Question about Philips 170V6FB (Black) 17" Monitor
Philips 170V LCD screen steadily blinks on and off, even when not
Philips 170V lcd screen steadily blinks on and off even when not connected to a pc. Both screen and power led blink. Resolves itself at random from anywhere between 20 minutes to several hours later
  • 11,361 Answers
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 16, 2010
2 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: Philips 170V LCD screen steadily blinks on and off, even when not
I would open it up and inspect the capacitors in the power supply section first since it is simple thing to do, look for bad caps with bulging top or seal, see failed monitors (common problem) due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Posted on Mar 22, 2010
Blinking screen
The screen might be going bad, or the lcd cable could just be loose and needs to be reseated. The lcd would have to be taken apart to get to the cable.
Plug in an external monitor and see if thedisplay shows up on it. It can be any kind of monitor even the old big fat crtmonitors as long as it has a vga cable to connect to your computer's vgaport. If so that proves your video card is ok. The video will showon most systems when you reboot without you having to do anything. Some systemswill require you to hit the FN (Function key) + F1 thru F12. Hold downthe FN key then hit the correct key for displaying on the monitor (F1 thruF12). The correct key will normally have CRT/LCD on it or it will havethe icon of a display.
If the external monitor you plugged in blinks then your video card has an issue. If not, it's the lcd screen.
May 06, 2012 | Toshiba Qosmio X305-Q725 PC Notebook
White horizental lines across the LCD Monitor.
This is a high voltage horizontal output problem. Could just be a loose connection or an intermitant component failure. If you can get into it, check for any loose connections. Sometimes this can also be caused by a large accumulation of dust. Make sure you unplug it before opening it up.
Apr 04, 2012 | HP LP2465 24" LCD Monitor
My television is a Philips LCD 4 Had it for 2 years.
caps on the PSB-power supply board are blown.... Do you have blinking LED yet?
Best Regards and Semper Fi
Aug 03, 2010 | Philips 42PFL5332D 42 in. LCD Television
Philips 170V LCD screen steadily blinks on and off, even when not connected to a pc. both screen and power led blink. resolves itself at random, from anywhere between 20 minutes to several hours later
Mar 22, 2010 | Philips 170V6FB (Black) 17" Monitor
LCD TV model LA32R71BAX. The problem is the screen is black and power indicator light blinks steadily
unit has an internal problem, have an electronics tech look over the power supply as well as the main pcb nd the drive pcb for the lcd panel, it is rare that those symptoms are caused by the panel.
Jul 05, 2009 | Televison & Video
17" Philips LCD TV has sound, faint blue flashes and blinking pwr
GP151001, Typically these cable/wire connectors fall into a catagory called HIGH DENSITY INTERCONNECT connectors or similar type. I should think that the whole assembly should be available somewhere ****!!! It's just this kind of thing that really gets me P.O.ed louie12fix
Apr 15, 2009 | Philips Epic 17PF9936-37 17" Flat Panel...
Problem with LCD
Indeed offered solution is most likely correct. However I can suggest you to ensure if dots/lines appear even before windows screen comes. If yes thats the conclusion that your LCD Module has dead pixels or internal connectors has connectivity issue. Consult a local Hands on technician. LCD module might be costly you can always use an external monitor with your laptop.
Good luck. Happy new year.
Dec 27, 2007 | Acer Aspire 3002LCi Notebook
Philips 170V6FB (Black) 17" Monitor Logo
415 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
