Setup password Computer shut down and will not reboot. Boots to scree that says press f2 for setup, and on bottom press f12 for boot device setup menu. Each option asks for a password. I have tried every password I know and no luck. Is there an override password? This is not my computer, I was contacted by a friend for help. all I have is the serial # for the product.
  • 1 more comment
  • lefty2769 Mar 30, 2008
    Thanks for your help
  • renia Jul 09, 2008
    my notebook after booting up it will not start up.
  • jaydeo Jul 25, 2008
    computer shut down and will not reboot. boots to screen that says press f2 for setup and on bootom f12 for boot device setup menu. each option asks for a password. i have tried every password i know and hade no luck is there an override password? i have serial number for product,.
Remove battry thet put it i water the dry it ,refitt ur battry ad strt
Posted on May 01, 2008
    Genius:
  • 3,587 Answers
Nope..if you don't have the password, and they don't, then it's reformat time for that machine
Posted on Mar 30, 2008
Just install new hard drive in my laptop....old one frozen. i have an activation key for windows 8.1 pro. how do i install new operating system?
Boot from your installation disc. Insert the installation disc into your optical; drive, and reboot your computer. Normally a computer boots from the hard drive first, so you will need to adjust some settings in your BIOS in order to boot from the disc drive. You can enter the BIOS by hitting the designated Setup key during the boot process. The key will be displayed on the same screen as your manufacturer's logo.
  • Common Setup keys include F2, F10, F12, and Del/Delete.
  • Once you are in the Setup menu, navigate to the Boot section. Set your DVD/CD drive as the first boot device. If you are installing from a USB drive, make sure that the drive is inserted and then select it as the first boot device.
  • Once you've selected the correct drive, save your changes and exit Setup. Your computer will reboot.
Oct 31, 2016 | Computers & Internet
Bios setting probleme
you can not press the F12 or F2 Key at startup ....You need to hold the key down abd bios will open of boot order if F12 is pressed.
So hold the key down(F2,F12) then press the power key...keeping the F key pressed down.
Good Luck
Jun 19, 2013 | 10 10 Computer Network adapter Cable...
Change the f12 boot menu on an acer t180
Press F2 to enter BIOS setup at startup. You can set which devices appear in the list from the boot menu.
http://johnbokma.com/mexit/2007/12/22/acer-aspire-phoenix-bios-boot-screen.jpg
Jan 20, 2013 | Acer Aspire™ T180 PC Desktop
SATELLITE U205 ....IS ITPOSSIBLE TO BOOT FROM AN EXTERNAL USB DVD DRIVE
Shut your computer down and remove the power cord.
Replace the power cord and press the "Power" button to restart it.
Watch the screen carefully for a message about computer setup.
Most computers use one of the function keys, which are aligned across the top of the keyboard, to access the computer's setup utility, but each manufacturer uses a different key.
For instance, HP computers generally use the F1 or F10 keys, while many Dell computers use the F12 key.
Press the appropriate function key to enter the computer's setup program, then scroll through the list of options until you see "Boot Order."
The exact location of the boot order option varies from manufacturer to manufacturer, but it is often located under the Advanced menu.
Highlight the "USB Devices" option and press the up arrow key until that device is first on the boot order list.
This will force the computer to look at the external DVD drive first when it boots up.
Use the "Esc" key to exit the setup menu. Choose the "Save settings and exit" option and allow the computer to reboot.
It will now boot from the external DVD drive.
Hope this helps
Sep 26, 2012 | Toshiba Satellite U205-S5057 Laptop DC Car...
After turn on is asking for password (bios) and no body set up any password.
Hi, "Reboot" the Computer, look at the bottom of the [Screen] there will be (2) two, "Options" F2 for {Utilitiys Setup} and F12 for [Boot Options]; you want to "Press" the F2 button immediately at "Startup!" Once your in the Utilities, you can change the [Password]. If all go well, let me know by giving a "helpful rating," thanks.
Jun 21, 2010 | Toshiba Satellite A215-S5837 Notebook
Can't boot up my HP XE4100 laptop
press hard disk and boot the windows
Apr 01, 2009 | Computers & Internet
Bios batt
if you leave it long enough does it boot ?
press F2 and go through the settings and check for something like "display boot menu" or similiar.
remember to save your settings upon exiting
Sep 20, 2008 | Toshiba Satellite M100 Notebook
Computer bios seting
Try restarting the computer. As soon as it shuts down start tapping the "Del" key continuously. It has to be before the beep if you get a beep, and before any boot up screen appears.
If this doesn't work try in the same manner tapping F2,F8 or F12.
Try going on the web to Emachine site and do a search for that question.
Good-Luck
Jul 26, 2008 | E-Machines eMachines Desktop PC
Setup password
i think the computer is asking for bios pc if it is bios then you have to open the case and remove the bios battery for five sec.before this you have to remove the power plug.after five sec. just resit the battery and put the power plug back and switch it on.
plz post your findings
Apr 23, 2008 | Panasonic TOUGHBOOK CF-18 Tablet PC
Can not Boot from OnBoard SATA Hard drive.....it keeping looping...
Turn on (or restart) your computer.
When F2 = Setup, F12 = Boot Menu appears in the upper-right corner of the screen, press <F12>.
The Boot Device Menu appears, listing all available boot devices. Each device has a number next to it.
At the bottom of the menu, enter the number of the device that is to be used for the current boot only.
If this works and you want to change the setting permanently do the following:
When F2 = Setup, F12 = Boot Menu appears in the upper-right corner of the screen, press <F2>.
Use the arrow keys to highlight the Boot Sequence menu option and press <Enter> to access the menu.
NOTE: Write down your current boot sequence in case you want to restore it.
Press the up- and down-arrow keys to move through the list of devices.
Press the spacebar to enable or disable a device (enabled devices have a checkmark).
Press plus (+) or minus (–) to move a selected device up or down the list.
Feb 17, 2008 | Dell Dimension 4700 PC Desktop
Computers & Internet Logo
98 people viewed this question
David Payne
David Payne
