Question about Dishwashers
Pump runs but will not drain the water - Dishwashers
  • Dishwashers Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your problem...
Dishwasherpump runs but will not drain the water - 2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Posted on May 15, 2010
Washer spins but doesn't get the water out
hi Ruth.
Washing Machine Won't Drain Water Last updated on November 7th, 2017
If your washing machine won't drain water out this article gives advice on how to fix it. If the washing machine has only just been plumbed in and it won't empty then check this article first - you might not need to drain or pull the washier out - won't drain after being moved or plumbed in. Otherwise, before trying to repair it you need to manually drain out the water that's stuck inside.
If your washing machine is stuck full of water because it's gone dead, or won't drain after being connected to a different u-bend you need to read the appropriate paragraphs in the how to drain washing machine link above before doing anything else.
What are the main causes of not draining? If the washer appears to be functioning normally but simply won't pump away the water these are the most common causes -
  • A blockage somewhere
  • Something jammed in the pump
  • Pump failure
  • An electrical fault
Is the water pump running - or not? On the spin cycle, is the pump running but water isn't being pumped out? If yes read on. There are two places to check for blockages. If the pump isn't running then jump to - If the pump isn't running.
Is the pump making a loud grinding noise?
If the pump is making a loud grinding noise, either constantly or intermittently, there is likely to be something inside being tossed around by the impeller. It's possible for a pump to have bearing failure but in most cases it will be an obstruction (such as a coin) stuck inside the pump. With the water drained out and pump filter removed it should be possible to see into the pump (where the impeller is) to check for obstructions.
Checking for blockages
Is the drain hose connected to the u-bend under the sink? If so try checking the spigot for blockages. Note that if you cannot hear the pump running don't bother. A blockage here would not stop the pump running, nor would it make the pump stop making its normal noise.
This is a simple fix, and can be done without moving the washing machine. The drain hose is connected to the u-bend by a plastic spigot pushed into the end of the drain hose. Unscrew the spigot to inspect inside. Also check inside the u-bend where the spigot screws on. A small button, or accumulated bits of stringy threads and lint from laundry can get stuck here. It takes surprisingly little to stop the water being pumped away at this point.
Check for a blocked pump filter
Next you need to check for blockages in the main pump filter if your washing machine has one. Most do. You will need to have drained out as much water as possible before removing the filter. Also, put down large bath towels before removing the pump filter to soak up the water that will inevitably come out.
Taking the filter out It should be easy to pull the filter out. If unsure check your instruction manual or the pump filter link above. If the filter appears jammed and won't come out read the advice in the pump filter article. Don't make the mistake of assuming that anything found in the filter will account for the fault. The pump filter would need to be physically blocked by something like a sock, or a buildup of lint to stop the washing machine from pumping out.
If all you find is a few buttons and coins this will not be the reason your washing machine isn't pumping the water. Only an object actually jamming the pump impeller or a substantial blockage of the filter would account for not draining.
If the pump isn't running The most common reason a pump isn't running is because an obstruction is physically jammed inside it. Check that the impeller turns and it's not jammed (or broken and loose on the shaft). It may have a little magnetic resistance at one point but it should be at the same point on each revolution.
The impeller should turn fairly easily. It might be possible to hear a gentle hum in place of the normal pump sound although not necessarily. A hum would indicate the pump his electrically OK and is trying to run but is jammed. With water drained out of the washing machine remove the filter and check for obstructions. If no pump filter is fitted the pump may need removing to check.
Pump isn't jammed
If the pump is not jammed then it needs testing with a continuity test meter for open circuit resistance across the pump's terminals. An open circuit pump is clearly faulty and needs replacing.
if none of the above helps you out you might have to call an engineer out.
Nov 30, 2017 | Washing Machines
Holding water
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 02, 2013 | Washing Machines
Washer won't spin
Good Day,
Avanti washer repair
Good Day,
Nov 01, 2013 | Washing Machines
Won't drain and showing F 01
Good Day,
Oct 31, 2013 | Maytag EPIC MFW9700S Front Load Washer
My dishwasher won't drain properly. The pump has been making a weird sound for a month or so and last night it couldn't drain. It starting beeping and the pump was running. I cleaned the drain filter
If the pump is running but noisy then that indicates a loose pump impeller (new pump I am afraid) if running (no noise) but failing to remove water, then I would be checking that drain hose is clear, or even that your machine is not syphoning water from waste disposal, a quick check would be to disconnect waste hose from waste disposal and see if it will then drain into a bucket, hope this is helpful.
Feb 18, 2013 | Dishwashers
The washer filled with water and started washing but now it won't drain, the knob keeps going and then just turns off but the water won't drain..what should I do?
Do you hear the pump run when it is supposed to? If not, then the pump may need to be replaced (warranty?). If the pump runs, but nothing comes out, lower the drain hose to a pan or bucket on the floor to see if water will run out under gravity. If water does come out, the pump may be defective (the impeller in the pump is loose on the motor shaft). If nothing comes out of the drain, look for a pinched drain hose or the hose from the outer tub to the pump. It may also be an obstruction in the drain connection at the tub connection (a stray sock or similar). Hope this works!
Mar 16, 2010 | Tecnik TKL9260 Front Load Washer
Bosch SGS5332GB dishwasher. drain pump runs all the time
There is a float under the machine that tells the pump to shut off. If the float is stuck or bad, the machine will keep draining. I am including a web site that might help. Bosch Dishwasher That Will Not Stop Draining Hunker
Nov 06, 2017 | Bosch Dishwashers
Maytag dishwasher won't drain water
It may be a water pump issue. You need to run it through a cycle and listen to hear if the pump is trying to run when it should drain. If you hear the pump running, but nothing is draining, you likely have a clog somewhere either going to or in the drain hose.
Nov 23, 2008 | Maytag Dishwashers
Hotpoint aquarius extra wma46
The first question you need to ask yourself is, "is the drain pump running?" If you can hear the drain pump running when it tries to drain, then more than likely you have a clogged drain pump, or drain line. Here's how you can determine which one: You can check the drain line by seeing if it collapses when the pump starts to run. If it does, then you know you have a clogged line somewhere BEFORE the pump. This usually means an article of clothing has gotten between the wash basket and outer tub and is stuck in the line. If the line is full of water and doesn't seem to be going anywhere, hook up a wet/dry shop vac to the drain hose in the rear of the machine to see if you can pull water from the tub, through lines, and through the pump. If you can't, you know you probably have a clogged pump, or drain line AFTER the pump. If the drain pump does not come on, you may have a pump failure. In either case, you need to drain the water from the tub. A wet/dry shop vac does a great job at pulling water from the tub, so you don't have to bail. Let me know if this helps.
Jul 22, 2007 | Hotpoint WMA46 Front Load Washer
Dishwashers Logo
Top Dishwashers Experts
