Question about BFG Technologies NVIDIA GeForce 9800 GT,, PCI Express Video Card
When cold starting, my comp will run for a few
When cold starting my comp will run for a few minutes before the monitor glitches locks up and goes black. When I reset the start up screens are garbled with random characters all over. After windows loads up all goes blank. It will keep doing this until I let is sit for a few hours or I switch to Safe Mode. When in safe mode everything operates as normal safe mode. Any Ideas to what is causing this? Specs: geforce 9800 gt running on Windows Vista. Intel Core 2 Quad cpu Q6600 @2.4 ghz 64 bit os.
    Novelist:
    Scholar:
  • 103 Answers
Its a GPU problem.
It can be overcome by doing reflow technique.
You need to do following.
1. Uncover ur PC casing
2. Locate the nVIDIA PCI-E Card.
3. On the card, locate the power supply pin of GPU fan.
4. Remove the pin.
5. Switch on ur PC.
6. Still u may get scrambled display/wavy screen, but wait for 5 minutes.
7. Press reset button on ur PC.
8. Ur PC might work.
9. Switch it off.
10. Connect the power supply pin back as it is.
11. Power on ur PC.
thats all.
Removal of fan power, makes the GPU to get high heat, it a reflow technique.
Remember, not to touch the GPU portion (heat sink), as it may be in higher temperature.
Try this, it works most.
Clarifications:
gnaveendra@gmail.com
Posted on Jun 05, 2010
Security light flashing
The weather may play a factor here, many strange things happen in the winter, wait till warmer weather then monitor the light.
may be a simple glitch.
Jan 23, 2014 | Volkswagen Passat Cars & Trucks
Temp guage climbs to high nml then a minute later it drops back to low nml
air lock in the cooling system get a plastic bottle cut the bottom off turn upside down put on radiator filler and run engine cut full off water wait until all air bubbles stop then remove and put cap on see how that goes
Jan 07, 2014 | 1996 Lincoln Mark VIII
My refrigerator is a Kitchenaid KSRG25FKSS05 and still runs but not cooling. I hear some kind of relay click and then click again after about 10 seconds. Then I don't hear it click again for a few minutes....
refergerant is not causing this problem. when the comp starts up and the bottom fan also starts up and the fan in the freezer comes on / this alll happens whe the cold control said we need more cold . so it sounds like the one that won't come on is the comp . and the clicking noise is the thermal control shutting down. then when cooling tryes to restart. . the kit you need is 8201786 this is called a start device and comes with instructions .. cost about $70.00 . easy to install . mm hope this helped and thanks for the model # .. and for ysing fix ya ..mm feed back pls
Nov 17, 2010 | KitchenAid KSRG25FKSS Side by Side...
When cold starting, my comp will run for a few minutes before the monitor glitches, locks up, and goes black. When I reset, the start up screens are garbled with random characters all over. After windows...
the 9800 is a power hungry card  some modles are rated at 450 watts . your computer sounds overloaded by your card. depending what you have in your computer(DVD burner, Second hard drive ,ect you may need a 650 watt power supply to run your system with the new card . ther are alot of power supply calulators on the internet just google pc power supplies
Mar 22, 2010 | BFG Technologies NVIDIA GeForce 9800 GT,, ...
Monitor goes blank after first few seconds of turning it on...
There's an internal electronic part/s of your monitor that are cold soldered / defective. I suggest to bring the unit to an authorized service to properly diagnosed & fix the problem. best regards
May 25, 2009 | Proview PT 15.1" LCD Monitor
Black screen at start up?
IT SOUNDS THAT YOU HAVE A COLD SOLDER !! open the unit and check out the printed board and look around the transformer for a burnt or cold solder , re solder it and youre good to go , let me know , AJ
May 05, 2009 | Gateway FPD 1730 17" Flat Panel LCD...
97 altima a/c problem
check for the freon charge level.if the freon is too much definitly your compressor will turn and off every 10 seconds
Aug 07, 2008 | 2001 Nissan Altima
DSR-1800 Lost Lock
This error 07.042 means Detected the abnormal capstan speed.here what u have to do go to maintanence menu.and check the capstan speed
Sep 28, 2007 | Sony DSR-1800 DV/Mini DV VCR
Screen goes blank after a few minutes
hi if your sure that all the power settings of the screen and the comp are fine then it points to 1 reason: the screen is heating up and the automatic circuit shuts it down... try locating it some cooler place or put a vent behind it... see if it does any help if soo set it in a cool place good luck
Mar 16, 2006 | ViewSonic VP191b 19" LCD Monitor
BFG Technologies NVIDIA GeForce 9800 GT,,  PCI Express Video Card Logo
149 people viewed this question
Top BFG Technologies Computers & Internet Experts
Mark Dewar
Bill Boyd
Mister Danger
Are you a BFG Technologies Computer and Internet Expert? Answer questions, earn points and help others
