Kyocera FS1010 "Print cartridge carriage stalled" what do I do please?
  • Needy Nick Mar 31, 2008
    Thanks so much. I'm ashamed to say I was muddled between my different printers, and it was actually my HP Office Jet that had this problem. But I really appreciate the detailed advice.
  • 112 Answers
This could well mean you are going to have to call a Kyocera technician in.
There are a number of reasons this could happen. The teeth on the cog that drives the carriage could be worn. They could also be not engaging properly for a number of reasons.
I would not expect a non tech to try to resolve this.
If you are fairly techeical try to strip the printer down to the carriage feed under the cartridges. Look fro lodged debry or similar or worn teeth on any of the palstic cogs. If you find worn parts you will need to get new from the manufacturer.
Sorry I cant be more helpful.
Let me know how you get on.
Posted on Mar 30, 2008
  • Geoff Champion
    Geoff Champion Apr 01, 2008
    Ah..... Well thats a horse of a different color as they say in the land of Oz.
    1) Open door so print heads move to the center
    2) Unplug the unit. (Don't turn off, just unplug!)
    3) Open back door
    4) Look inside the back left side for a small black gear (About the size of a quarter)
    5) Spin the gear with a screw driver (I'm pretty sure I spun it clockwise). Spin it and watch the inside of the printer where the print heads park. You should see a tray move out that has four rubber blue rectangles on it on the right side of the unit (this is where the print heads park when the unit is not printing).
    6) Keep spinning the gear until the plate moves all the way forward.
    7) Grab the plate and try moving it forward more.
    8) Put the back on and close the top.
    9) Turn the unit back on.
    10) Open the top again
    11) Unplug the unit again. (Don't turn off, just unplug!)
    12) Grab the tray, from step 5, and slide it all the way forward and all the way back multiple times.
    13) Make sure that the print heads slide left to right smoothly
    14) Remove ink cart's and clean the contacts with bottled water and a q-tip. LET DRY BEFORE REINSTALLING!!!
    15) Remove print heads and clean contacts with bottled water and q-tip. LET DRY BEFORE REINSTALLING!!!
    16) Clean the inside of the printer with a soft dry cloth, use a slightly damp, with bottled water, lint free cloth (Glasses cleaning cloth works well) and wipe off the rollers in the front and back of the unit. See HP's cruddy support site for details on this step.
    17) Hold down #7 (reprimes the printheads with ink) and plug in the unit
    If needed also turn off and do a #6 to reset the unit.
    Let me know how yo uget on ;-)
Hp C4280 printer says incompatible print cartridges wont print! 2 new cartridges installed
HP OJ 5110 the print cartridge carriage is stalled
door open,
clear carriage jam, and then press enter.
problem solution describe in hindi
Dec 13, 2010 | HP OfficeJet 5110 All-In-One InkJet...
Do both stalls need to contain a cartridge, in order to print?
Hi
Yes you are right both the stalls should contain cartridge. However, it is not necessary that the cartridges should contain ink. One of the cartridges can be empty.
Please put empty cartridge on the carriage, even if you want to print a BW document.
Daniel Scott
Jun 08, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Hi, am having problems configuring my Kyocera fs1010 to us usb port. How do I go about it??
please try with LPT cable and check ... please explain about your clearly what error you getting or how you configuring printer ....please post your comment ....
Dec 16, 2009 | Kyocera Mita FS 1010 Laser Printer
Kyocera Mita FS1010 fault
check your user guide... it will explain this error... or contact kyocera customer support...
Jun 25, 2009 | Kyocera Mita FS 1010 Laser Printer
Cartridge carriage is stalled
Please let me know how install the ink cartridges blak and color.
Could I have a copyof manual pls
Apr 26, 2009 | HP PSC 1610 All-In-One InkJet Printer
Stalled printer cartridges
Sounds like an issue with the print carriage. When it's out of alignment and tries to print, it can make awful noises. HP.com has a web page that describes a number of troubleshooting steps when you have print carriage issues:
Carriage Jam Errors
There's also a related web page having to do with the noise coming from the printer:
Noisy Print Carriage
Hope this helps. Good luck.
Oct 07, 2008 | HP OfficeJet 4215 All-In-One InkJet...
Kyocera FS1010 first page only half printed
I found this solution. Worked a treat. I took the printer apart and applied felts to the solenoids (the felt normally used for the bottom of cup coasters).
See the Success post in this thread...
http://www.copytechnet.com/forums/kyocera/15980-kyocera-fs1010-delayed-printing-1st-page-2.html#post55451
This manual helped too...
http://www.freeprintermanuals.com/PM/Kyocera%20FS-1010%20Parts%20Manual.pdf
This is the post...
Success
A solution has been found. Thank you to Steveauh (Townsville)
Kyocera in their wisdom have used a foam insulator on the 3 solenoids that disintegrates over time regardless of use.
  1. Open the right side of the printer
  2. Disconnect all connections to engine board
  3. Remove engine board
  4. Remove plastic guard (white)
  5. remove all 3 solenoids
  6. Replace all pads on the solenoids that come up against stops
    Registration Solenoid has 2 pads (1 against the solenoid frame and the other on a stop arm, the others just the frame pad)
  7. Keep thickness to around .4 - .5mm Too thick on register arm will cause early printing.
  8. Reassemble
And that is it. The arms were being magnetically delayed due the metallic contact. It seems to be a regular problem in this chassis FS1000 to FS1030.
Jun 23, 2008 | Kyocera Mita FS 1010 Laser Printer
I AM LOOKING FOR THE ITEM NUMBER FOR THE KYOCERA FS1010
this is not troubleshooting, try going onto their website
Apr 15, 2008 | Office Equipment & Supplies
Mac iBook G4 to print on my Kyocera FS1010
well...you need to get drivers from either apple.com or kyocera.com
Mar 23, 2008 | Office Equipment & Supplies
Printer Cartridge Carriage stalled
i believe that u havent install all the latest uptades of the printer...!
u can find all the drivers HERE
dont forget to vote!!
Stratos
Nov 06, 2007 | HP PSC 1510 All-In-One InkJet Printer
628 people viewed this question
k24674
jasbo
jasbo
