Question about Lexmark X4270 All-In-One InkJet Printer
Problem Receiving a fax
When I receive a fax , I only receive a blank sheet. Was having the same problem when I send a fax, distant end party would get a blank sheet,I change default setting to 9.6 and am able to send, but still getting a blank sheet when I receive a fax. Please advis. Thanks. Jose
  • papaMex Mar 30, 2008
    I taken the ink cartridge and shook them.
    How can the cartridge be dry, If I can copy color and B&W copies. Also, I can print from the computer too. In color.
    ???? plsease advise thanks,
    - document was not loaded upside down
    - It's not out of Ink. I can manually make a copy and print a document from the computer in color.
    - time and date are set
    please adv tks
  • Lexmark Master
  • 13,433 Answers
Is the original fax loaded upside down?
Is the receiving fax machine out of ink?
Are both the black and color cartridges installed?
Are the date and time set correctly?
Setting the date and time on the display To set the current date and time:
  1. On the control panel, press Fax.
  2. Press Options until EDIT DATE/TIME: appears on the display.
To change the date:
  1. Press Select.
  2. Use the keypad buttons to enter the date you want your All-In-One to display.
Note: If you make an error entering the date, you can use the left arrow button to navigate to the number you entered incorrectly, and then enter your correction.
  1. Press Select.
To change the time:
  1. Press the right arrow once, and then press Select.
  2. Press 1 for 12-hour time or 2 for 24-hour time.
  3. Use the keypad buttons to enter the time you want your All-In-One to display.
Note: If you make an error entering the time, you can use the left arrow button to navigate to the number you entered incorrectly, and then enter your correction.
  1. Press Select.
  2. If you are using 12-hour time, press 1 for AM or 2 for PM.
Posted on Mar 30, 2008
  • Ekse Mar 30, 2008
    you gave
    oldnovii
    a fixya rateing, did he solve the problem?
    is your problem solved?
  • 667 Answers
How long have you had this problem? About a week or two? Check to make sure the date and time are set correctly. With this machine if they are not set correctly it can cause you to receive blank faxes.
    Sergeant:
  • 395 Answers
Replace the ink cartridge it may be dry. also check with lexmark for firmware upgrades you may have to call them for the latest firmware upgrades.
    Guru:
  • 1,894 Answers
Have you done a reset?
NEED 2 PROGRAM COVER PAGE
Cover Sheet
You can have the fax machine generate a cover sheet and send it as the last page of your fax transmission. The cover sheet includes the date and time, the receiver's name and number if a Rapid Key or Speed Dial number is used, the sender's name and number, and the total number of pages.
? Your name and number must be programmed in order for them to appear
on the cover sheet (see page 49).
? To have the recipient's name appear, you must dial using a Rapid Key or
Speed Dial number with the name programmed.
1 Load the document(s).
• SEND READY will appear in the display.
• Press RESOLUTION and/or CONTRAST to set the resolution and contrast if needed.
Press Cover Sheet. (Flip up the Rapid Key overlay if it is down.)
• The display will briefly show COVER SHEET MODE ENTERED and then
revert to SEND READY.
• To cancel the cover sheet selection, press STOP.
3 Dial the receiving party and transmit the fax.
If desired, you can set your fax to automatically send a cover sheet with every
transmission (you do not have to press COVER SHEET each time). This is
accomplished by setting Option Setting 10 (Auto Cover Sheet) to YES as
explained on page 125.
Jan 17, 2011 | Sharp FO 5800 Fax
If we send afax than it is coming blank at another
make sure you are placing the document in the feeder correctly. some faxes you have to send it face down others you have to send it face up.
Aug 06, 2009 | Brother Office Equipment & Supplies
Printing blank pages when receiving fax
Ask if the ones sending are sending legal size, it may be using 2 sheets to get all from a legal size document.
Jul 29, 2009 | Brother MFC-8460N All-In-One Printer
Receiving fax
Hook up a regular phone to the line and dial *69.
The number should also show up on the display if the other party has programmed it in the sending fax.
Feb 16, 2009 | Xerox WorkCentre Pro 575 Plain Paper Laser...
Fax will not send
Does the receiving or sending party have a DSL phone line?
Aug 01, 2008 | Brother MFC-8220 Fax
All Fax pages not received or sent.
have you watched the paper going through the doc feeder are thay goning one by one or is it pulling more then one. try making a copie withe 4 sheets does that work. if not open cover of doc feeder clean rollers. serperation pad. ( pad would be twrods the top of the cover )
C.W.H.
Jul 21, 2008 | Canon LaserClass 2050 Plain Paper Fax
TX problem
If I understand you right, what you send, people are receiving blank sheets?
When you try to run a copy are those blank also?
If so your problem is with the scanner. The drum should have nothing to do with sent faxes.
Unless your putting the paper in the scanner upside down. And if you ran it enough to need a drum I can't imagine that .
May 15, 2008 | Xerox FaxCentre F116 Plain Paper Laser
Probllem receiving a Fax
No, the solution you provided I had already done. Problem is not solved as it was guarranteed, but I was charge for it and you still want me to purchaed the premium solution.? Get real!. my charge should be refunded..Very dissatisfied.
Mar 30, 2008 | Lexmark X4270 All-In-One InkJet Printer
Receiving a fax
It will be a problem with the other ends fax when it sends its stretches out the fax too much and it transmits accross two pages. The other fax is telling your machine to print out accross two pages in the transmission. Older faxes are the worst for it.
Feb 18, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Lexmark X4270 All-In-One InkJet Printer Logo
83 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
