Question about iRobot 530 Roomba Vacuuming Robot, White Vacuum
My roomba stays in one spot and cirles like it's spot cleaning and it's not. It won't move around like it use toi haven't used it in some time altho it is charged.
My Roomba 535 stays in spot clean and will not go into any other mode.
Posted on Sep 04, 2010
Irobot roomba won't work
This message sometimes happens when it\'s jammed or caught. I would open it up and really clean everything out to make sure the brushes are not jammed. Also pop out the ball white/black wheel at the front and remove all the hair around the axle for this.
This almost sounds like something caught in the wheels and gears. String and the like can get caught in there. The easiest thing is to find the end of the string and try to unwind it in the direction reverse to what it caught in. I tried taking the whole Roomba apart one time, it was tough, so I don\'t recommend it unless you are very mechanically minded. FYI to everyone with a Roomba, I knew someone who expected theirs to pick up random dry cat and dog poop around the house. No vacuum can do this.
May 13, 2014 | iRobot Roomba 530 Robotic Vacuum
Roomba stays in same little area
First off Roomba is Ms. Roomba...a fine lady!
The problem with HER is it is a woman who can\'t make up her mind where to go. She has a Computer Brain and it is Programmed by the company to move in a direction and respond to its surroundings. If the Brain was disturbed, the commands are mixed at times and thus, incorrect signals make the unit jerk around. Contact the Service center and perhaps get a system test to locate the source of the problem.
Apr 01, 2014 | Roomba Irobot 4110 Floor-vacuuming Robot,...
My roomba 530 cleans just great, but it will not return to the docking station--it just stops in the middle of the floor without any warning. I push the dock button, etc. to no avail.
I sometimes have the same problem with my Roomba 530 (named Ethel). Make sure the signal transmittor on the docking station and the signal receiver on the top of the Roomba are clean. You can use a cloth or paper towel with a SMALL amount of window cleaner to run around both of these signal devices. I also like to clean the metal contacts on the station and the corresponding contacts on the bottom of the Roomba at the same time. This won't make a difference for the docking but it just assures that the vacuum will charge efficiently. If this doesn't work, you might need to have the unit cleaned professionally unless you feel comfortable about taking the unit apart and cleaning it yourself. I did this and Ethel has worked fine ever since!
If this helps, please come back and rate my suggestion!
Jun 06, 2011 | iRobot Roomba 530 Robotic Vacuum
It stays in one place spinning around. As if it is stuck on spot clean. I held down the spot clean and demo buttom until it beeped trying to reset but this did not help.
Your bump sensors are malfunctioning... The best thing to do is order a repair kit. I ordered mine from EESolutions.ca and it worked great.
Dec 12, 2010 | iRobot Roomba 560 Robotic Vacuum
My roomba stays in one spot and cirles like it's spot cleaning and it's not. It won't move around like it use to,i haven't used it in some time altho it is charged.
You need to clean the sensors.....you have pets...the dander gets on the sensors...it's a common issue. (See...you didnt even tell me you had pets!)
Mar 22, 2010 | iRobot 530 Roomba Vacuuming Robot, White...
Roomba is dancing?
You are stuck on spot clean. Try removing the battery and reset it then try Full clean.
Feb 14, 2010 | iRobot 4160 Roomba Robotic Vacuum
Hello the problem i have with my roomba is? it
the best course of action is to do as it says and remove the base plate and the wheels and clean them. Don't neglect the caster in the front when you clean the two drive wheels.
Nov 04, 2009 | iRobot Roomba 560 Robotic Vacuum
Roomba 4100 lights up when I hit the power and dies
Most likely it is a worn out battery. You can buy a new one for about $70 at iRobot.com or read their help section.
Jul 05, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
Roomba Scheduler will not dock
Clean the contact on the robot and it will dock.
Nov 16, 2008 | Roomba Robotic Floor Bagless Vacuum
Circles
Do you have it set on "spot"? This causes Roomba to start out in circles, expanding and expanding until a certain time and then returns by going in circles, making smaller circles, until it gets to its starting point.
Oct 21, 2008 | Roomba Robotic Floor Bagless Vacuum
iRobot 530 Roomba Vacuuming Robot, White Vacuum Logo
399 people viewed this question
Top iRobot Vacuums Experts
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
