Question about Toshiba Satellite A105 Notebook
Battery meters at 12.5 volts but won't run laptop when ac removed
I have two PA3451U-1BRS Li-ion batteries that won't run my Toshiba Satellite A105-S2001 laptop when ac power is removed. Power meter says both batteries are dead but one battery meters at 12.5 volts and the other at 11.5 (yes I opened the cases). When one battery is installed with ac power on the charging light (amber) is on and never goes out. With the other battery installed the charging light never comes on.
    Problem Solver:
  • 16 Answers
Pls try this: Toshiba Satellite A105
Posted on Jun 25, 2010
2 Suggested Answers
MOROO007
  • 180 Answers
SOURCE: battery meters at 12.5 volts but won't run laptop when ac removed
u have aproplem in second one
Posted on Apr 21, 2010
Tip
How to charge your new replacement battery
When charging the Toshiba satellite l200 battery for the first time your device may indicate that charging is complete after just 10 minutes or 15. This is a normal phenomenon with rechargeable batteries. Simply remove the battery from the computer and repeat the charging procedure.
Not to do so may significantly shorten the life of the Battery Sony vgp-bps9a/b (This does not apply to Li-ion batteries, which do not require conditioning). To discharge, simply run your unit under the power of the Battery Toshiba pa3399u 2brs until it stops or until you get a warning Battery low. Then recharge the Battery as indicated in your owner's manual.
If the laptop Battery will not be used for a month or more, it is recommended that it be removed from theunit and stored in a cool, dry and clean.
It is normal for a Battery become hot during loading and unloading. A Compaq Presario V2000 battery Authority will eventually lose its charge if unused. It may therefore be necessary to recharge the Battery after a storage period.
The milliamp-hour (mAh) rating of Notebook Battery dot org is often higher than your Battery of origin. An index above Mah is indicative of a longer duration (more capacity) of the Pavilion DV9000 battery and will not cause any incompatibilities. A Battery Laptop Battery dot org, in most cases better than the original 30% to 50%.
How the pa3451u 1brs Battery in real time depends on the power demand made by the equipment. In the case of laptops, the use of the screen, the disk drive and other devices results in an additional drain on the Battery, Effectively managed by reducing the BatteryTime. The total running time of ThinkPad x30 battery is also heavily dependent on equipment design. To ensure maximum performance of the laptop battery, optimize power devices on your computer management. Refer to your computer manual for further instructions.
on Oct 11, 2010 | Computers & Internet
DVD drive won't open on my Toshiba Satellite U305 S7467
Insert a striaghtned paper clip in the tiny manual eject hole.
Dec 29, 2012 | Amstron Toshiba Satellite U305-S7467...
Clear cmos toshiba satellite
remove the cmos battery remove all power like battery ac power supply hole the power button on the laptop for a least 1 minute replace the cmos /laptop battery and ac this should clear cmos BUT DO NOT ATTEMED THIS IF YOURSELFT IF YOU DO NOT KNOW HOW TO STRIP A LAPTOP
Dec 26, 2012 | Amstron Toshiba Satellite U305-S5097...
IT CAN NOT BE CHARGED OVER 70 %
Some batteries have a reset button on them. If it doesn't then the battery needs replacing. Most only are good for a couple years then stop charging properly, if at all.
Aug 09, 2011 | Toshiba Battery (A105BATTERYBT9C) for...
I have a Toshiba L35 Satellite S2174. I lost my power adaptor so started to use a HP adaptor of same 19 V , but Different Current 3.16A. I dont have the current rating of my original charger. The...
Hi Arsalan
To answer your question Its "yes". wrong power/ampere rating can shorten the battery life. I recommend that once you replace the battery include the AC adapter.Thanks
Feb 20, 2011 | Toshiba Satellite L35-S2174...
Battery replacement
What is it excactly you want out of your battery, three hours is outstandind battery time. Most last little more than half that. You're not going to find any that will last much if any longer, especially from an after market manufacturer.
Jun 12, 2008 | Toshiba Satellite M45-S265 Notebook
Upgrading RAM and Batteries
For batteries, my advice would be to stick with the brand of the unit (Toshiba, in this case). Toshiba lists a 12 cell battery on their website under the "laptop accessories" section of www.toshiba.com. For the A60, the part number is listed as PA3382U-1BRS and costs $152.99. You can search google for another place to buy (perhaps where you bought the laptop) but be careful that you don't get a generic in place of the original (OEM). With memory, Kingston and PNY are the aftermarket leaders and you can't go wrong with either. Kingston's website lists a whole slew of specific A60 models. Some with 256MB on board (not removable) and some with 512MB on board. So, a 512MB chip may give you 768MB or 1024MB depending on the exact model. Max memory seems to be either 1.25GB or 1.5GB depending on how much is onboard (and not removable). Installation is usually easy on any laptop and typically requires only a small screw driver to remove the memory cover on the bottom. The owners manual for the laptop likely gives the steps to add memory.
Sep 02, 2007 | Toshiba Satellite A60 Notebook
Toshiba Satellite A105 Notebook Logo
142 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
