Screen all blue
Switched it on and got an all blue screen one day (red and green are there but flash)
popped the back cover off and you can see the red and the green tubes flashing really fast, but the blue just sits there bright with no flashing.
i can cure it temporarily by swapping 2 colours on the back of the focus block.
There is no noise and the tv still takes the same time to come on as normal.
Any ideas whats causing this???
  • FunkedUp Mar 31, 2008
    ok thanks for the suggestion I will check. Any idea on rough cost to fix if this is the problem?
  • 8,617 Answers
Try looking into the blue CRT lens while its on and see if the coolant has congealed. You will be able to tell if it has bacteria growing as this can cause the blue to be unresposive and make your screen have a blue haze. The coolant will need changing if this is congealed with bacteria. This is a common problem in all projection tvs blue and green are more prone to this sympton red is not.
Posted on Mar 30, 2008
  • Sonny Berry
    Sonny Berry Apr 01, 2008
    a repair shop will charge about 300 to 400 to do it. However you can do it yourself in about an hour per tube. Its very easy and I am compiling a file with instructions on how to do the coolant change that will be available at my other site in a day or two.
Hi my audiovox fpe2705 needs red color in shows only in green an blue thank you
remove back cover then check the CRT tube if there is color red cathode how?by using a wire or test prove connected in ground in your TV very quick if red screen flashes your CRT is good then check your CRT board socket find the driver transistor of red cathode then check it if shorted replace thank you
Mar 05, 2011 | Televison & Video
Bluish screen on Acer AL2016w LCD monitor
Good day sir, you are right I may say, the loss of red will cause the screen to go blue, the cable that connects to the lcd and mainboard usually has 3 wires, red green and blue, my guess is the red wire isnt connected properly. there are two terminals one on the LCD and one on the mainboard. better check both side of that cable. It may be caused by cold solder joints, due to the fact that it pops up occasionally, sad to say that any adjustments wont work. unless it is fixed. hope this may help. if you have any more questions, please feel free to ask again. thanks.
Jul 16, 2009 | Acer AL2016W 20" LCD Monitor
Hitachi television repair
Try switching the power off at the PLUG for the night. This will allow the screen to reset. I had a similar problem after a power failure.
Nov 03, 2008 | Hitachi C29-F100 29" TV
Sony kp41s3u - blue screen
Convergence amp ic bad or loose connection on ic's
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
Feb 26, 2008 | Televison & Video
Blue screen with Green Star-burst image in center?
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Jan 19, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Green box keeps popping up in upper right corner
You should be watching your dvd's on an input and not on tv analog 3. Every time the tv "senses" a signal change in the audio that screen will pop up. Connect the DVD player to the tv by using either the red, white and yellow (composite) connections or using the green, blue, red, white and red (component). Once you are on an actual input that box will stop popping up.
Dec 27, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Help with kogi F9AH screen
Intermittently displays bright red/green/blue raster then shuts down with led flashing 2, 4 or 5 times
Amazingly this was due to the CRT being faulty !
Blank raster
Replace defective TDA6111Q for Red, Blue and green
Red or Green or Blue screen
Check and replace on crt module : D702, D703, D704 (all 1N4148) replace with type 1N4948T
Dead, led flashing red/green at first, then going to red standby
Replace C604 (1000uF, 16v) elec. cap. It is in the decoupling circuit for the 5 volt supply
Nov 23, 2007 | GVision F9AH-TG Television
Rear Projection Tv Problem! black and white... Please help
go into menu turn color off see if you have a black and white picture if not adjust red,green, and blue screen drive on controls in back of tv you have red, green, blue it will have focus /screen controls cover each tube do one at a time blue focus and screen drive adjust to clear blue picture do all 3 tubes, then adjust them to where you have a black&white picture once this is done turn color controll back on.Thank You for using FixYa and Have a Nice Day.
Nov 11, 2007 | Toshiba 50H72 50" Rear Projection...
Red & green lamps shutting off leaving a blue screen
Could you show a picture of the distended cover you mentioned?
Were the light blue lines you were referring to, diagonal, or truly horizontal?
Oct 15, 2007 | Sony KP-57WS500 57" Rear Projection...
Red Screen
try tapping lightly on the tub that matches your color problem.
do you see it come and go? if so then you have bad tubes.
you can try to rejuvenate them but is not recomended.
Jul 06, 2007 | Akai PT5598HD 55" Rear Projection...
Televison & Video Logo
149 people viewed this question
Top Televison & Video Experts
