Memorex recorder how do i install driver for memorex dvd ram 530 L V1 getting error 39 corrupt driver
Memorex has a support site that will tell you where to download your proper driver. I just purchased a DVD +/-RW that came without drivers and installed it in line leaving my CD as master on the buss strip (the end). Did not want to play until I put it on the middle or slave connector (thinking my computer or hookup cable is backwards now although it shouldn't be with their only being one way to attache it to the drive and motherboard!). Try Cable select and then try it alone and then try the open slot
Posted on Mar 30, 2008
Hi there I have a memorex dvd + - ram recorder 550L v1 All of a sudden it stopped working I checked the hardware in windows and I get this message Windows cannot start this hardware device because...
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
hope this helps you
Aug 24, 2011 | Memorex Computers & Internet
After copying many memorex dvd r discs I cant seem to copy without getting a session fixation error. Ive used 3 other brands of discs and 2 other software recorders.The only time I did succeed was when I...
dear rsavage11 :
like this problems many reasons cause it :
the first one is the dvd data cable is bad try to use original one
the second reason is power supply some time there is a bad voltage
the third reason ram can make this problem
if you see that is helpful please don't forget to vote me
best regards
Apr 22, 2011 | Memorex DVD+R Discs 47GB 16x Spindle...
Hi, The DVD/CD Rom Icon has dissapeared on My Computer. When I go to control panel - device manager and click on the dvd/cd rom drive icon I get the following message in the genaral...
You will need to re-install the driver. Right click the device in device manager and select properties. Navigate to the driver section and uninstall all existing drivers. (It may *not* give you the option to do that, depending on how corrupted the driver is, but it should.)
Reboot the PC.
Upon reboot, Windows should find the new device and install generic drivers. It will probably ask you to reboot a second time.
Apr 07, 2011 | LG GSA H62N Super-Multi - Disk drive - DVD...
I get a message upon login- error loading winhbe32.rom. what do i do?
I believe you may have a corrupt driver for your cd-rom or dvd rom.
Dell Driver support
Find your DVD or CD device and reinstall your Drivers.
The problem should go away.
If not, you may have a bad driver or cable.
Oct 03, 2010 | Dell Inspiron 530 Desktop Computer
Memorex dvd +- ram 530L v1 ata lightscribe software does not work
www.cnet.com/topic/memorex.html -
Happy surfing
Might be a pain, should have what you need, if not, type in Memorex Downloads to Google search, go surf from there, loads of info.
Hope it helps.
Nov 14, 2009 | Computers & Internet
Nero Vision 4 refusing to burn to DVD (Memorex DVD Burner)
if its having problems writing the lead in, it,s possible that the devices drivers are corrupt or incorrectly installed. to resolve this re-install nero, or better still upgrade to a newer version of nero.
also check that your media/ blank dvds are compatable. some writers support DVD-R But not +R.
if none of the above works, go into the device manager, and uninstall the DVD drive, reboot the computer, and re-install it. Other related problems are usually atapi or couffin drivers.
Mike @ compurepair.
Jun 11, 2009 | Memorex (32023237) DVD±RW Burner
Matshita drivers on toshiba notebook
Code 39 loadTOCNode(2, 'moreinformation'); Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
Recommended resolution loadTOCNode(3, 'moreinformation');
Reasons for this error include a driver that is not present; a binary file that is corrupted; a file I/O problem, or a driver that references an entry point in another binary file that could not be loaded.
Uninstall the driver, and then click Scan for hardware changes to reinstall or upgrade the driver.
On the General Properties tab of the device, click Troubleshoot to start the Troubleshooting Wizard.
Keep me posted.
Oct 13, 2007 | Toshiba Style Bay DVD-RAM Drive Kit...
Computers & Internet Logo
91 people viewed this question
David Payne
David Payne
