Question about Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima wf640
Just brought washer from my daughters to mine and started a wash load. Was fine when she last used it. It is about 3 months old. Light on front keeps flashing H20 but water is going into machine and in drum but wash never starts. I have cancelled it and put it onto drain but keeps going back to wash. Help!!!
    President:
  • 1,294 Answers
Click on your model number (below FIXYA) on this website, & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line. You might find the mysterious codes there.
And dont forget to rate me on this great site.
Possible your thin hose going down from the pressure switch to the pump area is off or blocked; this hose should be blown into from the top, or try to unblock & refit carefully from below the pressure switch
Posted on Mar 30, 2008
2 Suggested Answers
SOURCE: hotpoint ultima wf640
read your washer instruction manual and check all connections also h2o stands for the chemical sign for water
Posted on Apr 03, 2008
F02 what does t his mean thanks on wf640 1400
'f02' normally indicates a problem with the motor or the tacho. Often these kinds of faults with Indesit (Hotpoint, Ariston) are cured by reseating plugs/sockets but require a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jun 24, 2011 | Hotpoint Ultima WF860 Front Load Washer
Machine does not clean clothes the machine seems to work ok but the washing feels stiff and there is sedment on the washing the machine is a hotpoint ultima 18 months old.
Try cleaning out the dirty water pipe. Mine was completely blocked up with scale and soap powder. We used a coat hanger and went from the out side as well. The water now pumps out completely without leaving any left under the drum
May 08, 2010 | Hotpoint Ultima WF860 Front Load Washer
Error code on washing machine wf640
have you checked you have turned on the water back on???? check but red and blue, or just blue it must be 90degree left or right.
Mar 08, 2010 | Hotpoint Ultima WF860 Front Load Washer
I have washing machine Aquarius wf640 + it keeps showing f-02
F02 indicates that the motor tacho has broken or become detached, this is to be found on the end of the motor shaft.
Pleawse rate my solution.
Thanks.
Aug 07, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hot Point Washer will not drain water from tub.
my old hitachi washing machine PAF-760P was not used for a long time.I started yesterday, it started washing but when the knob rotates and goes to drain the water,it only clicks and does not drain the water. What must be wrong with it. can you help please.
Jul 28, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima wd865
call hotpoint and get cover for a fiver a month. I do cause mine breaks down regularly - only 2 years old and had engineer out for this prob amongst many others
Sep 28, 2008 | Hotpoint Ultima WF860 Front Load Washer
Your exit hose behind the machine has to go over a certain height before it goes into your wall standpipe or sink. The height is marfked behind your machine, approx 3 feet above ground level. The hose should put about 3 or 4 inches into the standpipe, & not fitted airtight. Post back later if the code stil comes up...........
Mar 30, 2008 | Hotpoint Ultima WF860 Front Load Washer
Wf640 test
This has happend to me today! this is the fix
  1. Press and hold the Start/Cancel button until message clears
  2. Now press both Start/Cancel and On/Off buttons together until you get a dOFF message
  3. now your machine should work OK
Mar 17, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Ultima WF860 Front Load Washer Logo
145 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
