Question about Dell Dimension E310 PC Desktop
Hi. I have a dell e310...and the desk top turns on but the monitor will not display anything...it has an amber light..sometimes.it will turn to green but then shuts off again Could this be a bad video card?
  • IQUIT May 15, 2010
    Diagnostic indications are here:http://www.fixya.com/support/r4282412-fi... Solid Amber Power LED on the tower generally indicates a failed motherboard or component connected to the motherboard. SO video card is a possibility
  • 66 Answers
Depends . either the video card or motherboard see if the blue video connector is at the top or twords the bottom of the case and that will tell you if it's a card or integrated on the board.
Posted on May 15, 2010
2 Suggested Answers
  • 35 Answers
SOURCE: hi. I have a dell e310...and the desk top turns
That's a possibility, but have you tried checking that everything is connected behind the stack? I wouldn't go into major surgery on your computer until you rule out all the simple ideas. It could just be the monitor too.
Posted on Mar 23, 2010
I can't get my desk top to connect to internet it tells me my ip address is not right but my lap top goes through my desk top and i don't have any problems getting on line.
your dell needs a network adapter card or wireless card installed is that the case(look in b ack)
if no wireless, then it needs an ethernet cable plugged into modem/router from cin bell and then in back of dell
please advise your network configuration
May 28, 2012 | Dell Dimension E310 PC Desktop
My desk top icons are upside down
Hi rsimuchoba...
To reverse the upside down screen mode , press contro,l alt, and the up arrow at the same time; the screen will probably go blank. Turn off the monitor, turn it on again and the display will be normal again.
Please take time to rate me
Aug 22, 2011 | Dell Dimension 9200 PC Desktop
Hi. I have a dell e310...and the desk top turns on but the monitor will not display anything...it has an amber light..sometimes.it will turn to green but then shuts off again Could this be a bad video...
Mar 22, 2010 | Dell Dimension E310 PC Desktop
Dell dimension e310 desk top will not power on
If the POWER Button on the TOWER is blinking AMBER (Yellow) then the most likely failure point is the POWER SUPPLY in the Tower.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817226001
Dec 21, 2009 | Dell Dimension E310 PC Desktop
Are Dell monitors not compatible with older HP Pavilion Computer? I tried to connect my HP CPU to a Dell monitor and it will not recognize it at all.
It shouldn't make any difference which monitor you are connecting to any computer. In fact, I am running a 19" HP Flat Panel on my Dell Dimension 2400 right now. It is NOT a wide screen monitor as the Dell built in graphics card will not support the RESOLUTION RATIO required for the wide screen. Check what setting is "native resolution" for your monitor and see if your graphics card will support it. If not, using your old monitor, try different resolution settings. Right click on your desk top, click on properties and that should bring up the display properties box. Try a lower setting as larger settings are the ones that will give you a black screen. It will probably give you a smaller picture on your old monitor, or perhaps smaller or larger icons on the desk top. Accept the new settings, turn off your computer and switch monitors, and turn your computer back on. If you get a picture, but it does not fill the whole screen or the icons seem too large or small, then go back into properties from the desktop and try a different resolution ratio until the picture seems correct.
Jul 18, 2009 | Dell Computers & Internet
Monitor Will not come on
bad capacitors inside the monitor they need to be replaced, or if the power light is blinking then there are transistors that need replacement
Mar 22, 2009 | Dell E198FP LCD Monitor
Dell dimension E310 wont boot
Go in bios and change the SATA mode to IDE or compaitibilty then check whether it is working or not
Feb 17, 2009 | Dell Dimension E310 PC Desktop
No showing the full screen. Top + bottom 1 and half inches dark
your system display settings are set to a wide screen setting on desk top right click then properties, right had tab display then set the screen size to a square shape like 1024 x 768.
Feb 16, 2009 | Dell E153FP 15" LCD Monitor
Dimension E310
Im not sure if you are asking for the E310 drivers or the 4600c drivers, so I'm sending you the link to download drivers for both the systems.
http://tinyurl.com/2jpgqs (Thats for E310)
http://tinyurl.com/5jzwtd (Thats for 4600c)
All the best fixing your system
Mandeep
Jun 15, 2008 | Dell Dimension 4600 PC Desktop
Dell Dimension E310 PC Desktop Logo
173 people viewed this question
Alun Cox
