Question about Refrigerators
Bad compressor My Frigidaire sxs fridge compressor is bad. It has a five year warranty. (bought in 2005). Could you inform me of the procedure I should go thru in order for Frigidaire to make good on their warranty? Thank you,
  • 109 Answers
Call fridgedaire customer support, they will refer you to a service center that will come to your home and repair your unit, you will need your reciept if you didn't register the product. good luck!
Posted on Mar 30, 2008
Recently got 2nd hand Amana side by side model XRSS687BB. Compressor stops when closing fridge door. Freezer working as long as fridge door remains open. Fridge damper closed and won't open though it
I have went through something like this before, the serviceman told me it was in fact a compressor issue. Do you hear some kind of buzzing noise? Is it extremely hot? Then it's a compressor issue. They are pretty expensive to have replaced, would recommend to purchase a different brand. I had the same problems as Frigidaire. I had the compressor replaced twice during a time period of 2 years. It went out a third time and it was out of warranty and they told me that the compressor didn't receive any kind of warranty gain for itself and the company shortened the warranty of the compressor because of the issues they had with them. Since they were aftermarket ones, didn't apply to the original warranty. If you continue to have issues with this brand, please research the brand integrity online before you make another bad investment. I paid more for the new brand but it lasted longer than 9 months. The next fridge that I bought was older and used but lasted 5 years, so I stuck to that brand and it paid dividends stop far.
Dec 18, 2014 | Amana Refrigerators
Fridge stopped working both freezer and fridge, Here clicking at compressor, compressor not starting, cooling fan and everything else OK, could it be the compressor or is there a chance the thermal switch...
This is a bad compressor, or overload-relay kit. Disconnect the power, remove the overload-relay from the compressor, and test the three compressor terminals for continuity . You should have continuity between each terminal, and you should not have continuity between any terminal and ground. If this tests ok, then replace the overload-relay kit. This is a common repair for me, and it is very rare for us to find a bad compressor, so you should be ok. If it is a bad compressor, and it is less than five years old, you have a five year sealed system warrantee, that will cover the repair cost. If it is over five years old, it is not worth repair. When you are done with the repair, make sure you install a 2000 joule or higher, surge protector to protect your refrigerator from this type of repair in the future. Good Luck, Appliance Specialists
Mar 14, 2011 | KitchenAid Superba KSRG25FK Side by Side...
Compressor runs only a few seconds then clicks off
The compressor is going bad, check your owners manual for warranty information or look here http://b2b.frigidaire.com/support/manuals.asp if you cant find the manual. Some units have up to 7 years on the sealed system (the compressor, cooling coils, and hot coils).
Jan 30, 2010 | Refrigerators
My repair man told me my compressor is shot. The
yes the compressor is under warranty for up to five years.how ever the over load relay and start ptc might be bad in stead of the compressor.so you can try and change them first and see what happens
Jan 25, 2010 | Refrigerators
I have an Amana SxS (model DRS2663B) that is about 8 years old. About a week ago, it started making a sound - kind of a buzz coming from the compressor area (or the little box I identified as a...
You may have a bad relay/overload part number 12555902 runs about $15 but if the compressor is going bad it may not work.If you take the relay/overload off  turn it into your hand and shake it if you it sprinkles out like a pepper shaker go with the OEM part afore mentioned,but if it sounds solid and nothing comes out go with a hard start(SUPCO RC0410 also about $15) it will buy you at least another couple years in which to shop around for a replacement or save the money for a new compressor.You can call Amana to check on the warranty but most only had five years on sealed system.
Sep 27, 2009 | Amana DRS2663B Side by Side Refrigerator
Frigidaire plht189sska top freezer fridge problem. Freezer is cold, fridge is warm. About a month ago, had the problem of frost build up in freezer, water pooling under veggie bins, warm fridge. ...
If the defrost heating element, defrost timer or evaporater fan weren't working, you'd develop a block of ice on the evaporator. Is the compressor running? If it is, it might have bad valves from the frost buildup scenario. Liquid refrigerant could have gotten to the suction valves. The sealed system should have a five year warranty. Might be time to call a pro
Sep 15, 2009 | Frigidaire PLHT189CSB Stainless Steel Top...
Compressor Problem WeatherKing 13AJA36A01
Your warranty on your WeatherKing is five years on the compressor. When you buy a compressor to go in your unit it is 1 year. Several resons for bad valves. Dirty evaporator coil, overcharged and bad evap fan motor. James
Jul 10, 2009 | Heating & Cooling
My Frigidaire #LSR7333PQ has had two compressor failures in 3 yrs
Compressors fail due to:
bad capacitors.
bad start relay.
low voltage.
refrigerant leaks.
refrigerant restrictions.
bad fan motor.
to name a few problems.
You should be under a 5 year seealed system prts and labor warranty.
Call him back out.
Mar 09, 2009 | Frigidaire FRS26R4A Side by Side...
Frigidaire the refridgerator is not cold enough. It stays at 60 degrees, I don't know the model because it was torn off inside the fridge and the owner's manual did not come with the house when we bought...
Have one similar and found out the compressor goes out on them about a year and half after purchase. You can buy another compressor but the likely hood of it going out again is likely. Sorry but we bought bad fridges. Never again will I buy a Fridgidaire.
Jun 10, 2008 | Frigidaire Refrigerators
Beware of what you buy?
I hear the frustraiton in your blog hear,but honestly its misplaced anger, fortunate for you you werersold a left over and had coverage, ALL manufactures as of jan 06 now only carry 1yr warr's on all repairs, not just frigidaire, so yes BUYER BEWARE, but not just of frigidaire or bestbuy,, all appiances and all dealers are now in this together!!!!!!!! cust really needs to do homework and look into exactly whats being sold.. by the way components havent changed only the length of the warr
May 02, 2008 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
74 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
