Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
Bissell 1698 Powersteamer no spray
Steamer is not putting out any spray. I have checked the belts - they are fine. I have cleaned the fileters. The water tank seems to fit ok - although it doesn't seem to snap in solidily. No water comes out of the sprayer . I have tried to clean all holes and everything seems OK . It sometimes doesn't want to shampoo either. Is there anyway you can tell me whats wrong or what to do?
    President:
  • 1,673 Answers
A simple thing to check is make sure the round seal is on the bottom of the tank, it needs to be on the tank not sitting loose in then hole that the tank valve goes into. Could be a problem with the flow indictor cap leaking air. Is the top and the base tight together in the back, sometimes the plastic breaks loose and the top will rise enough that it raises the tank so water won't flow. Your pump may be bad.
Posted on Mar 30, 2008
Not spraying or picking up water
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
bmv,
Feb 02, 2010 | Bissell 1698 PowerSteamer ProHeat Upright...
Not letting water out of vacuum
If it is not pumping water out of the vacuum that means that the pump belt is worn. Here is a link to the belt you need and a manual you can view:
Bissell 1698 Belt and Manual
Nov 24, 2009 | Bissell 1698 PowerSteamer ProHeat Upright...
Bissell Power Steamer Proheat Plus not dispensing
heatman101
dfsghs
Jul 07, 2009 | Bissell 1698-1 PowerSteamer ProHeat Plus...
Forgot where to put water and solution lost manual
The water goes into the soft plastic bladder in front and the cleaning solution ges into the hard plastic in the back of the machine.
Feb 24, 2009 | Bissell 1698 PowerSteamer ProHeat Upright...
Bissell proheat 1698
heatman101
r43
Dec 19, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Bissell proheat 1698 cleaner not spraying water
MY CARPET CLEANER WAS NOT SPRAYING ANY WATER OR CLEANING SOLUTION. I TOOK THE BACK OFF OF THE HEATER THAT IS IN THE HANDLE. IT WAS CLOGGED WITH CALCIUM DEPOSITS. I CLEANED THE HEATER AND PUT IT BACK TOGETHER AND IT WORKS GREAT. KEN
Feb 25, 2007 | Bissell 1698 PowerSteamer ProHeat Upright...
If it seems like the tank does not fit in securely, the round gasket that goes around the valve at the bottom of the tank may have come off and actually be in the hole in the bottom of the vacuum base. It looks like it belongs there but you can pull it out with some needle nosed pliers. After you remove it, put it around the valve on the bottom of the tank, then it will fit into the hole again and everything should seal correctly. Mine was not spraying and would not suction well. figured this out and now it works great again.
Apr 16, 2006 | Bissell 1698 PowerSteamer ProHeat Upright...
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
174 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
