Question about Estate TAWX700JQ Top Load Washer
Agitator screw what size screw is use to hold the agitator?
    President:
  • 1,314 Answers
7/16
Posted on Mar 30, 2008
Hello, I have an Amana top load washing machine and the agitator just came off in the unit while it was loading with water. I can see the gear that the agitator is supposed to sit on and I can hear what I...
there is a plastic hub the agitator sets on , you will have to get the plastic hub out of the agitator , that goes over the shaft then a screw with an o ring holds that down, then just push the agitator back onto the hub, I should go pretty easy if not turn it a little and try again
Jul 01, 2017 | Amana NTW5205TQ Top Load Washer
/There is a gold chain necklace wedged under the agitator. How do I loosen the agitator so it will lift up just an inch or so?
remove center downy cap on top of agitator get a 7/16 socket and long extension and hold base of agitator and loosen screw in center of agitator pull up agitator out of washer...
Jan 27, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Kenmore 92283800 agitates sometimes if not to many clothes are in the washer...but I can hold the agitator and it stops completely
Welcome to FixYa.
Based on your description, the problem is likely worn agitator dogs/gears. The new dogs alone part # 80040 or what I'd recommend, part # 285751 as a kit with new hub too.
These are common and available at most brick & mortar parts depot's as well as on-line vendor's such as "repairclinic.com" or "searspartsdirect.com" to name a couple.
You`ll need to remove the top of the agitator to replace them.
To remove the top cover of the agitator, it should lift off by prying up gently with a flat screwdriver or puddy knife.
Under this cap there actually is a screw/fastener,( bolt ) it just may or may not look anything like a typical screw. It could be a plastic piece with a square center and with the aid of a large flat screwdriver inserted in this location pressed into one of the corner`s in the square center (as to hold it still or turn it,
I usually hold it still while turning the agitator) at the same time as holding the bottom of the agitator, turn it counter-clockwise and it will come loose. It may be the bolt style and in that case just remove the bolt and lift it out.
On Kenmore full size washer`s built by whirlpool there are several types, ones with a 7/16", 1/2" or 9/16" bolt holding it in place, and the type I described.
This is a link to a helpful "how to" video...it may have slight differences to your washer, but essentially the same.
http://www.youtube.com/watch?v=0GQh8JLqVv8&feature=related
Thank`s for visiting FixYa. Good luck and let me know if I can assist you further.
Regards,
Macmarkus :)
Dec 18, 2010 | Kenmore 24032\24036 Top Load Washer
I have a whirlpool top loading washing machine. The agitator seems to be in 2 parts, the bottom part is agitating, but the top part barely moves. Is this normal? Or, is the agitator broken?
Welcome to FixYa.
These are common and availble at most brick & mortar parts depot's as well as on-line vendor's.
Under this cap there actually is a screw/fastener,( bolt ) it just may or may not look anything like a typical screw. It could be a plastic piece with a square center and with the aid of a large flat screwdriver inserted in this location pressed into one of the corner`s in the square center (as to hold it still or turn it, I usually hold it still while turning the agitator) at the same time as holding the bottom of the agitator, turn it counter-clockwise and it will come loose. It may be the bolt style and in that case just remove the bolt and lift it out.
This is a link to a helpful a amatuer "how to" video...it may have slight differences to your washer, but essentially the same.
http://www.youtube.com/watch?v=V5wIN1J70-Y
macmarkus :)
Aug 13, 2010 | Kenmore 15944 Top Load Washer
Kenmore 80 Series does not agitate.
Hello, Welcome to FixYa.
The model and serial number tag will be under the lid at the back of the "lip/shroud" as you look from the front.
Based on your description, the problem is likely worn agitator dogs/gears. The new dogs alone part # 80040 or what I'd recommend, part # 285751 as a kit with new hub too. These are common and availble at most brick & mortar parts depot's as well as on-line vendor's.
On Kenmore full size washer`s built by whirlpool there are one 2 types, ones with a 7/16" bolt holding it in place, and the type I described.
macmarkus :)
Jul 15, 2010 | Kenmore Washing Machines
Agitator drive shaft pulls out of transmission LAT2600AAE
I believe there is a set screw or screw that goes throught the agitator to the shaft.
Mar 07, 2010 | Whirlpool LSB6200PQ Top Load Washer
How can I remove the agitator inside my washer, there is no screw at the top and it wont just lift up and come off.
HI jescatlicea,
To remove the agitator on your washer you must first remove the top cover of the agitator, it should lift off by prying up gently with a flat screwdriver or puddy knife. Under this cap there actually is a screw/fastener, it just doesn`t look anything like a typical screw. It is a plastic piece with a square center and with the aid of a large flat screwdriver inserted in this location pressed into one of the corner`s in the square center (as to hold it still or turn it, I usually hold it still while turning the agitator) at the same time as holding the bottom of the agitator, turn it counter-clockwise and it will come loose.
Hope this help`s you to get your agitator off without too much agitation...;)
On Kenmore full size washer`s built by whirlpool there are one 2 types, ones with a 7/16" bolt holding it in place, and the type I described. They are by far the most common, although for short period`s in the past kenmore had full size washer`s built by GE as well as Frigidaire/WCI.
Thank`s for visiting "fixya". Good luck and let me know if I can assist you further.
macmarkus :)
Jan 27, 2010 | Kenmore Washing Machines
Agitator and base came off/loose in wash
If your agitator is blue, and rather short........There should be a small hex head screw about 1/2 way down that holds the agitator on the transmission shaft. Check in your wash basket for the screw, or part of the screw if it broke off. You will see a divot on the agitator where the screw is recessed.
Jul 10, 2009 | Maytag Washing Machines
Loose agitator Maytag LAT2600AAE
Look toward the bottom end of the agitator. There should be a small indentation where a 10mm screw is. This screw holds the agitator the the transmission shaft. Sometimes the screw works loose and needs to be tightened.
Dec 17, 2007 | Whirlpool LSB6200PQ Top Load Washer
Estate TAWX700JQ Top Load Washer Logo
Top Estate Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
