Can't wake up Micron Laptop
I have an older Micron Trans port Trek 2 laptop. I try to boot it up and when I push the on button, all I get it a half moon (sleep?) indicator light that blinks. How do I wake it up?
Comment by RangerRick, posted on Mar 30, 2008 Been there, done that! It doesn't do a thing, except blink the half moon symbol at me again. Any other ideas? ******** The screen isn't coming on. No windows, no picture, no lights, nothing but the blinking half moon on the top of the keyboard. Still need a solution for this problem?
YES****
s4u311
Rank: Wiz
Rating: 80%, 51 votes
u have press power on button again the ur pc will be on again
thnx to using fix ya
  • RangerRick Mar 31, 2008
    I figured it out. The laptop had been stored in a closet for about a year. I took the battery out and it showed completely charged. I unplugged the A/C adapter and after putting the battery back in, I tried the power button again and again. Finally some other start up lights on the key board flashed and I heard a sound. I tried rebooting it several times and now it's working fine. Thanks for your assistance.
  • 813 Answers
Can u try what i gudie before
Posted on Mar 31, 2008
Laptop will not wake up from hibernation
ok try this
turn off computer
press power button with battery and adapter removed for 2 min should clear the power settings
plug in adapter only(no battery)
turn on computer see if it's happier
if so, then install battery and restart
May 22, 2012 | ASUS K52F-BBR5 Notebook
The laptop was working fine earlier in the day; I sat down at it and the power button was flashing. I ran my hand across the mouse pad to wake it up and it would not come on, so I pushed the power button...
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Thank you for using Fixya...
Sep 25, 2011 | HEWLETT-PACKARD G72260US Notebook
Laptop gone to sleep and won't wake up. Went to shut Easy note down. It took all day then when discovered this pushed button to turn it off now it has power but won't operate.
Try following method to get rid of Black screen problem.
1) TAKE OUT YOUR LAPTOP BATTERY
2) REMOVE YOUR AC ADAPTOR CORD, that's the wall power, remove it.
3) NOW HOLD DOWN THE POWER BUTTON FOR 30 SECONDS.
Mar 15, 2011 | Intel EasyNote E4 715 Notebook
I HAVE A MICRON Trans Port TREK 2 model no. NBKU376. when i first got it it had windows 98 well ive installed xp on plenty other computers before, and have the factory os disk. so of coarse i wonted to...
look bro,
ur windows Xp is not installed properly..
Try to reinstall it i.e. from the boot via Cd stuff..
when u do so, like reformattin, u'll definitely be asked to format the partition in ntfs or fat32..
Select fat32 & then try to continue...
this should work..
if u liked my post & if it worked, please vote me i really need some good ratings thanks..
Nov 28, 2009 | Computers & Internet
Micron Trek 2 laptop won't start on battery or AC (NBKU375)
The lightning bolt is used to indicate an electrical problem but then, you know that already :-( Try removing the battery pack and start it from AC only; some battery types don't like to be ignored, they can have individual shorted cells.
Sep 30, 2009 | Computers & Internet
Dell Inspiron 8200 Won't Boot up. Not even to BIOS.
Latitudes sometimes have a problem with RAM. Try these things to get it to boot...
1. Remove the RAM modules, clean the contacts with a pencil eraser, reseat modules and test.
2. If two modules, remove one and test. Place same module in second slot and test.
db
Mar 24, 2009 | Dell Inspiron 8200 Latitude C840 Laptop...
Sleep Mode
Mar 30, 2008 | Computers & Internet
Restore windows in my l;aptop
I belive the restore is f10. hit it at start up.
Feb 15, 2008 | HP Pavilion dv6000z Notebook
Micron Transport Trek 2 mod#NBKU370, ser# 1392070-00311
I think it means that either the hard drive has failed, or that it is not detecting it. try downloading a program called Bart PE Run this disk in the CD Drive on startup. then find the option called command prompt. then type in the following as follows:
chkdsk C:/r
after this finishes, shutdown, remove the disc, and see if the laptop will boot now.
Feb 05, 2008 | Computers & Internet
Computers & Internet Logo
415 people viewed this question
David Payne
David Payne
