Question about Kenmore Elite 45986 Front Load Washer
Kenmore Elite washing machine
HF error code, door will not open
  • tdelmore Apr 14, 2008
    I have the same problem. What ever happended to yours?
  • Anonymous Mar 28, 2014
    Error code 21
This code means its not getting a sufficient water supply. I was doing a cold wash and noticed it was sucking down some hot water, so shut off the hot. MISTAKE, after a little bit the HF code came up. Apprently it likes to decide for itself just how cold is cold. Darned Computers.
To make a short story long, when I shut off the hot, it apparently shredded the washer and sent the remnants down to the little filter thingy at the washer itself, whereupon they reassembled themselves into a clog, once again giving me the HF code.
(Check your user manual Troubleshooting section. I think it says to press Pause/Cancel twice)
Posted on May 01, 2008
SOURCE:
Both the coupler and the lid switch have been replaced yet unless you lift and close the lid it won't engage the spin cycle
Search Results
    Why am I getting an FL error code on a Kenmore Calypso ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kenmore Calypso washer model 11022062100 and there is water in ... Why am I getting an FL error code on a Kenmore Calypso washing Machine?
    fl error code on calypso washer-need help!! - Home Forumsths.gardenweb.com > Home Forums > Laundry RoomJul 22, 2006 - An FL error code keeps flashing on my Calypso Washing Machine. I can't do laundry. Could someone please tell me what I need to do to ..."F dl" light come on - Kenmore Elite HE3 Washing Machinehttps://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock Error... The Kenmore Elite HE3 is a washing machine by Kenmore. ... On Amazon I was able to get the CCU (Kenmore CCU Central Control Unit .... and a dose of WD40 on those contacts should keep that from misbehaving in the future as well.Kenmore Elite Calypso FL error code - ApplianceBlog
Jan 27, 2016 | Washing Machines
Kenmore elite smart wash quiet pak hf code
i think the hf means heater fault,,,,,,,,,,,,or the thermostat
Jan 27, 2015 | Kenmore Washing Machines
Kenmore Elite hf error
May I have the complete model number, so we can get started?
Feb 03, 2014 | Kenmore Washing Machines
Du error code on a kenmore elite oasis he what does it mean and what can i di to fix the problem
Door unlock failure
Excessive force on door lid is preventing lock bolt from
retracting.
Wash media buildup is preventing lock bolt from retracting.
Machine/motor control cannot determine if door lid is in an
unlocked state. See TEST #8, page 14
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 11, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
In the elite kenmore smartwash quietpack 9 HE 4t - what does error code HF mean?
If you still know where the brochure is I would look in the chapter "troubleshooting"
If the brochure is not where it should be, I would "google" the brand name and the no of the appliance More likly than not you will find the answer there. This method has helped me very often.
May 15, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3t
Here's a link that explains the "FH" error code:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
Read through these steps and let me know if you require further assistance. HINT: I'm assuming you have water entering the wash tub since you mentioned the washer will begin a wash cycle. Check for a siphoning issue or Drain Pump problem first. These are the simplest items to check. I hope this helps you.
PS There should be a tech sheet located inside you washer behind the lower panel under the door, or along the interior cabinet wall that explains all the error codes and how to troubleshoot. This may also assist you further.
Jul 24, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite HE3 Error Code
Here's a link that explains the "FH" error:
If you have questions about the information I provided, or need further assistance in trying to determine the source of your problem, please post back and let me know. I hope this helps provide an answer for you.
Jul 11, 2008 | Kenmore Elite 45986 Front Load Washer
F 11 Error Code
The door will stay locked if the machine did not drain properly. Try running a Drain & Spin cycle.
Mar 17, 2008 | Kenmore Elite 45986 Front Load Washer
My kenmore elite smartwash/he4t (error code)
Try shutting off the machine. Switch off Usually the door opens in 2 minutes or so. Do not force open the door. There may be instructions in your book to open the door manually. It could mean unscrewing somewhere.
Apr 04, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
1,970 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
