Question about Dishwashers
I have a leak coming form under my dishwasher,
I have a leak coming form under my dishwasher what should i do as far as repairing it?
  • Dishwashers Master
  • 43,501 Answers
Here is a tip that I wrote about leaking dishwashers...
There also is a link in there to another tip on how to buy parts online for your dishwasher...
Leaking Dishwasher
http://www.fixya.com/support/r4546178-leaking_dishwasher
heatman101
Posted on May 15, 2010
The door not locking
Remove top of dishwasher. Under the top fitted to the frame will be an adjustment to the locking mechanism. You may need to loosen this to enable the door to lock. Be warned though that you don't loosen it too far or your dishwasher will leak.
Nov 01, 2013 | Hotpoint 24 in. FDW60 Free-standing...
This dishwasher leaks in the front. Is there a fix I can do on this?
You need to determine if it is the door seal leaking or if the leak is coming from under the machine. If it is the door seal, it will need to be replaced. If the leak is elsewhere it will have to be repaired accordingly.
Jan 28, 2011 | Frigidaire FDB1100RHM Builtin Dishwasher
Water leaking from under the machine (Miele G638 Plus) dishwasher
The salt tank is a pathetic piece of ****. The plastic cracks and leaks into the bottom tray, which in turn sets off the safety switch.
Follow the attaching hoses and bypass the salt tank unless you really need it. This will save you around $250 for a salt tank and $300 labour for callout and repair.
Mar 23, 2009 | Miele 24 in. G638 Plus Free-standing...
Water leaking from top dishdrawer
This is very rare in any dishwasher. I use to repair most all dishwahers. First check your door seal for any cracks, cuts or splits. The water inside is under great pressure and can push out from the top of the door if that is is weak, flat, or has anykind of cut or crack. If the leak indeed is coming from the top then you will need to get someone to help you pull out unit and check top for cracks or splits. This entire housing is plastic and may have come with crack. If your washer has a hose at the top, then check it good. While its out from under the counter run it and watch to see if you can tell where leak is coming from. I may have missed something. Remember, always unplug this from wall outlet or turn off breaker if you are indeed moving it in or out. Good luck.
Mar 09, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Hotpoint HDA3230Z02WW Dishwasher leak
Hello ajs10172003
Welcome
You said, you have a leak under my dishwasher every time you run a load but can not tell where it is coming from. When you looked under the dishwasher it appeared to be leaking under a white cylinder shaped part. This is where the water was gathering at. Not sure what this is. Maybe someone can shed some light on this.
It is probably the SOLENOID that is leaking.
This opens and closes to control the water coming in and going out!
And it looks like cylinder as you described.
Time to replace that part if this is the case. An easy repair only a $40 part.
call service!
Let me know how it goes!
Huuum,
Please remember to leave a rating!
Oct 20, 2008 | Dishwashers
Maytag Quiet Series 200 Dishwasher Leaking Internally
two possible sources of water
either
inlet valve leaking. turn water off after use and if no water accumulates, then cause is leaking valve
or
if drain is plumbed in to a spigot on the sink trap, then every time you empty water from the sink, some of it goes down to the washer
cure by taking the drain hose up as far as possible under the sink in a swan neck
Oct 12, 2008 | Maytag Dishwashers
Maytag Quiet Series 300 Dishwasher leak
hi there,
the leak may be coming from the door gasket or the door vent.
can you provide me with the complete model # please?
Sep 21, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
Dishwasher leaking
You must remove all covers possible in order to watch the drip source using a flashlight. Once found, yes, the leak is fixable. All leaks are fixable...depends on cost of fix. A main pump seal repair/replace may be too expensive. Again, cost is the main factor. So find the leak, then get a repair estimate, if necessary...or get a screwdriver and tighten the hose clamp.
Jul 13, 2007 | Whirlpool 24 in. DP840SWP Free-standing...
Leaking dishwasher
when you state "there is water leaking out of the drain hose", then that leak must be fixed either by a new hose or to repair the hose. as far as the timer issue, i need more info.
May 25, 2007 | Maytag 24 in. PDC3600A Built-in Dishwasher
Hotpoint Ultima dishwasher DF32
you are probably plumbed in under the sink for the drain hose. a common problem is water coming back down the drain hose when you empty the sink. if so take the drain hose up as far as possible in a swan neck. other possibility is a leaking fill valve
Jan 26, 2007 | Hotpoint 24 in. DWF32P Free-standing...
Dishwashers Logo
67 people viewed this question
Top Dishwashers Experts
