Question about Radio Shack Pro-2096 Base Scanner
Dyslexic handicapped needs help programming the RS Pro-96
I am a 73 y.o. with dyslexia. I purchased the RS PRO-96 Scanner 4 days ago.
I find the owners manual overwhelming to understand.
I need step-by-step instructions in order to input the frequencies in the order I want.
Example: Bank: 1-Maryland aircraft, 2-Maryland State Police, 3-Baltimore County Fire and police, 4-Baltimore City Fire and Police.
Question 1- Can you assist me?
Question 2- Will programming above frequencies interfere with the Pre-Programmed frequencies?
Sincerely,
Jim C.
    Problem Solver:
  • 6 Answers
Jim Not sure if my scanner and yours are exactly the same, but find your specified bank and press MAN, then PGM, and then enter your frequency. For talgroups (digital), press MAN, then PGM, then TRUNK, then enter your talkgroup ID number. Hope this helps...
Posted on Jun 15, 2009
  • 127 Answers
Hello Jim
I will try my best to help you. Go to manual and push till you go to the number you wish to use, If the numbers on it or all 00000000 you can put what frequency # on it. as long as it is all 0000000 you don't have a thing on that # to interfere with. When you get the # you wish to use put the number in, if your # has a . in it you will need to put the. in hit enter then prg. i[email protected]
Posted on Apr 17, 2009
SOURCE:
I have a Pro 96 that when I turn it off and turn in back on the screen says '"DSP LOAD PC / IF Port Flash Men" I've tried turning it on and off a couple times and also tried resetting it a few times...
Do you have something plugged into the side of the radio where the PC/IF port plug is? It sounds like it's looking for an update, and you need the RS cable a the 96 software in order to do that. Google it on radio reference.
Jan 02, 2014 | Radio Shack Pro-96 Scanner
The RS Pro 96 digital scanner radio locks up. The display comes on but the keyboard is nonfunctional. Nothing on the keyboard will work. Resetting the unit does not help. The lock function is not on. Not...
Check the small battery on the circuit board. Another possibility is that you don't have enough battery voltage to operate the unit. Even external power supplies may not produce enough voltage if the main battery is bad.
Aug 22, 2010 | Radio Shack Pro-96 Scanner
Pro 96 scanner only scans bank 3 and 4. i am sure
While it's scanning, press any keyboard number (0 thru 9) to activate/deactivate scanning on the corresponding bank.
Need the full manual for your scanner? You can download/print it here:
http://support.radioshack.com/support_electronics/doc71/71778.pdf
For a comprehensive database of active frequencies and systems in your are,visit:
www.RadioReference.com
BillB
Jan 09, 2010 | Radio Shack Pro-96 Scanner
Programing Pro2096
There is a Yahoo GROUPS for this scanner and the PRO-96 - join and they can help you out-okay?
Aug 11, 2009 | Radio Shack Pro-2096 Base Scanner
Pro-96 Scanner Not Receiving Philadelphia Fire Department Radio
Well I would check up on their current frequency. They may have changed frequencies overnight. It does happen. Here is a handy website to check out. Look around and hope it helps you.
http://www.radioreference.com/apps/db/
Mar 03, 2009 | Radio Shack Pro-96 Scanner
Programing Radio Shack Pro 106 scanner
As an employee of Radioshack, I have found that you can use scancat lite to progrom the pro 106. Programing conventional trunking systems work well with this system. However after three days of frustration I did find out how to program the digital channels. After programing the conventional channels in, you will have to program the digital channels in manually. Do not program the group id's into the scanner, just leave it in a "wildcat" search. When the group Id shows up while listening to the scanner push enter and that will program the Id in. When you got the all the Id's that you need, then program the scanner to a private mode, this will let you to listen to just what you want to listen to. I am still working on finding better solutions.
Dec 29, 2008 | Radio Communications
Battery holder for Pro 95 scanner
Your pro 95 takes the same yellow rechargable battery pack as the pro 97. It is available at the site listing below. It is their #100-006. It cost 5.99 plus 10.95 shipping. I ordered it 4 days ago and got it two days ago. You may be able to save on shipping by calling them and requesting some sort of slower shipping.
https://www.greamerica.com/shop/cgi-bin/cp-app.cgi?usr=51F4658914&rnd=7881653&rrc=N&affl=&cip=71.106.150.99&act=&aff=&pg=prod&ref=100-006&cat=Radio+Scanner+Accessories&catstr=HOME:Radio+Scanner+Accessories
Nov 07, 2008 | Radio Shack Pro-95 Handheld Scanner
Pro 96 Rebanding Issue
http://www.radioreference.com/forums/showthread.php?t=100208&highlight=custom+tables
You need to program custom tables into the Pro-96. Visit the link above.
ChLO ChHI Step Offset Base
440 559 25.000 440 851.025000
000 719 25.000 0 851.012500
720 759 25.000 0 848.000000
815 831 25.000 0 846.625000
958 958 25.000 958 868.975000
961 1022 25.000 0 843.400000
Mar 15, 2008 | Radio Shack Pro-96 Scanner
I have a pro 96 scanner that i just cant seem to program. how can i do it?
Call your local Radio Shack. They can either program it for you or suggest someone who can.
Dec 19, 2007 | Radio Shack Pro-96 Scanner
Radio Shack Pro-2096 Base Scanner Logo
188 people viewed this question
Top Radio Shack Radio Communications Experts
Robert McClure
Jason
Perry Mellott
Perry Mellott
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
