mine, not any help for it?
  • silver310 Dec 22, 2008
    Hi.Yes i have same problem.Please help me!!
  • ballz34 Feb 03, 2009
    I have the same problem. Are you sure it is the bearings in the fan that are bad. Because when I power on the fan kicks on like it should then 3 beeps and flashing red light
  • Anonymous Apr 11, 2009
    its happening to me 2.first most games were freezing now this is happening.
    playing killzone2 and suddenly ps3 shutdown. turned it back on and it shut itself down and red light flashing.
  • Anonymous Apr 17, 2009
    i have the same problem guys, im looking 4 a solution
  • brianathome Apr 20, 2009
    I have the same problem. Also started a few weeks ago freezing during game play. Have had for almost 2 years and never froze until now. :( Have not found a solution.
  • Phil
    Phil Jan 10, 2014
    I have the same problem, think I'll just buy a new one.
    New Friend:
Just had this happen to me and I fixed it myself. It is likely that the CPU and GPU needs new silicone on it. You have to wipe the old silicone off and spread new on it. I got it at Radio Shack, just make sure you have THERMO SILICONE and also a heat gun before you try to fix. Just go to YouTube and look up the following: YLOD fix. A guy walks you through the whole process. I did exactly what he said step by step and now my PS3 works. I wouldn't try this unless you are handy and your warranty has expired. If your warranty is still good send it to Sony. I hope this helps....
Posted on Feb 20, 2010
    Sniper:
  • 85 Answers
Unless your fan is making an abnormally loud noise it is not the bearings. The problem you are having is from a bad Heat Sync as well as the CPU and GPU needing to be re-seated. I have personally fixed this with my own PS3 as well as others. I run my own home based pc repair business in southern california. Email me at [email protected] for more information.
Posted on May 16, 2009
  • 3 Answers
Im having tha same problem rite now...it means tha barrings on ur fan r bad...u need a new internal fan..tha trick is finding where 2 get one..lemme kno if u find a place that can get em..thanx
Posted on Jun 30, 2008
    Sniper:
  • 84 Answers
Ahhh the dreaded red light, sorry buddy i would ent get stuff like that off ebay but if it came with a 1 800 number try to call that and ask them
Posted on Mar 31, 2008
SOURCE:
My PS3 (40Gb) has just shut down on me. I was playing COD Modern Warfare 2 when the PS3 just shut down and then beeped at me 3 times the red light started flashing and when I pressed the power area the...
Its called yellow light of death. Here is a link to my step-by-step instructions on how to fix.
http://www.fixya.com/support/t8396931-ps3_turns_ok_but_turns_itself_off_after
Feb 24, 2011 | Sony Playstation 3 (PS3) Console
Updated system last night and this morning when i powered it on, it came on and worked fine for about 3 mins then it shut off with a flashing red light... now it wont start up at all...
Oh man thanks SONY, right?
Well you should try a video reset first and if that doesn't work then pull the hard drive out and try booting the console with no drive.
For the video reset: While the PS3 is off (solid red led) hold down the power button until you hear the SECOND beep, quickly release.
Let me know what happens.
May 23, 2010 | Sony Playstation 3 (PS3) Console
Ps3 won't turn on just beeps then switches off
Please check if you get a yellow or red light flash and how many times does the ps3 beep before it shuts down.
If you get a Yellow Light, reason below:
If the hard-drive fails on the PS3 you may get a solid yellow led, The yellow light will show if the console is overheating as well, but the console shuts down so you don't it for long.
1)Turn off your playstation 3. If you think your ps3 has been caught by the heat, then wait at least 20 minutes and put it back on again
2) Check if there's any loose cable.
3) Try to put out your playstation's hard-drive, and put it back in. You might want to repeat this 2-3 times for better results.
If this did not work, then it is suggested to send your PS3 for repairs to Sony Customer Support
Let me know of this helped and please take time to rate my solution.
Wishing you Happy Holidays and Happy Gaming
Regards
Kreative Geek
Dec 23, 2009 | Sony Playstation 3 (PS3) Console
Hi, my ps3 shutting down when I turne on the power
try rebuilding the database and the file system in recovery consol
to get to the recovery consol press and hold the power button when ps3 is in standby mode(red light) till you hear a double beep. sometimes the ps3 does a beep then another beep and goes back into standby thsi is fine just release the power and quikly press and hold it again till you get double beep.
like on my 80g system it goes like this
ps3 standby...press hold power.......beep .........beep........stanby again....release and hold power again.......beep .........double beep...release power now you should be in recovery menu.
Oct 27, 2009 | Sony PS3 40GB Best Sellers Bundle Console
Ps3 wont boot red flashing light all since download latest update
Your console is going into protection mode to protect the from being damaged.
First thing do is check the ventilation, make sure the fans are running, make sure you have min of 1 foot around the PS3.
If all is ok, with the PS3 in stand by mode Press and hold the power button for 5 secs.. until you hear the second beep this cause the PS3 to reset.
If you have the 60GB version then you might have a faulty power supply which was a known issue on these 60GB versions, if you have contact Sony and plead for a console repair free of charge, other than that they might do a repair but it will cost approx £145 in the UK.
Thanks
Sep 04, 2009 | Sony Playstation 3 (PS3) Console
PLAYSTATION 3 60gb problem Playing just fine then shut off and beeped with flashing red light. Tried turning back on, green light came on then a yellowish light blinked quick, turned red and shut off and...
Hi there, this is usually a sign of the Yellow Light Of Death (YLOD). Your console does not have to overheat for this error to occur. When the PS3 was originally made Sony used lead free solder in their consoles. Lead free solder is not as flexible as normal leaded solder and over time due to expansion and contraction because of heat given off by the console's components lots of PS3's failed. You have got a couple of options, you can either have the console professionally repaired which is going to cost around £50. If the console is out of warranty Sony will only replace it for a cost of around £130. As a last resort if you are good with electrical items you might want to have a go at repairing it yourself. If you google YLOD you will find plenty of guides that will instruct you on how you can repair it yourself.
Please bear in mind that once a console has the YLOD there is NO guarantee as to how long a repair will last, it could be a couple of hours to a couple of years.
I hope this information helps you and I hope you get your PS3 up and running soon.
Aug 27, 2009 | Sony Playstation 3 (PS3) Console
System will not turn on
hard drive error get a new hardrive -might work or call sony for a replacement ps3
Aug 16, 2009 | Sony Playstation 3 (PS3) Console
When I turn on my PS3 it turns yellow then immediately shuts down
Its the yellow light of death, its an over heated ps3. Theres not much you can do about it, take it to sony or a computer fixing shop and get the console fixed. These can be fixed at a price of around £35. If you cant get that, get a new ps3, its what i had to do.
Aug 08, 2009 | Sony PlayStation® 3 (60 GB) Console
Ps3 60gb no operating system
First the PS3 doesn't use flash memory, it uses a 2.5in SATA hardrive. It can't be that there is no OS, otherwise the PS3 would write it to the hardrive, it must be corrupted or have some other problem.
I would recommend buying a 2.5in SATA hardrive - they're very cheap. Ask in store for one, or you can get one from Play.com. If that doesn't work, it's a problem with the PS3 itself and you should phone Sony.
Jun 20, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
5,229 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
