Question about Dacor DCM24 Convection/Microwave Oven
When I shut door, the light stays on and it
When I shut door the light stays on and it rotates but no microwave activity. Even hitting the Stop button will not stop the rotation and the light. I cannot get it to work in Convection mode either.
  • Dacor Master
  • 9,085 Answers
I would suspect that the door sensing switch (top door switch) is open inside or is disconnected. This will cause it to seem like the door is open, but it will not cook.
It may also have an intermittently bad secondary interlock switch (bottom switch). If this were the case, it would not microwave or cook in convection mode, but the turntable would fail to operate, too.
We have the applicable service manuals for this models and have uploaded them to our site here and here to help you.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you need other parts, you can order them by the part number in the service manual from this supplier.
Posted on May 16, 2010
Sharp R-530ES microwave oven stopped working
You have a bad secondary interlock (lower door switch) or its mount is damaged or out of alignment.
We have the service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
Dec 28, 2008 | Sharp R-530ES Microwave Oven
Shart Microwave model R-1514 fails to start. Beep is heard when start button touched but internal fan or microwave does not start. All other buttons such as fan, light ect work.
Your bottom door switch or its mount is bad.
We have the R1500 series service manual and have uploaded it to our site here to help you.
You will need the
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you only need a switch, you can order a universal type from us for $5 postpaid.
Nov 22, 2008 | Microwave Ovens
Oven makes operating noise when doo is closed without starting
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
The best place to order Sharp parts is Tritronics. You can call them at 866-779-5835.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Nov 21, 2008 | Sharp R-1480 Microwave Oven
Zmb30cst light problem
This is usually caused by either a bad door switch or a loose door switch mount.
http://www.microwavedisplay.com/doorsw.txt
Oct 22, 2008 | Zanussi ZMB30CST Convection Microwave Oven
Sharp R-1450 microwave
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
On these, it's usually a broken tab on the upper switch holder.
That sounds like what's happening when you hold the Start pad - maybe you're moving the frame and chassis enough to help it work.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
William E. Miller
prototech@usa.net
Aug 19, 2008 | Microwave Ovens
Microwave oven, ge profile model #pvm1870 the light stays on when the door is closed. microwave makes a noise while the light stays on. slight pressure to the door turns the light off.
This is usually caused by either a bad door switch, a loose door switch mount, or bad door hinge alignment.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. Other times, it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 17, 2008 | GE Microwave Ovens
Sorry my English, but can u help me?
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally by a problem on the control panel.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 06, 2008 | Maytag MMV1153A Microwave Oven
No heat or turntable motion
There are plastic mounts inside the microwave which hold the door switches and onto which the door hooks latch when you close the door.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383 or here.
Jun 01, 2008 | Sharp R-403HW Microwave Oven
Microwave Oven Problem
Quite often this is due to a bad door switch. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure. It's probably not actually heating with the door open, but better safe than sorry! If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your full model number (without the suffix) here: http://tinyurl.com/gv383
Apr 10, 2007 | GE JEM25 Microwave Oven
Smasung MW7490w door/turntable problem
It's probably a defective door switch, probably the upper one, or the mount which holds the switch is broken. Opening the door while cooking (without first hitting the STOP button) is the primary cause of door switch failure. There are plastic mounts inside the microwave which hold the door switches and onto which the door hooks latch when you close the door. The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly. Usually it's not a loose screw, but instead a broken tab on the switch holder, allowing the switch to rotate just out of position.
Sep 23, 2006 | Samsung SMH7159 Microwave Oven
Dacor DCM24 Convection/Microwave Oven Logo
125 people viewed this question
Top Dacor Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Steven Clarke
Steven Clarke
Are you a Dacor Microwave Oven Expert? Answer questions, earn points and help others
