Question about Norelco 8883 XL Electric Shaver
Hair clippers that don't work
I haven't used the electric clippers for years and when I turned it on it did not run, but smoked slightly. I quickly turned the clippers off. What type of service is required?
    New Friend:
  • 160 Answers
Sounds like a bad switch
Posted on Jul 07, 2008
  • 62 Answers
The unit should be sent into the manufacturer for a complete review.
Posted on Mar 31, 2008
How do I use Wahl hair clippers? How do I know
Hi I have been a hair stylist for 25 years each guard that clips on has a number on them the lower the number the more hair is clipper off start big like a number 8 will leave one inch of hair 7 leaves 7/8 of a inch 6 leaves 3/4 of a inch 5 leaves 5/8 of a inch 4 leaves a 1/2 inch of hair on the head 3 leaves 3/8 of a inch 2 leaves 1/4 of a inch and a 1 is just hair on the Scalp almost bald no days the color of guards are changing so your best bet is go with the size remember to start with the largest one first then you will know what you like the best and you can't go wrong and if you buy WAHL and you not A Hair Stylist You Can Purchase A Good Clipper at Sallys Good Luck
Jul 30, 2011 | Wahl Health & Beauty
Clippers dont work at all, don;t cut hair and the dog hair is trapped
A reason your trimmer may not work is that the hair is trapped inside the trimmer and not allowing it to function properly.
Here is a link to a video to cleaning hair clippers.
www.youtube.com/watch?v=43CpUK2AghA
If the problem persists, then you most likely burnt up the engine in the clippers and there is no easy solution other than buying a new trimmer.
May 02, 2011 | Wahl 8550
My clippers are frozen. They don't vibrate but the motor turns on.
Hi, How long have you been using the clippers? In my experience they can get clogged with hair quite quickly depending on the animal. I'd recommend removing the blade to better get at the hair stuck between the blades. Once the blade is off lubricate the appropriate parts following the guide in your operating manual. It's best to do this soon before the motor burns out. If you feel that the blades are too clogged, it's easy to buy a replacement blade for around 1/3 the price of a new clipper set.
Mar 12, 2011 | Andis Super Deluxe Pet Clipper Kit
How to position the clipper blade while u sharpening?
Hi!
I'm not sure about the nature of you question. Firstly if you mean, position the comb (with the adjusting lever on your clipper because your blades wont work, then:)
1.
If you move the comb downwards using the lever on the side of your clipper you will get a shorter cut, if you move it forward you will get a slightly longer cut. If your clipper makes a horrible noise, I believe there is a plastic adjuster on the side that you adjust with a flat head screwdriver. This adjusts the springs inside the clipper which effects how central the cutter moves from side to side. Adjust this while the clipper is running. You want your blades to be as central as posssible. If they still do not work, you may need your blades sharpened. This costs £5.90 incl. VAT & Postage www.sheareaseltd.com You could send your clipper to them as well and ask them to re align your blades after sharpening and they'll just charge the extra postage. (extra £5)
Hope this helps!
2.
If you mean how to hold the clipper with the blade relative to what you are clipping. You need to hold the clipper so the teeth are not pointing into your project, but not pointing away from it either. Keep the comb parallel to your project. With human hair, cut against the grain, with an animal cut with the grain!
Hope This Helps!
Jun 18, 2010 | Wahl Magic Clip Clippers Hair Trimmer
Runs if tipped to the right. Not if tipped to the left
check the electrical cord at the clipper connection by bending the electrical cord at clipper end with the clipper on if the clipper stops the electrical cord is broken in side.if this will dose not locate the problem, the next possible problem will be the coil inside the clipper the coil has a broken field winding wire. Have a Wahl clipper repair shop repair the problem.
Mar 30, 2010 | Wahl Magic Clip Clippers Hair Trimmer
New clippers
what type of hair clipper are you looking for. mannyssharpening.com has very good warranty they fix what they sell
Sep 26, 2009 | Wahl Super Taper Hair Clipper 2000 Hair...
I have an Oster A5 it is 2 years old. What is the secret to putting the blade back on? The directions are vague and just mention that the motor should be turned on and then snap the blade in place. No...
Hi! I'm a groomer...
Slide your blade onto the spring loaded hinge. Turn your clipper on, and snap the blade down on the running blade drive. You'll probably have to push it down slightly, for it to catch. This should work.
Debbie
Apr 04, 2009 | Andis 01690 Hair Trimmer
Clippers jam and won't cut when trying to use attachments
OIL THE CLIPPERS AND CLEAN THE HAIR OUT REALLY GOOD.
Jan 11, 2009 | Oster 76076-010 Hair Trimmer
Oster classic clipper smoke after a few use not electrical smoke
How do I do maintanience on my clipper to keep them running good
Apr 07, 2008 | Oster 76076-010 Hair Trimmer
Hair Clippers not clipping
for Shorty8 adjust power screw,check connector fork,if too tight losen tension inside the clipper
Aug 28, 2007 | Andis 01690 Hair Trimmer
Norelco 8883 XL Electric Shaver Logo
213 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Bruce Foote
Level 1 Expert
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
