Question about Sony Ericsson W610i Walkman Smartphone
Phone lock my celllar phone just locked up
  • Anonymous Apr 09, 2008
    i don't know the lock code for my P800 & i need it immediately
  • sextine1234 Sep 29, 2008
    i need to unlock at&t for centennail plllease help me!
I HAVE FOGOTTEN MY UNLOCK CODE FOR MY SONY ERICSSON W610I. HOW DO A MASTER RESET ALL CODES.
Posted on Sep 26, 2008
Unlock it with no phone calls involved
Posted on Apr 29, 2009
Micromax i am forgotted my phone lock code
Micromax q75 phone lock ? : Solution: If you have not changed the default phone lock code for your micromax q75 phone. Then use "0000"(four zeros is the default code) and press the home button(top left most button and not the green sim 1 button). If you press the green button it will say " Emergency calls only" it means you are clicking wrong button. hope this helps you.
Nov 03, 2010 | Swiss Tech MicroMax 19in1 Multi Tool Clam...
Tip
How to lock a Samsung Intensity cell phone
Unlike flip phones, cell phones like the Samsung Intensity are subject to accidental keypad-pressing and dialing when they are in your pocket, purse, or even a holster. To avoid unintentionally using up voice or data minutes, you can lock your phone and temporarily disable the keypad.
There are two ways to lock a Samsung Intensity - the standard keypad lock and the security lock.
- To use the standard lock:
You can lock your phone at any time from the main screen by holding down the "0" key for about two seconds. The keypad will immediately lock, and you won't be able to use any functions or make any calls (except for calling the local emergency number). To unlock the phone, press the right option button (in the upper right corner of the keypad, next to the End button) followed by the Menu or OK button.
You can also set up Auto Key Lock, which will automatically lock your keypad after the backlight turns off. The Auto Key Lock setting can be found in the menu under Settings & Tools > Phone Settings > Auto Key Lock.
- To use the security lock:
The security lock also prevents your keypad from being used, but it requires a code to be entered in order to unlock the phone. To enable the security lock, go into the main menu and select Settings & Tools > Phone Settings > Security > Lock Phone Now. (You'll need to know your phone's security code in order to access this setting -- by default it is typically the last four digits of your phone number.)
To unlock the phone, press the right option button and then enter your phone's security code, followed by the OK button.
You can set your phone to go into security lock mode as soon as you turn it on by enabling Phone Lock Setting under the Security menu. Every time you turn your phone on, you'll need to enter the security code in order to unlock it. However, once you unlock it, it will remain unlocked until you either manually lock it or turn it off and then back on.
on Mar 04, 2011 | Samsung SCH-U450 Cell Phone
Tip
Unlock your samsung phone in just a simple trick
hi there everyone i would like to share this trick for some of samsung mobile phones
having problem with your phone it always says wrong card????
then try this one...
Note...this code is not working with some of samsung phones...
so just try it...100% it will not damage your phone
just follow this step
1st Make Full Eprom Reset *2767*3855#
After Rebooting Mobile
then enter....
*7465625*638*00000000*00000000# (to change NCK code to 00000000)
then enter...
#7465625*638*00000000# (to permanently unlock the phone)
check the lock status...
*#7465625#
Input *#7465625# to check the locks....all locks should now be inactive as shown below:
network lock - inactive
subset lock - inactive
sp lock - inactive
cp lock - inactive
sim lock - inactive
activa lock - inactive
phone lock - inactive
auto network - inactive
auto subset lock - inactive
auto sp lock - inactive
auto cp lock - inactive
auto sim lock - inactive
hope it will help you
on Dec 30, 2009 | Cell Phones
I need a sim lock code for samsung e370
Try All this you can do...
*7465625*746*Code# = Enables SIM lock
#7465625*746*Code# = Disables SIM lock
*2767*2878# (Temporary Unlock)
*7465625*638*00000000*00000000# (Set Code)
#7465625*638*00000000# (Clear Network Lock)
*#7465625# (Verify the network lock is “inactive”)
*2767*3855#
*2767*3855# - FULL E2P RESET
*2767*2878# - CUSTOM E2P RESET
#*7337# - UNLOCK
*2767*688# - UNLOCK
*#0523# - CONTRAST
*#9998*523# - CONTRAST
*#8999*8378# - Service Menu (X100)
First with different carrier SIM in phone at WRONG CARD screen ENTER on the keypad
*2767*3855# (wait 10-15 seconds) phone will reboot(restart)
When phone completes reboot ENTER
NEXT ENTER
AND THEN *#7465625# to check the locks....all locks are inactive...these are all the locks...
sp lock - inactive
cp lock - inactive
sim lock - inactive
Comments: Dec 07, 2007 - by DRSS - My FRND,
you need to go to the mobile repairer and you have to done flashing on your mobile...
THANKS
Jun 24, 2010 | Cell Phones
Mobile phone unlocking codes
*7465625*638*Code# = Enables Network lock
#7465625*638*Code# = Disables Network lock
*7465625*782*Code# = Enables Subset lock
#7465625*782*Code# = Disables Subset lock
*7465625*77*Code# = Enables SP lock
#7465625*77*Code# = Disables SP lock
*7465625*27*Code# = Enables CP lock
#7465625*27*Code# = Disables CP lock
*7465625*228# = Activa lock ON
#7465625*228# = Activa lock OFF
*7465625*28638# = Auto Network lock ON
#7465625*28638# = Auto Network lock OFF
*7465625*28782# = Auto subset lock ON
#7465625*28782# = Auto subset lock OFF
*7465625*2877# = Auto SP lock ON
#7465625*2877# = Auto SP lock OFF
*7465625*2827# = Auto CP lock ON
#7465625*2827# = Auto CP lock OFF
*7465625*28746# = Auto SIM lock ON
#7465625*28746# = Auto SIM lock OFF
Jun 08, 2010 | Cell Phones
I have an Haier 8 bottle counter top wine cellar. No electricity to digital display, rear fan is not on and does not cool. Looking for schematic for possible fuse location.
look down of the wine celllar and take off the plastic cap and clean the electrics contact. After that use use the 4 screwed support to give it the right inclination._400.jpg
Apr 10, 2010 | Haier HVUE08A Wine Cooler
I FORGOT MY SECURITY PASSWORD FOR MY SAMSUNG PROPEL A767, CAN'T GET IN PHONE... PLEASE HELP THANX
Hi Friend,
Kindly note down the below steps,
Unlock Method for SAMSUNG PROPEL A767. No Cables or Software Needed.
1. Turn mobile phone on with unaccepted sim BUT NOT FULLY INSERTED (only push it half way into sim slot).
2. Insert unaccepted sim to phone (push the sim fully into the sim slot).
3. Input *2767*3855# and phone will reboot and will be temporarily unlocked.
4. Input *7465625*638*00000000*00000000#
5. Input #7465625*638*00000000#
6. Input *#7465625# to check the locks....all locks should now be inactive as or similar to below:
sp lock - inactive
cp lock - inactive
sim lock - inactive
Check and revert back
Regards,
Ayyasam
Jul 01, 2009 | Samsung Propel A767 Cell Phone
My SGH-T629 came from the U.S. how can i make it capitable with the sim card in the phillipines
A. Turn on phone with full battery and non-T-Mobile SIM in place.
Allow phone to completely boot up to Wrong SIM screen. B. Enter from Wrong SIM Screen *#7465625# to confirm lock status C. Scroll through Interrogate Screen 1. Network lock - Active (this is the one you'll be deactivating)
2. Subset lock - inactive
3. SP lock - inactive
4. CP lock - inactive
5. SIM Card lock - inactive
6. Activa lock - inactive
7. Auto network lock - inactive
8. Auto subset lock - inactive
9. Auto SP lock - inactive
10. Auto CP lock - inactive
11. Auto SIM Card lock - inactive
12. Phone lock - inactive D. Push "C" button under navigation button to clear Interrogate screen back to Wrong SIM
screen E. From the Wrong SIM screen enter the following: *7465625*638*00000000*00000000# Those are two series of eight zeros. The phone will not show the zeros but will show dashes in their place. Phone may make a small tone and at the bottom of the screen it will read "Network Personalized" or perhaps "Network Already Personalized" F. Now input the following from whatever screen shows up: #7465625*638*00000000# (again this is a series of eight zeros) Phone may make small tone and will read "Network Lock Deactivated" G. Turn off phone
H. Re-start the handset and allow it to reboot.
J. Enter from Standby Screen *#7465625# to confirm lock removal status K. Scroll through Interrogate Screen 1. Network lock - inactive (note that this lock is now inactive)
That's it. Your phone is ready to accept SIM cards from just about any GSM mobile telephone service provider in the world. If you received a "wrong password" message you will need to insert a working SIM and reset the password to the default 8 zeroes "00000000". After that you may try this process again and it should work.
Dec 02, 2008 | Samsung SGH-t629 Cellular Phone
Reformat sgh t509
NEXT ENTER
sp lock - inactive
cp lock - inactive
sim lock - inactive
Sep 08, 2008 | Samsung T509 Cellular Phone
As you asked
ok, so all the locks are off on the phone.
The imei code is valid no one has changed it.
Its possible that the phone has been reported stolen?
Apr 27, 2008 | Samsung SGH-E370 Cellular Phone
Sony Ericsson W610i Walkman Smartphone Logo
368 people viewed this question
Top Sony Ericsson Computers & Internet Experts
David Payne
David Payne
Andrew Taylor
Andrew Taylor
Are you a Sony Ericsson Computer and Internet Expert? Answer questions, earn points and help others
