Question about Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer
Washer Thanks for those suggestions, I turned the power off, tried unplugging etc. Everytime I push the cancel button it just turns the machine off. So i think we will have to take the panel off. Once I get it open, is there something I can do to totally reset the thing?
Have you checked the filter in the bottom panal of the machine....take this panel off and you will see a filter thing twist and empty that.....i paid 152 dollars for someone to do that
Posted on Apr 07, 2008
    President:
  • 1,314 Answers
Well id try it again it may be just stuck you might spray some wd 40 up in the latch assembly ive heard this helps then lets see what it does
Posted on Mar 30, 2008
SOURCE:
Only button that "beeps" is cancel
If the buttons works but not the beep , then it can be related to some error in the program or a switch off/mute.
However if the buttons do not work then it can be moisture build up within that can cancel the switching and so there is no beep as the contact is not made. In any case try and heat the front panel very softly and see if the fault clears.
Jan 24, 2013 | Frigidaire Affinity ATF8000FS
I had the main water shut off and forgot to turn it on before starting my machine. Now it is stuck. I unplugged it for a couple hours, then plugged it back in and the lights just blink and the cancel...
try this:
Press "Stop" two times.
Push "Power."
Select the button for the desired wash cycle.
Press the appropriate "Modifiers" and "Options" buttons to adjust the settings.
Push "Start."
thanks to here
Mar 06, 2011 | Kenmore Elite 45986 Front Load Washer
How do i reset my kenmore he 2 washer
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 03, 2010 | Kenmore HE2 Plus Front Load Washer
Error Message
Your owner's manual may give a troubleshooting guide for the error code your machine might give you. Is it possible you have locked out the control panel? I "think" the calypso has a control lockout, usually a start button or cancel button. If you press it in for 3-5 seconds, it can lock or unlock panel. If all else fails, try unplugging it and see it it will drain out the water.
May 20, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
My washer won't turn on. It just beeps when i
Hi, this is a main control panel issue. here is a procedure you can preform to gain control back.
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN/SPIN if there is excessive water in the washer.
Re-select cycle and press START.
If the problem persist, you will have to have the control panel repaired by the service tech.
Mar 07, 2009 | Whirlpool WFW9400S
F20 CODE Whirlpool Duet Sport Washer wfw8300sw00
Hi!
“F20” on display
(Water Inlet Problem—no water or insufficient
water supply) Select PAUSE/CANCEL twice to cancel the cycle
Unplug washer or disconnect power. Check the following: Are water faucets completely turned on?
Are screens at inlet hose connection to washer
clogged? Are water inlet hoses kinked? Are water inlet hoses frozen?
Do rate the solution.
Thanks
Rylee
Feb 08, 2009 | Whirlpool WFW8300SW
Washer power
Sounds like you have a stuck or shorted keypad. I've seen this a lot on this model. Solution is to replace the keypad. Catriver.
Aug 04, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Re: control lock is on
FOUND OUT HOW TO FIX PROBLEM . ON MY WASHER AT BOTTOM RIGHT HAND CORNER ,IT SAYS END OF CYLCLE SIGNAL. HOLD IN FOR 5 SECONDS AND IT WILL FIX ITSELF
Jan 14, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Front load washer won't start
Telescope, Im assuming your model starts with 417.44092, Kenmore made by Frigidaire. You have the best model with the digital display. Try unplugging the machine for 5 minutes to see if you can reset the board. If that doesn't work put it into a test mode by doing the following: Turn the dial to drain spin, press cancel to turn off the led's. Within 5 seconds press and hold the options and pause/cancel together for 5 seconds. All the led's should light. Now by turning the dial 1 click at a time clockwise you are going to test the following. 1rst click- hot water solenoid 2. bleach solenoid 3. Bleach and wash water solenoid 4. door lock solenoid activates 5. door lock solenoid de-activates. 6. the washer will fill and tumbe. 7. washer will fill and spin 8. drain pump and door lock will activate and washer will go in high spin. 9 clicks from the start, the last error code will be displayed. To clear the error, press and hold the options and cancel buttons for 3 seconds. To exit the test, just unplug the washer for 5 seconds. Sometimes these electronic boards just get a glitch and have to be reset. Make sure that the dispensor door is shut all the way. Try these things first...Catriver..post back.
Nov 04, 2006 | Kenmore Energy Star 44092 Front Load...
Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer Logo
37 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
