Need replacement rear panel speaker ports is
Need replacement rear panel speaker ports is this available? for aerocool extremengine 3T case
    Sergeant:
  • 183 Answers
No, it's not possible. you have to purchase a new one
Posted on May 21, 2010
Front 4 usb ports and microphone and headphone jacks don't work but the rear usb and speaker jacks do work. I've had the computer new since 2009 and they have never worked.
it sounds to me like the wires from the front panel connectors are not connected to the motherboard inside the computer case, open the case up find the front connectors wires inside and find out if there are any connectors on the motherboard to plug them into.
the reason the rear ones work is because they are soldered directly to the motherboard.
good luck.
Jun 28, 2014 | Acer Aspire E380 ASE380-UD500A PC Desktop
My speaker jack broke off inside my audio input in the back of the computer. I want to use the thermaltake case's front usb and audio out/mic in jacks, but they don't seem to get power or work. My drivers...
> Have you removed the broken jack from the rear end of the pc ?
> Are you trying to use the audio ports on the front panel ?
> if you are trying to use the audio port on the front panel you will first need to remove the piece of the broken jack stuck in the rear port - cos you can take an audio out line either from the front OR the rear any one
Oct 22, 2013 | Thermaltake Mid-Tower VL10001W2Z Element G...
How do you setup the speakers?
you will need to connect your speakers to your computer then you will need to install them to your computer if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
then you are ready to position your speakers if you have more than 2 you might need to select stereo
Speakers can be placed on floor stands, hung on wall brackets, or placed on furniture. Subwoofers typically sound best in room corners or near the left- or right-front speakers.
The front three--left, center, and right--speakers usually sound best when positioned with their tweeters elevated to the same height as a seated listener's ears. In any case, try to keep the center speaker near the same height as the left and right speakers.
You can place speakers on shelves or on/in a low cabinet or entertainment center. Some speakers are better suited to this arrangement than others. "Acoustic suspension" sealed satellites are the most appropriate. Next best are ported speakers--as long as the ports are located on the front of the cabinet. However, speakers with rear-mounted ports won't perform at their peak when placed inside a piece of furniture.
As for the rear-channel surround speakers, they usually sound best when positioned three or more feet higher than the front speakers. However, high-fidelity DVD-Audio and Super Audio CD music will sound best when surround speakers are placed at the same height (ear level) as the front speakers.
Hope this helps
Jul 13, 2011 | Labtec Spin 55 Computer Speakers
How to use speaker in computer?
Does your motherboard has an onboard sound card? If it has then read your motherboard manual especially the audio section of the manual where the topic is described how and where to plug in which audio jacks coming out from you speakers (speaker system) to which part of the external audio ports usually located at the rear end of your computer case. You need to install the sound card drivers to activate audio properties of your computer of course, to actually use the speakers.
You can also use the front panel audio port of your computer case where you can connect your speakers to as well.
In case your motherboard did not come up with sound card installed you can always install an external sound card and then connect the speakers to the proper external audio ports of the card. Just read your motherboard or sound card manual. It is all there.
Jun 03, 2011 | Audio Players & Recorders
Hi need a set of temp sensors, the extension cables and the tape for sticking the sensors to the individual components. Where can I purchase these items.The unit is a Aerocool Gatewatch.
Amazon sells it.
http://www.amazon.com/AEROCOOL-GATEWATCH2-BK-TEMP-MONITORING-PANEL/dp/B000MPG7NW/ref=sr_1_12?s=electronics&ie=UTF8&qid=1304319712&sr=1-12
May 02, 2011 | Computers & Internet
Yes, you need to purchase a sound card.
Mar 22, 2010 | Computers & Internet
The front 3mm port is disconnected and I don't know where to hook it back up. I can't tell from the manual.
The front 3mm ports are for mic input / headphones output. The pin connectors are as follows. You need to use the JAudio header, which are in the lower-right corner of the motherboard closest to the front of the case when it's installed.
This header has 14 pins, and allows user to connect the front audio out put cable with the PC front panel. It will disable the output on back panel audio connectors.
Within this header, pin 1 is in the lower left corner, and pin 14 is in the upper right corner, like this:
2 ... ... ... 14
1 ... .. ... 13
The pinouts are:
1 Mic in/center
2 Ground
3 Mic power/Bass
4 Audio power
5 Right line out/Speaker out Right
6 Right line out/Speaker out Right
7 Reserved
8 Key
9 Left line out/Speaker out Left
10 Left line out/Speaker out Left
11 Right line in/Rear speaker Right
12 Right line in/Rear speaker Right
13 Left line in/Rear speaker Left
14 Left line in/Rear speaker Left
Aug 27, 2009 | Biostar P4M800-M7A Motherboard
Using headfones while having rear ports for speakers
This MotherBoard has a special software that comes with it to handle all the sound related stuff. If you install this program it should be easy to control the sound then.
Mar 01, 2009 | MSI K8MM-V Motherboard
Not sure how to do proper instalation for this product.
Usually
speakers are connected to.
On rear of case will be either 3 ports in line or 6 in a group each has a different color and unless you have multiple speakers which require to be set up from diagram that came with them
standard speakers plug into the Green port
Oct 13, 2008 | Inland ProSound 1000 Computer Speakers
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
