Question about Heavy Machinery
Who makes craftsman wood chippers model 987797810
boscia
  • 163 Answers
SOURCE: Craftsman Chipper-Shredder Model No. 247.775870
If a small engine wont start its usually one of two problems, its not getting gas, or its not getting spark. easy way to find out if its getting a spark is to remove the plug, put it back back in the connector and just let it hang down while you try to start it. you should see a bright blue spark, if you dont try changing the spark plug. if its getting a spark come back on this site and i'll help you trouble shoot it.
Posted on Nov 30, 2008
  • 83 Answers
SOURCE: my chipper is throwing long chunks of unchiped
Either your blades are dull or the gap between the intake tray by the blades is too far or is rounded off. Many chippers have a plate on the intake by the blades that can be flipped around when it rounds off. Also some have a edge on the other side of the blade so it can be reversed and give you a fresh edge. Be sure to unplug the sparkplugs and remove the key when going into your chipper to ensure no one can start it when your in it. There is usually a lock bar to keep the blades from moving.
Posted on Mar 31, 2009
  • 3 Answers
SOURCE: looking for manual for troy-Bilt super tomahawk wood chipper
I have the both the manual and parts catalog for Troy-Built 8hp Tomahawk, can send them to you for the cost of coping and postage if you haven't found them yet.
Ron Bowman, PGYBCK@AOL.COM
Posted on May 02, 2009
mowerman1857
  • 389 Answers
SOURCE: how to change oil to craftsman chipper 24779594
You can download a PDF manual for your chipper at ( www3.sears.com ) Type your model number like this ( 247.795940 ) It will show you a parts list for it and also there will be a place that says "Manuals" click on that and it will download to your computer where you can eithewr save it or print it out or both
Posted on Sep 16, 2009
mowerman1857
  • 389 Answers
SOURCE: How to remove impeller assembly from chipper
You can download a PDF2.gif manual for your chipper at ( www3.sears.com ) Type your model number like this ( 247.795890 ) It will show you a parts list for it and also there will be a place that says "Manuals" click on that and it will download to your computer2.gif where you can either save it or print it out or both
I came across this wood chipper today i would like to figure out how old it is. is there a way to figure it out from the serial #3486583
Philip Google search your wood chipper,make and model# and it may come up with info. on the manufacturing date.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Apr 06, 2016 | Heavy Machinery
I have a 5hp craftsman chipper model 247.795850, I am not ab;le to keep it running; it will start with starter fluid but when fluid burns off chipper stops. I put a new plug and air filters as well as...
Your problem is the carburetor, it needs cleaned (at a minimum), but you may have to give it a rebuild. Make sure that you clean all the littlee holes and passages.
Jun 02, 2011 | Craftsman Heavy Machinery
What year is my wood chipper? I purchased a Craftsman 8hp wood chipper-shredder that is silver-gray in color and all metal in construction with a Briggs & Stratton 8hp motor. The B&S motor is...
The B & S Code is the date of Mfg. This engine was built in 1994 (first two digits rep. the year), Sept.( the next two digits rep. the month) and the second day of that month. Your engine was built on Sept.2,1994. Your chipper may be one year newer as the engine had to be installed after the date of mfg. Your welcome
From North Carolina
May 17, 2011 | Heavy Machinery
My Father in Law passed away and I am trying to get his Craftsman 5hp wood chipper running so that my Mother in Law can sell it. It has electric start. I assume with electric start there must be a battery...
You can visit the Craftsman website to get this info. You will need your Model Number and Serial number to download an owners manual. The manual should show you where the battery is.
Apr 19, 2010 | Heavy Machinery
Who makes craftsman wood chippers, model 987797810
Craftsman stuff is made by various manufacturers. The craftsmans or Sears model # is usually preceeded by three numbers and a period. These 3 numbers indicate the manufacturer. A list is available on the Web. Do a google search for Sears code numbers or craftsman code numbers and you'll find the lists.
Mar 23, 2010 | Garden
I need a gas tank for a Craftsman 242-27006 shredder-chipper
go to http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears type in your model look through the pictures and you should be able to find the part number and sears can order it for you.
Feb 22, 2010 | PDP Systems 1.5 Horsepower Electric Wood...
Removing flywheel from chipper-shredder model number 247-775870
REMOVE THE FLYWHEEL NUT, CHECK FOR BURRS ON THE CRANKSHAFT, REINSTALL NUT LEAVING 1 OR 2 THREADS EXPOSED, APPLY UPWARD PRESSURE ON FLYWHEEL WITH SMALL PRYBAR BEIGN CAREFULL NOT TO DAMAGE ENGINE, GENTLY TAP THE END OF THE CRANK WITH A SOFT BRASS MALLET OR BLOCK OF WOOD
Nov 18, 2009 | Craftsman Gas Mini - Tiller/Edger
Looking for manual for craftsman chipper
The manual can be found HERE.
On the left side of the page, under "Browse Subcomponents" you can use your RIGHT mouse button to open each page in a seperate window. This reduces the use of your BACK button, and personally, I find it more convenient.
Hope this helps.
Dolf-
Oct 10, 2009 | Troy-Bilt Chipper Shredder
Need a leaf bag for a chipper/shredder/vac
That is actually a good price. MTD wants $225.00
Oct 04, 2009 | Craftsman 4 Cycle Blower/Vac
Wood Chipper how to
Great input tina783. I have just one thing to add. Try to shred the branches within a reasonable amount of time. I found out that with my shredder, if I put older, dried up branches in, it tends to take a lot more time, as well as tosses chips back out at you. With newly cut branches, this wasn't nearly as much as an issue.
Aug 27, 2008 | AMANA TOOL 658060 PRESTIGE FINE DADO SET...
Heavy Machinery Logo
164 people viewed this question
Top Heavy Machinery Experts
Bill Boyd
Daryl Gleaton
Tom Chichester
Are you a Heavy Machinery Expert? Answer questions, earn points and help others
