Question about Hannstar I-Inc TW-191D Monitor
My monitor turns dark when I power up PC
My monitor turns dark when I power up the computer. Usually I need to turn it off and on to get the display to stay on. After I try this stays on but the problem always comes back when I turn pc back on.
  • 11,361 Answers
You may have failing power supply due to bad caps (leaking/bulging tops)
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 17, 2010
What causes laptos to not show display despite showing that they have switched on?
Step 1:
The display on your laptop is the interface through which you interact with and control your computer. If it is not working, your laptop will become virtually impossible to use. A laptop is a computer, and like all computers is subject to both hardware and software problems that may affect the display. Before taking your laptop in for repair or getting rid of it, you should first check the display yourself to see if it needs to be replaced.
Check the laptop's battery and power cord. If the laptop is out of power, the display will not work. This usually happens if the power cord is unplugged and you were unknowingly running your laptop on battery power. Check to make sure the power cord is plugged in and that the laptop has power. Many laptops also turn off the display if it is being powered by its battery after a period of nonuse. Touching any key will usually turn the display back on if the battery is not drained. Restart your computer. If a software program is stuck or malfunctioning, it may cause your display to stop functioning. Press and hold the "Power" button on your laptop to reboot your computer. If the problem was a malfunctioning program, the display will turn on after the computer restarts. Check the brightness level of the display. If the level is too low, the screen will appear dark. The brightness controls are usually located on two function keys, such as "F9" and "F10." Look for sun or light icons on the keys. Press the key with the larger icon to increase the brightness level. Alternatively, on some laptops hold the "Fn" key while simultaneously pressing the "Up Arrow" key to increase the screen brightness. Check the display closed switch. Many laptops have a small button that senses when the LCD screen is closed and puts the laptop in sleep or hibernation mode. If the switch gets clogged with dirt, it may get stuck in the closed position. This will result in dark display even when the lid is open. The switch is usually located near the hinges of the lid. Spray the switch with a can of compressed air to loosen the dirt so that it will resume its normal operation. Plug an external monitor into your laptop. If the problem is not software related, the external monitor will display the laptop's screen. Connect the monitor by plugging the cable into the VGA, HDMI or DVI port on the laptop. Press and hold the "Fn" key while simultaneously pressing the "F8" key. The video output will be directed to the external monitor if there is a hardware problem.
b>
Feb 21, 2013 | Toshiba Satellite Computers & Internet
Erratic display
So your Gateway is brand new or a refurb?
Aug 02, 2008 | Computers & Internet
Lcd screen not working
Step 1:
Feb 20, 2013 | Computers & Internet
LG L1730S 17" LCD Monitor
Hi Anand,
You need to check your power options settings and modify it , so that your monitor does not turn off automatically.
If you are using windows xp , go in control panel and then there would be an icon for power options , double click the power options and then you would find settings which read turn off monitor , turn off hard disk etc... select the turn off monitor to never mode or as per your convenience and you would have your problem solved.
Hope this helps.
May 12, 2011 | LG L1730S 17" LCD Monitor
Computer turns on and boots up , however, the screen is dark
Try going into the control panel and select power options see if there is way to adjust the display brightness or try holding down the "Fn" key and use F7 to increase the brightness
Feb 07, 2010 | Toshiba Satellite A75-S229 Notebook
I have a dell Dimension 2300 and the images are very dark. I don't think it is from the monitor.
Try these steps: 1. Check the monitor settings. Access the On Screen Display (OSD) Menu System. Adjust the contrast and brightness using the control buttons in the monitor.
2. Run the monitor self test. Unplug the video cable from the computer (cable from monitor to the back of the computer). Usually it has a blue or white connector. Turn on the monitor alone. It should display the self test pattern (white, red, green & blue). If the images are dark in the self test, it is a problem with the monitor.
2. Rotate the monitor to face a different direction. This will help in eliminating sunlight glare which can cause poor picture quality.
3. Test your computer using another working monitor. If the problem occurs in a known good monitor, then it is a video card or motherboard (if your video card is integrated) problem.
I hope these options help.
Jan 19, 2010 | Dell Dimension 2300 PC Desktop
Power light on no screen shown
unplug from pc, turn on monitor. if there is a 'no signal' or any image displayed on the screen then the problem is not the monitor..
Nov 15, 2009 | BenQ FP737S-D 17" LCD Monitor
Dell display is dark
Leave the monitor hooked up to the computer with you booted up into windows.Go into the menu on the monitor itself. There should be a button on the monitor itself that will allow you to go into its own menu. From there try to find the brightness and contrast controls and turn them up. If after you turn them up the display stays dark then your monitor is bad and it will need to be replaced.
Dec 30, 2008 | Dell E153FP 15" LCD Monitor
Powers up temporaly displays goes dark
Your monitor has a bad back light. Send it back to your friend
Nov 22, 2007 | BenQ T705 17" LCD Monitor
No display
if your monitor is not connected to a pc, then it cannot find a vga signal input and therefore go into power saving mode, which is indicated by the orange light, but as soon as you connect to the pc and power on the light will go green and the monitor will power up.
May 07, 2007 | BenQ T701 TFT 17" LCD Monitor
Hannstar I-Inc TW-191D Monitor Logo
118 people viewed this question
Top Hannstar Computers & Internet Experts
David Payne
David Payne
Are you a Hannstar Computer and Internet Expert? Answer questions, earn points and help others
