Paper jamed on the bottom of the copier that I can't get to it
  • 59 Answers
Hi just remove the paper casset and remove the paper and reset the casset hope help you
thanks
Posted on May 15, 2010
HOW DO I FIX THE PAPER JAMS?
click start , click devices and printers, right click printer image, click trouble shoot and follow directions.
Jul 09, 2015 | Canon NP 6317 COPIER FOR 220 VOLTS ONLY
Gestetner 6123 paper jaming feeding section copy printer
nrg 6123 copy printer after make stencil line on copy soulition
Jun 15, 2012 | Gestetner - AO40 Wide Format Copier Copier
IF PAPER HAS NOT JAMED BUT MACHINE ARE SHOW PAPER JAMED
Try cleaning the rubber paper feed rollers. If it fails to pick up the paper in a pre determined time it will show paper jam. The pick up tires must pick up paper when turning, if not the paper will not feed into the machine and it will show paper jam with no jammed paper.
Mar 16, 2011 | Canon imageRUNNER 400S Copier
Paper jamming sign lit up but no jammed paper seen
hi there shuld be paper inside or may be when u removed jamed paper not proper way some pice of paper struck in the sensor thats why paper jamed lit up clear the whole paper path it will solve problem if not there is any path sensor not working good just clean the path sensors
thanks
May 14, 2010 | Toshiba e-Studio163 Copier
My canon D761 copier does not feed paper. message says "paper jamed" but there isno paper jamed.How do I fix this
paper jam lit when jammed or feeding does not occurs, try cleaning the feed rollers and look if the feed rollers rotates when you copy
Mar 19, 2010 | Canon imageCLASS D761 Copier
Cannon pc770 copier claims that paper is jamed in copier checked and there is no paper jam
Recommend you call to service, cose so many problems You may only in detail and attentively examine the sensors of the passing the paper. May be the whole paper has jamed in on fuser, in stove. There is else of the reasons, can be are covered by dust.
Mar 14, 2010 | Canon Office Equipment & Supplies
PAPER JEM WHILE PRINTING. I NEED A HEIP TO REPAIR THE PRINTER.
first, if thare any paper is jamed in the paper tray, pull the paper stright out. take out the remaining paper. close the paper tray.
opne the front cover pull out the toner cartirdge, remove the jamed paper.
open the inner door (where the paper exit). make sure there is not paper jamed it.
close the front door. if any paper jamed inside of the machine, it should automatically eject it out.
Note: reset the printer by opening and closing the front door.
Apr 03, 2009 | Samsung ML-2510 Laser Printer
MF5750 All-In-One Laser Printer DOES NOT PRING indicate paper jam I check and there is no paper jamed in the printer. It starts as it will pull the paper to copy document and then indicates in the display...
It starts as it will pull the paper to copy document and then indicates in the display that the paper is jamed.
Can anyone explain what the problem my be?
Please assist me.
Jan 19, 2009 | Canon imageCLASS MF5750 All-In-One Laser...
Konica minolta
How about this, if you look what paper tray are avaible from the display pannel, is there a matching size paper tray or is the tray you are trying to use another size then lets say LTR. Is it a different size, if so you may have paper jamed behind the paper tray causing a different paper size, if so remove the jamed paper..... Also, the other suggestion are good as well.
Aug 06, 2008 | Konica Minolta DiALTA Di200 Copier
50 people viewed this question
k24674
jasbo
jasbo
