My clor looks to be
My color looks to be saturated with the blues and greens and i have tried to adjust them but its does not align. it is 51 inch rear projection hdtv ready tv model 51pw9303. I dont know if this has anything to do with the problem but we had little kids who shut the tv off and on a lot.
  • Frank Sumner Mar 31, 2008
    no it does it on all av hook ups
    Sergeant:
  • 395 Answers
Check the cables from your receiver or cable box. I am assuming you are using the Y, Pb,Pr component hook up. check the red wire, (Pr), as it may be disconected or bad.
Posted on Mar 30, 2008
  • Robert Johnson Apr 01, 2008
    if that be the case then the red CRT is bad or the IC on the red CRT board is bad. sometimes the focus block can cause this problem. have a tech check these things
My 65 inch sony tv half the screen is having colors like 3 d
Your Convergence ICs have failed. It is very common on rear projections. The solution is to replace the STK chips, check fuses and the resistors next to the STK chips. Replace as necessary and re-align via the service menu. It is about a $300 repair at a tv service center. You will need the service manual if you decide to do this yourself.
Try This:
When you notice the symptons Use this simple test to verify.
Go to the users menu on the tv.
Look for the converge option probably under setup or video setting. Converge is short for convergence to align the red and blue colors to the green color.
If you cannot move the red either horizontal or vertical, then the STK chip has failed for red section.
If you cannot move the blue either horizontal or vertical, then the STK chip has failed for the blue section.
If you can move both in each direction then the problem is something else.
Note if one STK chip fails, you replace both regardless.
Feb 20, 2011 | Sony KP-51HW40 51" Rear Projection...
51 inch projection- can't read words clearly,
ll projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 14, 2011 | Hitachi 51F500 51" Rear Projection...
We own the PT51HX41 51 inch rear proj. We are getting a green and red glow around all pictures and wording. Are the bulbs gone or do they need to be adjusted...
The tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors.These parts on the tv convergence board are dead,must be replaced on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 05, 2010 | Panasonic PT-51HX41 51" Rear Projection...
Sony KP-51WS520 51" Rear Projection Colors have been over saturated for awhile...selecting vivid seemed to help. But now I am getting a ghosting effect on most words, always to the right.If I go to...
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 09, 2010 | Sony KP-51WS520 51" Rear Projection...
My sony dlp tv looks like 3d. the three sprectrum
This is convergence bord problem and you need to replace the STKs and check all resistors around the two stks and replace the faulty ones. If you are not too confident, its better to seek professional help. some indication of costs are available on www.fixurtvs.com. You can download service manual from fixya site tech support and decide what you want.
Mar 22, 2010 | Sony KP-51HW40 51" Rear Projection...
Red green lines across my screen on 51 inch tv hdtv
If you cannot align those crosses, then the convergence section is damaged. should be repaired by a qualified technician, its a big job.
Jul 20, 2009 | Philips 51PW9363 51" Rear Projection...
Red and Blue slightly out of alignment
If constant all over the screen it is the static convergence that needs adjusting.
The green is not adjustable!
Move the red magnets with the blue covered with a piece of card to align with the green and then move the blue with the red covered to align with the green.
May 13, 2017 | Panasonic PT-51G41 51 in. Rear Projection...
G2 alignments?
Hello YankeeTwidgt,
Here we go you will need a schematic diagram (You may already have one but I thought I would mention it ), an oscilloscope, a TV signal generator (NTSC color bar, RGB purity screens, and pattern screen), and a voltmeter (I would prefer you have a VTVM, but a digital meter with high impedance (>=10M) will be ok).
First turn all of the color and tint controls completely down (This includes the main color and tint and the pre-amp color controls if you have access to them).
Then turn the RGB pots fully counterclockwise.
Once this is done connect the signal generator set to channel 3, and set to the specifications on the schematic, use the color bars, what you should see at this point are bars of various shades of gray.
Then turn the generator to the purity setting and set the pattern to red.
Once this is done your screen should be dark or dark red, gradually adjust the R pot until the screen is pure red and the voltages, and signals match what is seen in the schematic (mark this point on the pot and the return the pot to fully counterclockwise).
Do the same for the Blue and Green Controls (Blue first and then Green).
Once all of the pots are marked and turned to counterclockwise, set the pattern to gray purity, and turn the pots back up to their marked positions, the screen should be gray. switch to color bars and the screen should have the proper colors.
This is a course adjustment, and you will have to do a fine adjustment using the schematic, and the test tools, but this will put you way into the ball park.
The reason these pots are not talked about in gray scale adjustments is because they usually don't have to be touched. That's why it is important to get them back to specification using the voltmeter and oscilloscope to set the signals up properly.
I wish you success,
Shuttle83
Jul 27, 2008 | Philips 51PW9303 51" Rear Projection...
Sony kp51hw40
did you adjust the green screen control .
Oct 01, 2007 | Sony KP-51HW40 51" Rear Projection...
Televison & Video Logo
79 people viewed this question
Top Televison & Video Experts
