My 50 inch Samsung DLP completely turns off at random times. The problem seems to be getting worse and happening more frequently. HELP!
  • n_j_vance May 04, 2009
    i have the same problem only with a toshiba 61h71. picture is fine but randomly turnes off and flashis red light. then to turn on again it must be unplugged. HELP!?!?
  • 8,617 Answers
What is the model number of your DLP? I should be able to help you out, but will need the model number.
Posted on Mar 30, 2008
SOURCE:
I have a problem with samsung sp 50 l7h a 50 inch dlp tv
I can see you have a Samsung TV, well the issue seems to be your ballast which doesn't have enough voltage to keep on with your lamp. This is why you keep losing the picture every certain amount of minutes. The thing with Samsung Tv's is that they have issues with the ballast and the color wheel, they tend to go bad pretty fast.
Jul 27, 2009 | Samsung Televison & Video
Numerous white spots on Smasung DLP TV
Mine is having the same problem. It started around Memorial Day and is only getting worse. One white dot is now a dozen. I called Samsung several times and was given the brush off. They clearly know this is a problem and are failing to respond to the problem in hopes that people will deal with it on their own. It does not matter if your warranty is expired. This is a latent product defect. They are still liable and obligated to fix the problem. I have filed a complaint with the better business bureau. If the company does not respond, I'm taking this to small claims court to get reimbursed for any cost to fix my tv.
Jun 02, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
My Samsung HLN5065W started to freeze to a black and white
I have a problem with my HLN 5065W Samsung DLP that 3 other folks have and no solution. After the set is on from 5 minutes to 6 hours, the screen will freeze in black and white, I can turn it off for 5 minutes and it will display a good picture again. Sometimes the screen will just go dark blue, TV has to be cycled on/off to get the display back. This problem is getting worse, started as once a month, now 3-5 times a day. I have a tech background and can read a schematic, HELP.
Mar 01, 2009 | Samsung HLN5065W 50" Rear Projection...
Power button blinks green about 1 minute then goes red
There is an additional problem,
if the bulb had been replaced by a technician, call them back and ask for additional support, since they did not fix the problem.
Oct 15, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Color blinkig in and out.
It seems like the color wheel might start to fail.
Do you hear any abnormal sound(s) from the TV when ramdon color appears.
Would you be able to check and make sure all the fans are working properly?
Jul 13, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
Monitor some times gives shades with black
While 50 inch dlp samsung is on, 6 inch black line on left side of screen. This is the second time this has happened. The first time it happened then the lamp blew......do I need to replace the lamp again?
Feb 19, 2008 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
Top Televison & Video Experts
Ekse
