Question about Fuji FinePix A900 Digital Camera
Will someone help me?
My Finepix A900 digital camera is turning itself off every time i try to take a picture. Its not the batteries. And i let it sit for a week, and its still happening. Can anyone help?
  • brandini Mar 30, 2008
    lol. i figured it out.
    dont use cheap batteries on these cameras
  • deepview May 24, 2008
    Camera replaced FREE once already by Factory Service. Using best Duracell PROCELL Professional alkaline batteries. DO not use Video or Picture Reviews. Camera indicated battery 'dead' after 10 - 15 shots. Battery tester indicates battery still with full power. Rather not send to Service again.
Make sure your rechargeable batteries are at least 2500 m/amp (milli amperes).
Also in your SETUP menu, you can adjust this auto powersave feature.
Posted on Mar 29, 2009
  • 28 Answers
If you have read the user manual on page 16, this camera only compatible with two kinds of batts: alkaline or rechargeable batts.
Posted on Apr 04, 2008
Guys its not the voltage thats killing you, its the amperage. You MUST have a HIGH output battery for these things to work properly. Funny enough is that the alkaline batteries from dollar store work while other, more expensive ones wont. Look for information about the output amps of the batteries your using, use only HIGH output amp.s batteries. Again all of em will say same volts but put out different amounts of power
Posted on Aug 02, 2008
What type of memory card works for a fuji A900
The A900 works with xD picture cards and the more common SD cards.
Apr 18, 2014 | Fuji FinePix A900 Digital Camera
My fuji finepix A900 is not charging with usb cable on my computer
The A900 is not a battery charger. It uses two standard AA batteries, either disposables or rechargeables. If you choose to use rechargeables, they must be charged outside the camera, using a separate charger.
Sep 22, 2011 | Fuji FinePix A900 Digital Camera
I have a FinePix A900 camera with a 1 GB SD card. I connected a cable in the A/V Out to watch the photos on a TV set. At this moment something went wrong. The camera LCD becomes black and no picture was...
First of all, it is never advisable to copy a picture from the computer to a memory card or camera. Most of the time, it will corrupt the card and sometimes the camera. Second, the procedure for connection to a tv needs to follow a detailed procedure. This is different for each tv and camera. For example, on my tv, my camera and tv need to be off, I make the connection, turn on the tv, set the tv menu to "photos", turn on the camera, and then follow the on-screen prompts from there. If I change that order, I have problems.
Jun 19, 2011 | Fuji FinePix J10 Digital Camera
My Fujifilm A900 wont turn on. I press the power button and the lens comes out ever so slightly then goes back in. It also wont go into disk mode or view mode.
I also have this problem - it started when I put some Lithium batteries in (AAs). Whilst I was looking in the A900 handbook it said "do not put Lithium batteris in it" :(
I thought those batteries where for these type of battery eating devices.
Summary: put Lithium batteries in never worked again!!
it was only a week old too!!
May 27, 2010 | Fuji FinePix A900 Digital Camera
My Fuji FinePix A900 camera's batteries are low. I have tried to replace them with new batteries, but the camera will not turn on. It will only turn on with the old batteries in it. What's up with this?...
if you are using rechargable batteries make sure they are fully charged, try more powerful batteries.
clean each end of batteries and the contacts inside the camera for better electrical contact.
Mar 28, 2010 | Fuji FinePix A900 Digital Camera
My digital camera FinePix A900, keeps turning off when I turn it on. Unable to pull any menus. Batteries are good. any suggestions, is it fixable or do I have to buy a new one?
Try pressing the playback button to turn the camera on. This should turn the camera on just so that you can view any pictures stored on the card or internal memory. You can also access the menu functions this way. Also try pressing the picture/shutter button and see if the lens extends. If the camera shuts off when you press the picture button and the lens does not move or only moves a fraction then the problem is probably to do with the lens
Dec 18, 2009 | Fuji FinePix A900 Digital Camera
Camera switches off when i try to take a picture
Digital cameras need to run on rechargeable batteries, If you are already using rechargeables,have a look at tha mAh value which should be written on the side. Retailers recomend a value of at least 1800,personally i would go for 2100.
Sep 14, 2008 | Fuji FinePix A900 Digital Camera
Taking wide landscape shots
Cannon were the first to use PHOTO-STITCH and i am not aware of any other make as yet to have the abillity to stitch images on the camera itself. You may be able to buy or download some sort of software that will do the same thing
Aug 08, 2008 | Fuji FinePix A900 Digital Camera
My Finepix A900 digital camera is turning itself off every time i try to take a picture.It's not the batteries, I've tried 2 sets of new ones. Any suggestions?
Actually, it may be the batterys. Even top brands like Energiser can have unbelievably short battery life if they are not NiMh! Go onto the FujiFilm website and find the batteries they recommend
Jun 12, 2008 | Fuji FinePix A900 Digital Camera
Fuji FinePix A900 Digital Zoom error
Same problem with me. Got a zoom error. I thought "it's still under warranty, so Fuji will help me out." WRONG! Fuji repair claims it has impact damage, but that's not true. The product is just defective. Fuji charges $113 to get it repaired. It cost me $140 from Dell only 7 months ago. Defective.
Apr 18, 2008 | Fuji FinePix A900 Digital Camera
Fuji FinePix A900 Digital Camera Logo
213 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
