Question about Gestetner DSm618d Copier
Can't find paper jam. Looked and looked. Its a
Can't find paper jam. Looked and looked. Its a Gestetner dsm618d.
  • 59 Answers
Hi if u cant find any bit of paper in paper path may be any path sensor out of order or may be dusty sensor just clean the all paper path sensors
thanks
Posted on May 15, 2010
Error code 500 dsm618d how do i clear this code or fix it
The main motor is faulty or the pcu gears are damaged which have stalled the main drive, check pcu cam gear for free movement if ok replace main motor
Aug 28, 2014 | Gestetner DSm618d Copier
Ghosting on the paper
Verify the imaging unit special a OPC drum and the fuser unit upper roller.
Dec 18, 2013 | Gestetner DSm618d Copier
It always jam in the bypass when feeding long even though the print is already out of the fusing unit.
is the paper size correct? example bypass paper size is 8 1/2 x 13 or 8 1/2 x 14for long size. setting this to your bypass tray will tell the machine that the paper on your bypass is long.
Aug 24, 2011 | Gestetner DSm618d Copier
Driwers for windows 7
Hello!
Gestetner is made by RICOH. You can go to the web site www.ricoh-support.com and download it for free.
You will see this web site.
Aug 05, 2011 | Gestetner DSm618d Copier
What do these codes mean and how do I fix them? sc819 and sc820 I have a Gestetner dsm618d Thank you!
Install a new firmware, or
When installing the FCU, slowly and carefully connect the MBU to the FCU to
ensure a proper connection.
! If the connection is not properly established, the fax option may not be detected
and/or SC820 may occur.
Jun 14, 2011 | Gestetner DSm618d Copier
u have to go sp mode and clear the memory. to enter sp mode press the yellow botton once and press 107 and hold down the the red botton after some seconds it will enter the sp mode move to 5 mode scroll to clear memory and press ok
Mar 22, 2010 | Gestetner DSm618d Copier
Gestetner DSm618d accidentally adjusted display too dark, now can't read it, so I can't control the machine, nor can I readjust ''contrast'' Vince
No matter how dark the contrast, if the room is dark you will be able to read it well enough to get to the settings -that is unless the display is burned out altogether
Oct 23, 2009 | Gestetner DSm618d Copier
Two copiers. Gestetner DSM618d - Will not stop showing jam indicator in compartment B. Have a code to call service center error - SC571. No idea. Aficia 200 - keeps saying call service center. Ken...
for the jam code make sure after you have checked that you reset the side door correctly on upper and lower section and that the re is no paper caught behind the paper sensor arm as somtimes if pulled down it can tear and jam the sensor..the 200 might just need the pm counter change or reset..go into the service mode via clear[yellow] 107 then hold down the stop button till the creen changes copier sp and then 7. data log and you can reset the pm there...good luck A
Jun 15, 2009 | Ricoh Aficio 450 Copier
Disabling the fax function
You can set the fax portion of the machine to manual receive like this:
"User tools"
"fax features" ok
"reception settings" ok
"switch reception mode" ok
"Manual reception" ok
"user tools" to exit
Thia will prevent the machine from picking uo any incoming faxes
....However, if the machine is jamming trying to print a 'fax' report, it will jam regardless of the feature you are using -they are unrelated. Depending on the cause of the jam, it could be a specific tray that is causing the problem, so you may want to remove the paper from that tray, and see how it works. The other reason, that is common for jams from one particular tray is that the size is set incorrectly. Check that the paper size dial on the tray is set for the appropriate size in the tray (including orientation).
If none of this helps, please describe the location of the jams, and I may be able to give further advice.
Apr 23, 2009 | Gestetner - DSm618d Digital Imaging System...
Had a paper jam. Cleared the jam.
you have go to SP mode to reset it;
1, power on,
2, press "clear mode" enter107 and "clear/stop" for few second
3, press "copier SP mode
4, turn power off (5 second) and back on.
Dec 14, 2008 | Gestetner DSc332 Copier
Gestetner DSm618d Copier Logo
110 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
