Question about Sony Playstation 3 (PS3) Console
Audio but no video
I was trying to switch from HDMI back to av but somewhere i lost video. I tried to put it back on HDMI but I only have audio. Please Help.
  • MOBILTEK Mar 31, 2008
    I WAS MESSING WITH THE SETTINGS AND SWITCHED IT TO 1080P. I STILL HAVE GAME PLAY BUT NO VIDEO WHEN IN THE PS3'S MENU SO I CANT SWITCH IT BACK. HOLDING THE POWER FOR 4 SEC HASNT HELPED. ANYTHING ELSE TO TRY?
    Problem Solver:
  • 22 Answers
PS3 is The amazing device by sony but it has some common problems like sound, video/picture problem etc.... Good news is that these all problems can be repaired with the help of DIY Guides, one such guide available at PS3 Repair Blog
Posted on Mar 13, 2009
  • 182 Answers
When the ps3 is in standby, press and hold the power button for over 4 seconds, it runs the optimal screen settings for the ps3. hope this helps
Posted on Mar 30, 2008
SOURCE:
I am trying to playback videos on my JVC Everio Camcorder using the colored AV cords. I hear the audio coming through my TV but there is no video/picture. I have tried adjusting the settings and tried...
First, set [SWITCH TO ANALOG I/O] to [OUTPUT]
then turn off the (camcorder) unit.
After you connect the cable (from AV connector to the TV's AV Input Connector (accepting the 3 color cables), set the TV to VIDEO mode, selecting the AV input (from your Camcorder).
Then start your playback on the camcorder ...
slide the mode switch to select the (video) mode (instead of the picture/photo mode)... press the PLAY/REC to select the playback mode, and select the desired files/frames to play.
Hope this works for you. Have you tried using the HDMI mini connector instead ? (same process, just set your TV to accept input from the HDMI input)
Jun 03, 2014 | Video Cameras
Can you hook up a blu-ray player to a Samsung TX-R2765 TV? I don't see an HDMI plug.
HDMI to AV Converter Composite 1080p HDMI to 3 RCA Audio Video AV CVBS Adapter HDMI 2 AV Converter Supports PAL/NTSC for HDTV DVD Amazon com HDMI to AV Converter Composite 1080p HDMI to 3 RCA Audio Video...
Nov 19, 2017 | Televison & Video
My ps3 will not put out any audio or video
Have you changed your settings from hdmi back to normal you should try both hdmi and scart or av on your tv, if this doesn't work then you need someone with a ps3 that works (you need your ps3 and a spare tv) and you can copy what theres does but you need to be very precise or look on you tube to see how to restore your ps3 back to the factory settings. I hope this helps mines done the same and it worked for me.
Apr 04, 2012 | Sony PlayStation Video Game Consoles &...
I properly connect my ps3 and switch it on but it does not show anything on the screen what may be the problem
Hook up a/v cord and have it on standy (red light)...push and hold power button for about 7-10 seconds or until you hear it beep......Let off...wait another 5-10 seconds.....is it on now????? if not your audio/video card in it might have went out....
Apr 01, 2012 | Sony Playstation 3 (PS3) Console
Hi, please please please help..... I have just bought a new Panasonic 42 Inch Full HD 1080p Widescreen LCD TV TX-L42U2B from Argos, I also bought the HDMI cable they recommended on the same website...
hello chis, it may the ps3 your having trouble with connect ps3 to hdmi 1 reset the ps3 by doing this. press and hold the standby button on the front of the ps3 you will hear 1 bleep then 2 short bleeps after the short bleeps release the button this will reset the display setting on the ps3 you should get1080p if this dfon't work feel free to get back to me thanks
regards
shaun
Jan 08, 2011 | Sony Playstation 3 (PS3) Console
How to get DVD to switch from Analog to HDMI ?
Read this: http://reviews.cnet.com/av-receivers/denon-avr-888/4864-6466_7-32740020.html?messageID=2561222 Including the comment below it. Also troll here; http://www.avsforum.com/avs-vb/showthread.php?t=944567 Then join, and post your issue. Guaranteed someone there can help.
Jun 09, 2009 | Denon AVR888
Reset HDMI on non HDMI tv
Put The HDMI Into your old tv then switch it to AV MULTI then put the av in then it will ask if you want to keep these setings then select yes and then put the AV MULTI into your new TV.
Mar 21, 2009 | Sony Playstation 3 (PS3) Console
PS3 HDMI & AV outputs not working?!?!?!?
change the sound output to HDMI? does the sound work on just like a normal tv channel?
Sep 03, 2008 | Sony Playstation 3 (PS3) Console
I have a phillips 26pf5520d/10 model number, ive connected a dvi cable and hdmi cable to my playstation 3 and tv, but i have no sound, please any ideas. many thanks steph
I'm assuming you mean you have HDMI coming out of the PS3 and going in to the DVI port on the back of the TV, via an adaptor or cable with a different connector on either end.
I have the same TV, you need a separate audio connection between ps3 and tv. HDMI can transmit audio and video but DVI (which is what the TV has) can only do video.
You'll need a 2 x phono female to 3.5mm jack male adaptor cable. like this one to make the audio connection.
you could also try this adaptor but its a bit big and therefore may not fit into the space available.
after getting an adaptor do this (keep your original setup the same)
1. Put the ps3 AV cable into the back of the ps3. 2. then connect the red and white plugs (ignore the yellow) from the ps3 AV into the adaptor (discussed above). 3. then connect the 3.5mm jack (from the adaptor) into the small audio port right next to the DVI port on the back of the TV (I believe its called 'DVI Audio')
I've not tried this and I don't have a ps3, yet, but in theory it should work, as long as the ps3 will send audio to the av output at the same time as to the hdmi output.
if it works, then post a response, i'd like to know for the future.
good luck
Aug 01, 2008 | Televison & Video
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
