Question about Vacuums
I am trying to disassemble a Eureka Mighty Mite model 3130a. I cannot get the back part at the wheels to disassemble.
3 Suggested Answers
SOURCE: How to change the belt
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=700499
Generic problem for all Vacuums
Posted by Sawpit1 on Jun 23, 2008
How do I change the belt on a Eureka Mighty Mite II.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Normally the Mighty Mite II does not have a belt unless you have the model with the turbo head and then I believe it is a geared belt and then you can pup the belt from your local vacuum cleaner dealer or the Eureka factory parts dept. there are 2 to 4 screws on the bottom of the turbo head and then I believe the top will come up and then you can get to the belt. The average belt change is every year if it is a geared belt for the best cleaning or if you have a flat belt it is every 4 to 6 months. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service 1-800-282-2886
Customer Service Dept
Electrolux Home Care Products
P.O. Box 3900
Peoria. IL 61612
Hours of Operation
Monday thru Friday 8:00am to 7:30pm CST
Saturday and Sunday 10:00am to 6:30pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 24, 2008
  • 21 Answers
SOURCE: I would like to disassemble my eureka altima to clean brushes
The Altima line has 2 screws on the hood (part where the knob is that says high carpet and low carpet) that you remove with a philips head screwdriver then you just lift the hood of the vacuum
Posted on Jul 23, 2009
How to download an owners manual or sanitaire red mighty mite model 3683?
There really isn't much to know about this vacuum in the owner's manual. It has attachments, doubles as a blower by attaching hose to back end. Practice the usual safety standards like don't use near water. Ck the prefilter on bag changes. That's about it.
Sep 01, 2014 | Electrolux EUR 3683 - Sanitaire Commercial...
Eureka Mighty Mite 3670 Bagged Canister Vacuum just stopped working
Should be under warranty. Take it to a warranty center for repair
Jan 05, 2014 | Eureka Mighty Mite 3670 Bagged Canister...
Need to replace belt in eureka envirovac model 4470
You must remove the screws that hold the top cover onto get to the belt. Remove top cover then remove brush roll to install new belt. Replace belt at least twice per year for proper cleaning.
Oct 26, 2013 | Eureka High Filtration s Mighty Mite...
Eureka mighty mite
THE INTAKE TUBE IS BLOCK PLUGGED...! FROM BOTTOM OF VAC SCREWS REMOVE WHERE TUBE IS AND CLEAR OUT BLOCKAGE REVERSE PROCEDURE FOR RUN.
Jun 14, 2013 | Vacuums
Brush stopped rotating and little suction on unit.
Even though the brush is spinning, you probably need to replace the belt2_bing.gif because it is stretched. It is probably slipping on the beater bar..
Jim
Nov 28, 2009 | Eureka High Filtration s Mighty Mite...
How to change the belt on a Eureka Mighty Mite II.
P.O. Box 3900
Peoria. IL 61612
Hours of Operation
Go Ahead. Use Us.
Jun 23, 2008 | Vacuums
Won't work
http://geeksquad.fixya.com/ThreadView.aspx?prdid=12151&thid=646957
Won't work (by 2 users)
Posted by AndiR on Jun 04, 2008
My Eureka Mighty Mite 3670 Bagged, was working fine, and we unplugged it to switch to another outlet in another room and it just stopped. We tried several other outlets and it just won't turn on. We thought maybe it got hot because we had been using it for a while and we let it rest for a while and then changed the bag just to be sure, although it was not full. But it still will not turn on. Any ideas……X
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
OK
1 Other User Has the Same Problem Comment by Guest, posted on Jun 06, 2008 I had the same problem today. Have a 9 amp model I bought 10 years ago which I never use. It has been sitting for years. Today put in new bag and ran it continuously for 45 minutes. After I turned it of it wouldn't restart. Tried another outlet and wouldn't restart. Felt canister at back and motor housing was hot so I thought I might need to let it cool down. After letting vacuum cool off for 10 minutes it restarted. All I can assume is that the vacuum has a built in overheat sensor on the motor. Hello,
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Eureka Mighty Mite #3670 Bagged Canister. I have the same type Mighty Mite Canister and from what you are saying the must be some type of heat sensor that is shutting off the motor to protect it from excessive heat. Al of the old ones have had lower amps and did not needs the heat sensor but once the bag is full and the filter clogged; they will shut down as well. They all use a plastic hose to clean with and that even gets hot sometimes. So I suggest that you get an owner’s manual from the manufacturer on you particular model so that id if happens again, you will be prepared. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Customer Service Dept for U.S.
P.O. Box 3900
Peoria. IL 61612
5855 Terry Fox Way
Mississauga, Ontario L5V 3E4
Hours of Operation
Go Ahead. Use Us.
Jun 04, 2008 | Eureka Mighty Mite 3670 Bagged Canister...
Vacuums Logo
135 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
