Question about Pentax Optio E60 Digital Camera
When i turn it on it has 0x02110000 error messages and turns off
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Nov 22, 2010
Epson 092-651-0x02110000 error
Did you ever sort it cos I have the same error
Jan 16, 2014 | Epson Office Equipment & Supplies
Shows lens error 0x02110000
you kind of need to contact the company. they might have a kind of website or kind of phone help
Oct 12, 2010 | Pentax Optio E60 Digital Camera
When turned on, my VPC S1070 shows
This blog explains the problem you're having, and things you can try to fix it.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
They say about half the cameras can be fixed, trying their suggestions. Good luck, hope you're in the "fixed" half!
Jun 10, 2010 | Sanyo Vpc-s1070w Digital Camera
I turn on the camera and it saysprogram green mode for a while and then it shuts down saying lens error 0x02110000 although im not sure how many 0's there are on the end of the 0x0211
Dear Sir,
This is problem of the lens block.You are not able to solve this issue by your self.You must send thi camera into the local Pentax Service.
Best Regards
AIOS
Apr 18, 2010 | Pentax Optio E60 Digital Camera
Dear Sir,
You must send camera into the Pentax service.
Best Regards
AIOS
Mar 23, 2010 | Pentax Optio E60 Digital Camera
When you turn camera on it says lens error 0X02110000
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 16, 2010 | Pentax Optio E60 Digital Camera
Lens error 0x02110000
This is a common problem with with cameras with retractable zoom lens .
Heres a few thing you should try :
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. If you get another type of error message this may mean you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one). TO AVOID THIS PROBLEM AGAIN : Keep away from dust, dirt, grit, sand and any camera bag that has loose fibres (clean it before use).
If this helps you, please vote...thankyou and good luck!
Jul 28, 2009 | Pentax Optio E60 Digital Camera
When i try to open my camera it says lens error :0x02110000
This seems to happen when something (water, sand, dust) gets trapped in the lens mechanism. Has the camera been somewhere filthy before?
The recommended methods include taping on the bottom of the camera, rapping it on a table, and pressing hard on the lens. If the lens moves when you turn the camera on, try keeping your hand on it so that it's forced back into the camera body. A can of compressed air squirted around the lens is also a possible fix... but be super careful with that stuff, a good hard blow of breath might be safer.
I'm not recommending that you do crazy stuff to your camera, but if you're careful you may be able to get it working again without having to get it serviced.
Jul 06, 2009 | Sanyo Vpc-s1070w Digital Camera
Switch computer on and the light is red but on the screen it says system error contact xbox customer support
SYMPTOMS loadTOCNode(1, 'symptoms'); You receive the following error message in multiple languages: System Error. Contact Xbox Customer Support. CAUSE loadTOCNode(1, 'cause'); Typically, this error message is caused by a hardware failure. THINGS TO TRY loadTOCNode(1, 'whattotry'); Note If you receive an error message and see one flashing red light on the front of the console, see the following article in the Microsoft Knowledge Base: 907536 (http://support.microsoft.com/kb/907536/) Xbox 360: One red light flashes on the Ring of Light and you receive an error message 1. Turn off the console, disconnect and then reconnect all cables. Turn the console on again. 2. If an Xbox Hard Disk Drive is attached to the console, turn off the console, and then remove the Hard Disk.
For more information about how to remove the Hard Drive, click the following article number to view the article in the Microsoft Knowledge Base: 906204 (http://support.microsoft.com/kb/906204/) Xbox 360: How to attach or remove the Xbox 360 Hard Drive Turn on the console, and then test for the error message. If you do not receive the error message, turn off the console, and then reattach the Hard Disk. Alternate testing with the hard drive connected and removed to see whether the error message occurs only when the hard drive is attached. If the on-screen alpha-numeric error is E67 in the error message, see the following article in the Microsoft Knowledge Base: 917874 (http://support.microsoft.com/kb/917874/) Xbox 360: One red light flashes on the Ring of Light, and you receive error E67, E68, or E69 3. If an Xbox Memory Unit (MU) is plugged in to the console, turn off the console, and then remove the Memory Unit. Turn on the console again and test for the error message. If the error message does not reoccur, turn off the console, and then reinsert the MU. Alternate testing with the MU inserted and removed to see if the error message occurs only when the MU is inserted. 4. If you continue to experience this behavior, contact Xbox Customer Service.
Jul 17, 2008 | Video Game Consoles & Games
Pentax Optio E60 Digital Camera Logo
90 people viewed this question
Top Pentax Cameras Experts
mohamed salim shaikh
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
