Question about Polaroid FLM-2011 Television
Poloriod tv channel lock
My tv works fine but sometimes it will lock and channel that I have watched before. Why does it do that and how do I get it unlocked and stay unlocked...Thank you
Tengo 5 tv de este modelo y no tengo control para ellos ,necesito saber que control universal es compatible
Posted on Apr 18, 2008
SOURCE:
Projection TV. DVD works. Cable often seems, "untuned". Static & un-fine-tuned sound of channel with black screen. Then, later, it will come on just fine. Sometimes, will go back to untuned status.
I would suspect your cable box first. I would unplug the power cable from your cable box and wait 60 seconds. Plug it back in and try to watch cable tv. I would also make sure the coaxial cable going from the wall to your cable box is connected properly. I would also make sure the cable going from the cable box to the tv is connected properly. Test your tv and see if it works correctly when you watch cable. If this fixes the issue you are good to go.
  • If this makes no difference use a set of new cables if you have them.
  • If this does not work then call your cable company. They may have to replace your cable box.
May 25, 2015 | Televison & Video
I'm trying 2 reset the dtv setting on my poloriod tv can anybody help ?
try channel return or
channel up or
input on the remote
I don't know which input, but you will find out
Jan 02, 2015 | Televison & Video
Picture is washed out and looks green. The TV is an lcd Flat 32" poloriod model. It is four years old. This just happened this week it's not been moved or anthing. It shows no change from channel to...
The tv Tuner board that recieving the incomming tv signal broscast is defective.Tries Websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
May 06, 2010 | Polaroid TDA-03211C 32 in. LCD HDTV
I no longer receive my local channel 9.1 (RF 9). I've tried rescanning and resetting the TV, to no avail. I've unplugged the set for a half-hour, but that didn't work either. Is there any other way to...
I have one TV that would sometimes receive one channel and sometimes not, while two other TVs received this channel just fine. We thought for a while there was a problem with the coax goin to that TV and when it was bent in such a way the reception was better. Not sure of the reason, but each TV is different in the reception of the new digital signals. Maybe watch that channel on the other TV's, or try to move the ant. cable around some?
Nov 25, 2009 | Sanyo DP32746 32 in. LCD Television
No sound when watching freeview on Samsung 32" LCD TV
I`ve got the same problem, sound with analog but not digital?
Dec 12, 2007 | Televison & Video
Philips model 50p8341a projection
color is off. Faces are orange sometimes, all orange, or red? Tried the remote to fix however did not work.
Nov 22, 2007 | Philips 60P8341 60" Rear Projection...
Turn tv on, and it scrolls through the channels
Had the same problem, channels would not stop scrolling.
It was as though someone had there finger on the channel up button.
Disconnected the sixth wire, starting with the black wire on the wiring harness for the front buttons, on/off, ch. up/down, vol. up/down, etc.
It works fine, no more unwanted channel surfing!!
Aug 29, 2007 | GE 32GT740 32" TV
Intermittent snowy pictures under Channel 51
Probably needs a new tuner or something associated with the tuner.
May 31, 2007 | RCA F36673ET 36" TV
Polaroid FLM-2011 Television Logo
140 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
