Question about Garmin StreetPilot C330 GPS Receiver
Worn cable The cable from the auto lighter to the garmein C330 became worn and lost connection. The battery won't charge in the car but will when I connect to my computer. Can I get the wire repaired at Geek Squad or similar repair facility since the Garmin itself is working fine? Joseph
  • Anonymous Nov 17, 2008
    Unfortumately, my dog chewed the cable in two, on my Garmin, which I keep in my car. I couldn't believe it! Happened whle I was drivng, and I didn't even hear anything. Now the cable must be replaced!
    I should goto Best Buy? (ICiricuit City no longer exists, at least in SF Bay Area). Thank you ,Maureen in Fremont, CA
You can buy a replacement cord at Best But, circuit city etc.
Posted on Mar 31, 2008
SOURCE:
My BMW won't start
Home >Hyundai >2009 Hyundai Genesis > i have a lot... 009_genesis_1131116.jpg Problem with the 2009 Hyundai Genesis I have a lot problems when i need to start... Ads by Google Download Google Chromewww.google.com/chromeA free browser that lets you do more of what you like on the web
By mazingerdavi on Sep 04, 2011
i have a lot problems when i need to start the engine in my genesis 2.0 coupe why is this,,i took the car to the dealer but cant find a problem,they say battery is ok
The national auto parts chains (AutoZone, Pep Boys, and Advance Auto Parts) will hook up a
diagnostic tool to your car to perform a Charging System diagnosis for free - its an easy
way to exonerate & differentially diagnose your Alternator/Battery/Voltage Regulator.
Priority Action Part Type Cause
1 Inspect Battery Battery Discharged or Faulty.
2 Inspect Battery Cable Corroded, Broken, Shorted or Poorly Connected Battery Cable.
3 Inspect Fuel Filter Clogged or Dirty Fuel Filter.
4 Inspect Distributor Cap Distributor Cap Cracked or Burned contacts.
5 Inspect Coil - Ignition Faulty Ignition Coil.
6 Inspect Wireset Worn, Damaged or Faulty Spark Plug Wire(s).
7 Inspect Spark Plug Incorrectly Gapped or Fouled Spark Plug(s).
8 Inspect Starter Starter Motor Faulty.
9 Inspect Fuel Pump Low Fuel Pressure.
10 Inspect Solenoid Switch Faulty Starter Solenoid Switch.
11 Inspect Relay - Fuel Pump Faulty Fuel Pump Relay.
12 Inspect Fuel Injector Pressure Regulator Faulty Fuel Injector Pressure Regulator.
13 Inspect Ignition Switch Improperly Connected or Faulty Ignition Switch.
14 Inspect Starter Motor Faulty Starter Motor.
15 Inspect Fuel Injector Dirty or Worn Fuel Injectors.
16 Inspect Fuel Pump Strainer Clogged or Dirty Fuel Pump Strainerat.
17 Inspect Engine Control Computer Incorrect Operating Information Being Delivered and Sent From The ECC.
18 Inspect Fuel Tank Fuel Tank Empty.
19 Inspect Carburetor Carburetor Flooded or Faulty Choke.
20 Inspect Distributor Worn, Loose, or Incorrectly Installed Distributor.
21 Inspect Distributor Rotor Burned Distributor Rotor contact
Sep 04, 2011 | 2007 BMW 525xi Sedan
My IBM R40 laptop is shutdown auto why after
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Jul 31, 2011 | IBM ThinkPad R40 2723 Notebook
I have IBM R40 and it shutdown auto after unplug it from switchboard
Jul 31, 2011 | Computers & Internet
2001 ford super duty 250- dash lights go dim whan I turn on headlights.
This may be an indication of a poor battery connection, a slipping (worn or cracked) serpentine drive belt, or a bad battery.
  1. Corrosion around the battery cables prevents the alternator from replenishing full power back to the battery
  2. A bad drive belt tends to slip around the alternator and like in #1, doesn't replenish full power back to the battery
  3. A bad battery with a dead cell won't accept a full charge.
Not mentioned above and less likely is a bad alternator. If you don't have a bad battery connection or a worn drive belt, I'd recommend having the electrical system checked out (most chain auto parts stores will do a free check).
Jul 17, 2011 | Ford F-250 Super Duty Cars & Trucks
Battery won charge clutch squeals
BATTERY WONT HOLD CHARGE COULD BE BLOWN ALTERNATOR FUSE OR FUSE LINK.DAMAGE OR BROKEN ALTERNATOR WIRES.BAD BATTERY CABLES IF BATTERY CABLES BEEN ON CAR FOR A LONG TIME REPLACE THEM.BESURE TO TURN OFF RADIO BEFORE REMOVING BATTERY CABLES SO YOU WONT LOSE PLAYING CODE. WHEN YOU DEPRESS CLUTCH AND YOU GET A SQUEAKY NOISE.YOU COULD HAVE WORN DEFECTIVE OR BROKEN RELEASE BEARING OR WORN BROKEN PRESSURE PLATE SPRINGS.
Feb 13, 2010 | 1994 Mitsubishi Eclipse
How to charge battery?
In most cases you use your cigarette lighter that came with your unit to charge the battery. I myself have a home ac to dc converter to charge mine with.
Dec 04, 2009 | Garmin StreetPilot C330 GPS Receiver
My garmin c330 will not run it had said battery low. Even in car lighter it will not stay on. When I push the power button it will power up and shut down right away
The Garmin C330 has an internal Lithum Ion battery that needs to be recharged. Use your USB cable that came with the device to connect it to you computer. The computer of course has to be on. Leave it connected to the computer all day or over night. After that time it should be charged completely. If it is not charged after that time the unit will have to be returned to Garmin to have the battery replaced.
Apr 02, 2009 | Garmin StreetPilot C330 GPS Receiver
I can't charge my GPS while I am in the car
Verify that the car cigarette lighter outlet is working. Do you have something that you could plug into the lighter like a light?
With the car running plug the Garmin into the cigarette lighter outlet. Does it come on without pushing the ON button? If the answer is no then there is either a problem with the cable or the cigarette lighter outlet. It should come on by itself if the lighter is working. Also are you using Garmin cables and DC adapter?
Jan 31, 2008 | Garmin StreetPilot C330 GPS Receiver
GARMIN STREET PILOT C330
take off the front face plate. hit the reset button on the right. charge it. I've got a 320. Same thing happened. On the 320 if you look closely there is a fingernail shaped indent on the inside of the square colored face plate. just pull the face plate towards you and it will come off with very little effort.
Feb 20, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
44 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
