Question about Casio FX-115ES Scientific Calculator
How do I calculate exponential functions?
I have to calulate things such as f(31) = 13.49(.967)^31 - 1. How would I do this? In my math book it says that scientific calculators have a y^x key but I don't see one. PLEASE HELP ME!!!
The y^x button is right next to the x^2 button. It is labled with an x raised to a square box (which I will write as x^box). Thus, if you enter (for example)
2 x^box 5 = 32
Posted on May 27, 2008
I need help on finding the EE or E in casio fx-115es
im taking chemistry is a easy steps to follow this when solving exponents
Posted on Sep 18, 2008
6ya staff
SOURCE:
I am trying to calculate continuous interest and am unsure how to use this calculator to do so.
Continuous interest calls for an exponential function. Read your theory and use the exponential function key on your calculator: usually marked e, e^x. It may also be the shifted LN key.
Mar 29, 2016 | Texas Instruments TI-36 X Solar Calculator
What is wrong with my calculator? invNorm Error:Domain
DOMAIN ERROR:
- You specified an argument to a function or
instruction outside the valid range. This error is
not returned during graphing. The TI-84 Plus
allows for undefined values on a graph.
- You attempted a logarithmic or power
regression with a LX or an exponential or power
regression with a LY.
- You attempted to compute GPrn( or GInt( with
pmt2 < pmt1.
Mar 16, 2015 | Texas Instruments TI-84 Plus Calculator
How do I express 5765 in exponential form?
Hello there,
First you need to find the P'rime factors' of 5765 which are 5 * 1153
Therefore the Exponential form of 5765 is 51 x 11531
You MUST find the PRIME FACTORS
(That means the two Prime numbers that when multiplied together gives the answer.
. Go here to see how. to 'manually calculate like we used to do it,
http://www.calculatorsoup.com/calculators/math/prime-factors.php
Nowadays just search for 'Prime Factors Calculator' on your search engine.
Sep 10, 2014 | Office Equipment & Supplies
Simplify logarithmic and exponential expressions
Simplifications of logarithmic expressions are based on the properties of logarithms
log(1)=0
log(a/b)=log(a)-log(b)
log(a^n)=n*log(a)
log_b(x)=log(x)/log(b)=ln(x)/ln(b)
As to exponentials you have
e^(0)=1
e^(-a)=1/(e^a)
(e^a)*(e^b)=e^(a+b)
(e^a)^n=e^(na)
That is the gist of it.
But I do not think that your calculator is able to handle any scientific calculations.
Sep 26, 2013 | Casio Model Dl-250la Heavy Duty Black/red...
How to use the exp key
I think it is case of mistaken identity. There is a function called the power function. The general form of it is a*(b)^x or a times (b) to the power of x. a is just a constant factor (not equal to 0) and b is the so-called base ( also different from zero). Personnally I call this function the power function, but you find it is often called the exponential function.
The exponential function e^x is similar to the power function. The main difference is that its base is a certain irrational number called e (=2.718281828...).
What you want to do, as far as I can guess is to calculate 2000*(1+0.12)^20.
Simplify your life and set 1+0.12 as 1.12, and type in 2000 [*]1.12^20=
1.12^20=9.646293093. Multiplied by 2000, this gives you a final result 19 292.58
To enter the the power use the key marked as [X^y], [Y^x] or [^]
Jun 26, 2012 | Sharp EL-531VB Calculator
Won't Graph Exponential Function
Ok, try these two things and you should be just fine.
1.) Check your range for your graph. It is possible that the range you are using isnt large enough to show the curve. Also try using Z-fit vs Z-st. These are options that your calculator will give you once the equation is graphed.
2.) Place a parenthesis around the 2x, make sure that you and the calculator are both using the same order of operations. This move mill ensure that the calculator will multiply the variable, x, by two and then do the exponential.
This should do it!
Happy Graphing!
Jul 25, 2010 | Texas Instruments TI-84 Plus Calculator
Is it possible to get euler's number on this calculator? I am a college algebra student starting exponential functions and need euler's number to computer continuous compound interest. Thank you.
There is no key dedicated to e, the base of natural logarithm, the same as there is for pi. However you can find it as the VALUE of the exponential function e^(x) for x=1. To obtain the VALUE of e you press [SHIFT] [ln] to access e^x, enter 1 and press [EXE].
Thus
[SHIFT][LN]1 [EXE] gives 2.718281828.
If you need that numerical VALUE often you may want to store it into a variable, say E. To do that
[SHIFT][LN]1 [-->] [APLHA] E [EXE]
From experience, I know that it is not the VALUE of e that you need but the symbol e to define the exponential function. If you press [SHIFT][LN] you get a syntax error. You can never see e in a multiplication, addition, or other arithmetic operation.
In this calculator, the e is first and foremost the symbol for the exponential function. If you need to draw the exponential function of X
you press [SHIFT][LN] X. Parentheses are not needed for simple arguments as this one, but if the exponent is a complicated expression parentheses are needed.
If you mean exponential of X you type [SHIFT][LN] [X,theta,T], but if you want exponential of (x-3z+ 0.5 y^2), you must enclose the argument (the object of the function) between parentheses
[SHIFT][LN] [ ( ] x-3*z+ 0.5*y [^]2 [ ) ] [EXE].
Hope it helps.
Nov 16, 2009 | Casio CFX 9850GA Plus Calculator
Trying to use the "e" symbol on my calculator but
You are not using the correct syntax of the exponential function.
[SHIFT][e^x] ( number) .
[SHIFT][e^x] 1 EXE] gives 2.718281828
[SHIFT][e^x] [(-)] 3 gives 0.04978706837 . The (-) is the change sign to the left of the [EXE] key.
For simple arguments the parentheses are not necessay, but it is safer to use them to avoid ambiguities and erroneous results.
Hope it helps.
Oct 22, 2009 | Casio FX-9750GPlus Calculator
How do I do an inverse log function on my HP 33s calculator?
The inverse of the common log is the raise 10 to a power. the inverse of the natural log is the exponential. The log and the antilog share the same key, one is accessed directly the other as a seconf/shifted function. Same thing for the natural log (ln) and the exponential.
Oct 19, 2009 | HP 33s scientific calculator Scientific...
Does the fx-260 SOLAR do exponential calculations?
Yes it does. All scientific calculators do logs, power, roots, exponential, trigonometric functions. Most do also hyperbolic and inverse hyperbolic functions.
Hope it helps.
Aug 16, 2009 | Casio FX-260 Calculator
Casio FX-115ES Scientific Calculator Logo
1,257 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Ekse
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
