Question about Onkyo TX-SV535 Receiver
When you turn the power on it just constantly turns on and off
If you find a solution email me at gotzmines21@aol.com I have the same exact problem and can't get an answer
Posted on Nov 26, 2011
That's great, mine started doing this today! looks like i might get something from santa this year!
Posted on Dec 03, 2011
Head unit not getting the right constant power
normally when an aftermarket stereo is installed the yellow wire is for constant power gets connected with the ignition power wire and what you said is what happens in result. get a multimeter, set it onto dc volts and put the black lead onto something metal and then id use the red lead to test wires for a constant 12volts when key is in the off position. Once a wire is found connect it to the yellow wire of the stereo
Feb 19, 2013 | 1999 Acura Integra
I want to switch the power on my car cd player away from the starter, so that i have to turn it on and off myself, rather than when i turn the key. how??
Surely you mean that your cd player is connected to the accessory power and not the starter. If you want your cd player to receive constant power then locate the accessory power wire of the cd player(the one that receives power when the key is on) and connect it to a FUSED constant power source(battery). Usually, if it's a three wire hookup it will be yellow, red and black. Yellow (constant power), red (switched power) and black is ground. If this is the hook up then the red needs constant power. If it's a two wire hook up, red (switched) and black(ground), then the red needs constant power.
Jan 14, 2011 | Car Audio & Video
When I turn on My RCA L40fhd41 40" television, the LCD screen constantly blinks on and off like a strobe light. The power light stays on constantly, but the screen continues to blink
Dec 12, 2010 | RCA L40FHD41 40. in HDTV
How do i stop my jvc stereo from resetting, because every time i turn off my car every thing gets reset
There is a constant power wire and a switched power wire. The constant must be hooked up to a constant power (one that doesn't lose power when the car is off). Either the YELLOW or RED wire will be the 'constant on'. Or you can hook that one directly to the battery. The other power wire from the deck should be hooked up to the switched power (or plugged in with a fuse that turns on with the car). Voltometer is your friend here.
Jul 29, 2010 | Car Audio & Video
I just washed the electrostatic grid and didnt have it thougholy dryed before inserting it back into the unit. Now I cant get the power light to turn on
As long as you have the cells in the correct direction, the air flow direction you should be O.K. If you have a way of turning on a constant fan that will help dry them. I would shut the power button off to the electric air cleaner and run a constant fan for 24 hours. After that, turn the power on and the constant fan off. Turn up the heat and see if it works.
Nov 24, 2009 | Air Purifiers
PC will not turn on blinking green light on power supply
The green light on power is blinking, it means power supply working in main power and the main supply not constant that time after constant the green light, then turn on the PC.
Thanks
Aug 13, 2009 | Intel SR1350-E Server Chassis...
Amp neon lights wont turn off
There are two types of power that feed your amplifier. There is a constant power that connects directly to the battery and there's a remote power that usually connects to the remote power output of your deck. Some decks do not have the remote power output, but they have a power antenna output that works just as well.
The remote power is what enables the amplifier to turn off when the car's power turns off.
Either way, it sounds like you have the remote power input on the amp connected to your constant power source.
That would prevent the light from turning off with the car.
If you don't have a remote power or power antenna output on your deck, I would invest in a new one.
However, it is relatively easy to find a remote and a constant power source in your fuse box.
Purchase a fuse tap for a few cents and connect the remote power input on the amp to a power source in the fuse box that turns on and off with the ignition.
Some of the power sources you can find in your fuse box that go on and off with the ignition may be labeled something similar to the following:
ignition, power windows, radio, accessory, etc.
The constant power sources in your fuse box are the ones that don't power off with the car, such as the dome/interior light, power locks, battery, etc.
I hope that some of this helps out a little.
Dec 04, 2008 | Car Audio & Video
Turn signals dont work and no constant power to stereo
check these fuses radio/interior lights
Radio backup (if applicable)
Ignition
Nov 25, 2008 | 1999 Honda Accord
Won't turn off or on automatically
You must have the yellow and the red wires tied together on a constant voltage source.
Only the yellow wire should be on a constant voltage source.
The red wire should only get voltage when the ignition is turned on or in the acc. position.
You need to rewire the red wire on the radio.
Let me know if it helps.
Jun 07, 2008 | Kenwood KDC-MP4028 CD Player
Don't keep memeory
Hi... your stereo has 2 power wires. Typically One is yellow and the other is red. Both should have power with the key on. Only one should have power with the key off.. the most common causes for what you are describing are either no constant power to the radio on one of the wires or you have the red and yelow wires switched around... -ampman
Aug 29, 2007 | Panasonic CQ-C7301U CD Player
117 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
