Question about Maytag Neptune FAV6800AW Top Load Washer
Getting dc error code in rinse cycle, 13 min.
Getting dc error code in rinse cycle 13 min. Before being done Have un-pluged and still getting code. Maytag FAV6800 led washer 5 years old.
  • 526 Answers
See my Clutch Fix post. Anyone with basic mechanical skill sets can save there $1000 machine for low cost maintenance or Clutch pulley replacement.......Rich
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
Posted on May 15, 2010
I have an lg tromm front load washer. I am getting the IE fault. I have cleaned the inlet screens and drain filter. It gets stuck at the 13 min mark, seems like it just won't go to spin cycle.
LE code mean suds have built up. Using non he (High Efficiency) detergent or too much detergent will cause this error most front loaders use he detergent only there is a he swirl on the container
Let your washer sit idle or 45 minutes.Unplg washer as well
Plug in and turn on as left spin speed select no spin press Start/pause to start a drain only cycle. When cycle is complete remove load. Start a rinse•spin cycle to clean out residue.
If the sud were too much you may have to repeat
Jul 25, 2015 | LG Washing Machines
My maytag washer when i start it it fills then the cycle starts the timer will count down til it get to 13 min then jumps down to 3 min then shuts off it skips the wash cycle and the rinse cycle befor
sounds like you have a problem with the main control board. you can order a new one from appliancerepair.com and if it turns out not to be the problem they allow you to return it for a full refund. great company!
May 26, 2014 | LG Washing Machines
Washer stops cycleing
First are you sure the error code is 'LE' and not 'tE' which looks very similar. The LE is usually the motor position sensor. Common on older washers. Easy fix. Under $20 part. The tE error is usually the thermistor. Inexpensive part about $6, but can be more complicated to get to. Ad a comment to your question and my answer with error code and I'll reply with more info if needed.
Jun 24, 2017 | LG WT4870CW 4.5 Cu. Ft. Top Load White...
Have Neptune FAV6800AWW top load, washes when it gets to the rinse cycle it stops with water in. If we remove the clothes and wait a while we can get it to complete. The code we are getting is DR which...
Are you sure the error code is DR? Could it be DC an unbalance error code. Google ""16022808.pdf"" to find. Is the washer banging around in Spin Cycle? If so this is a Clutch Pulley issue.
Google this ""Neptune TL Washer FAV6800AWW"" a forum where I help owners of the FAV6800A and FAV9800A machines.
DR is not a listed error code in the FAV6800A/FAV9800A Service Manual.
Aug 27, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My maytag fav6800aw top loader getting dc code in rinse cycle 12 min.stops and go's back then try's to spin but the tub starts moving all over the place.and then try's again after a while just stops it...
ernieesparza
You have clutch malfunction. Take a look at my Clutch Fix post and see if you can DIY the fix.
Basic hand tools and DIY skill sets is all that is required and you can save your $1K machine. Post back if you have questions or concerns…..Rich
Mar 27, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Getting dc error code in rinse cycle, 13 min. before being done Have un-pluged and still getting code. Maytag FAV6800 LED washer, 5 years old.
Hello rdberg,
See this post Clutch Fix it has helped a few owners with the dC and uC unbalance errors with the FAV6800A and FAV9800A machines. You have a very common problem with a Clutch malfunction. The first part of the post has to do with the nuts and bolts of disassembly and Clutch maintenance or replacement of the Clutch Pulley.
In the last part of the post I go into just how to check the One-Way Rollers clutches to verify that are locking up. If they don’t this results in tumbler movement on Wash Basket spin up and the unbalance errors. If you are handy and have some basic hand tools you can get your machine back in service at low cost.
Post back if you have questions…..Rich
Mar 23, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Error code E:13 is showing on the washer
Mine did it too on a light load. Set to reduced spin and rinse spin and everything ok. Think this code shuts washer down when spinning out of balance to protect damaging the unit.
Mar 21, 2010 | Siemens WFXD5202UC Washer
Washer says DC and stops on rinse cycle
DC= Distribute Clothes: The load is unbalanced, preventing high speed spin. Redistribute clothes.
Sep 24, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Whirlpool Cabrio F50 Error
Most likely the RPS sensor or the control board. Originally they had trouble with the RPS sensors.
Aug 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
MAH 2400 AWW flashing error code "dc"
Hi Pepsi,
"dc" means that the control board is trying to ramp up (that is, send a signal to the motor controller), but has encountered an unbalanced load and so shuts down. Specifically, "dc" means "distribute clothes".
I took this opportunity to upload a Tech and Troubleshooting manual for you. Here is the link for it. Read it carefully. You will be required to perform a "board output" test after placing the machine in "Service Mode".
I gotta tell ya, though. Based on my history with these, I highly suspect that the machine control board has failed. Let me know what you find, OK?
(And don't forget to rate this solution as "FixYA!", deal?
SG
Apr 11, 2009 | Maytag MAH2400A Front Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
789 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
