Question about Samsung YP-MT6X MP3 Player
Samsung YP-MT6 MP3 Player
Has anyone worked out how to connect the Samsung YP-MT6 MP3 Player to a computer running Ubuntu? I thought it would just show up in the file manager or plugging it into the usb would pop up a 'driver required' hint... But no joy :( I presume I need a driver but where to find it? Samsung don't support Linux or at least there's no driver for this mp3 player on their site... Just the windows option :( Help?
  • 10,421 Answers
SOURCE:
When i was playing my samsung yp-k3 player it was ok but when i turned it off all of the files where gone...but when i connect it on the computer it shows that there are still files in my mp3 player
I have own both a YP-T10 and YP-S5 samsung MP3 players and have experienced this myself, (1) First I checked what format my music was in and also where it is located on my MP3. (2) Then I tried resetting it, You can do this by pressing the rest button on the back, Its a small hole only big enough to fit a needle or a pin into it. It won't delete any files, Only reset the player. Then plug it back into your comp, if the files show in 'My Computer' and 'EmoDio/Samsung Media Studio' they should work fine in your MP3 player again:) Otherwise you might have to back it up and format the player but try the first 2 steps first.
Jan 04, 2010 | Samsung YP-K3 MP3 Player
Samsung YP-U3 is not recognized by computer
it is not appering in my copmuters but it is charging.
Jul 23, 2009 | Samsung YP-U3 MP3 Player
Lost two files in root directory on Samsung YP-MT6 MP3 Player
I would advise reffering to the Samsung website and reinstalling the firmware on the unit. This should install the files you deleted.
Jul 09, 2009 | Samsung YP-MT6X MP3 Player
Downloading music
No.
i tunes transfer files in aac format. Samsung only play mp3 and wma.
you can use samsung music studio in transferring files or converting files. you can simply drag and drop files to your mp3 just open it in the explorer.
Sep 16, 2008 | Samsung YP-MT6Z MP3 Player
Cannot use my player-device manager problem/deleting files
In case you have a problem to connect your Samsung YP-U2J Mp3 player, you should update Firmware to get it working. The new Firmware may be downloaded from Samsung.com.
CLICK Here to Download : Firmware Update
This error is common after with Windows Media Player 11
Here is the instruction:
  1. Download the YP-U2J Updater
  2. Remove Mp3 player if you already connected to the USB port
  3. Run the program (You should see something like: Please connect the device)
  4. Hold down the Play button and connect the Mp3 Player to USB port (Hold down the play button while you connect the device, you should see a message (normally after 8 seconds) like: Initializing on YP-U2J Updater program screen)
  5. After you hear the Windows chime "new device found" or the message "Initializing" on YP-U2J Updater, you can now remove your hand from play button.
  6. Check the Format Data Area checkbox (By clicking the yes button, you will lose all of your data in your Mp3 player)
  7. Click the "yes" button
  8. Finally, click on the Start button (takes less than a minute). DO NOT REMOVE YOUR DEVICE
  9. IMPORTANT: After updating the firmware, you MUST disconnect the Mp3 player and turn it on. You will see a 20% message for about 50 seconds and it will be restarted automatically.
Update: Please keep in mind that if you sync your Mp3 player with a computer that has a Windows Media Player 9 or 10, you should do these steps again
Jan 01, 2008 | Samsung YP-U2X Digital Media Player
Samsung YP-T5 MP3 Player I/O error
I had the same problem and solved it with this: On the Samsung support page, there´s a knowledge base called "YP-T6 Or YP-MT6 Show No File And Zero Free Memory" you need to download the latest firmare from the downloads section, then with the uptader on the PC, remove the battery from the YP-T5 or 6 and connect the USB cable to a PC while pressing and holding the play button on the YP-T. It should connect in a recovery mode which allows you to update the firmware, format the flash drive and get going again !
Jan 31, 2007 | Samsung Yepp YP-T5H MP3 Player
Samsung YP-T6 memory problem
I am having the same problem on the Samsung YP-T6 and i think it is because i might have fried the harddrive by putting in a non-alkaline battery in it. its like trying to plug in a american plugin into a plugin in germany, you blow up the house...
Dec 30, 2006 | Samsung YP-MT6X MP3 Player
I had the exact same problem, Just upgraded firmware to 2.121 from the Samsung website. The player seems Ok now
Sep 21, 2006 | Samsung YP-MT6X MP3 Player
Samsung mp3 player yp-MT6 512 MB
TRY THIS!!! Download the latest firmware and flash the MP3 player. Make sure you download the correct firmware for your MP3 player and follow the instruction carefully. Go here for the latest firmware: http://www.cczclan.com/yp-55download.asp Follow this link for older firmware and software from Samsung: http://www.cczclan.com/yp-55download.asp
Sep 21, 2006 | Samsung YP-MT6Z MP3 Player
Samsung YP-MT6X MP3 Player Logo
252 people viewed this question
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
