Question about Garden
My chainsaw is not getting any fire - Garden
    Brigadier General:
  • 4,088 Answers
Remove the spark plug and check for snappy, blue spark. If nothing, try a new plug. If still nothing, remove the left side case to expose the flywheel and ignition module. Remove the wire that goes to the stop switch from the module and try for spark again. If still nothing, it's new module time. Use a thin business card to set the gap between the module and flywheel magnets. If the gap was excessive with the old module, resetting it may bring back spark. Hope this helps!
Posted on May 15, 2010
What could cause chainsaw not to start. It's not getting fire to the plug
If there is no spark it could be an HT wire or the magneto or the magneto grounding switch.
Oct 14, 2014 | Poulan Garden
Its a poland 295 pro chainsaw still won't start
this problem could be due too a number of things first check to see if you have fire by pulling the spark plug then putting the wire back on it and pull the cord to see if it has fire i would not hold in hand unless you want a jump start for the day..If you have fire then check to see if you are getting fuel by adding a little fuel direct to carb not to much or you will flood it then see if it starts..If so ur lines may be stopped up...really them are the two main things to start the chainsaw fire and fuel..
Aug 10, 2014 | Garden
Poulan chainsaw not getting any fire?
check to see if your magneto is rusty if so clean with fine grit paper if still does'nt fire may be time to replace the magneto
Aug 08, 2014 | Poulan 16" 38cc Gas Chain Saw P3816
Ozito chainsaw petrol 14 inch bar model
Hi Ed, I had this same problem with my chainsaw when it was new. Once you get it to fire with the choke out push the choke back in but don't pull the trigger. Then try pull starting again and let it run for a few moments to warm up. It should run fine then.
Jan 18, 2014 | Garden
Chainsaw is getting gas getting spark carb is tight on head everything seems good just can't get it to fire.
Need to take your Carb apart and check the needle valve and screen. If the needle has a red tip, it needs a new one. check the Diaphram to see if it is stiff. If so replace also. Your saw will start right up.
Feb 10, 2013 | Garden
Remington SL4 chainsaw gets fuel but does not fire
She has points and most likely a condenser.
Chain Saw Collectors Corner
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/7c5ef158cb0d092988256d35001fa737?OpenDocument
I'd try that site for any help or parts for this Grand Old Lady.
I did a search for "Remington SL4" and found quite a few threads here:
ArboristSite.com Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
Please be kind to her. HTH
Lou
Oct 25, 2009 | Remington Garden
My gas poulan chainsaw model# pp3816av wont crank or get fire at the sparkplug and leak oil in case bad from the bar
the firing part try new sparkplug [plug must be grounded] still not firring disconnect one wire from on off switch purviservin@gmail.com
Jul 10, 2009 | Garden
Wont start with new plug. I can smell gas, but none on plug
Check the start stop switch, sometimes they can get dirty causing the saw not to get spark. Also maybe check Your air cleaner. if it's clogged it may be flooding itself out?
Jan 26, 2009 | Makita DCS6401 20 20",64cc Chainsaw 2...
0340 AV stihl chainsaw won't fire
Spray a little starter fluid down the carburator . It is starts then is is a fuel problem. Most likely a gummed up carburator. Remove and clean .
Jan 24, 2009 | Garden
I have a stihl chainsaw that won't fire
DID YOU REMOVE THE PLUG AND CHECK THE SPARK AT THE GAP? IF YOU HAVE FIRE THERE THEN THE PROBLEM MUST BE A FUEL PROBLEM. ARE YOU USING A FRESH GAS MIXTURE? YOU CAN PUT A FEW DROPS OF MIXED GAS IN CYLINDER THEN RE-INSTALL PLUG TO SEE IF IT FIRES, IF IT DOES THEN YOUR NOT GETTING GAS FROM THE CARB.POSSIBLE STUCK DIAPHRAGM. GOOD LUCK!!!
Jan 24, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Garden Logo
122 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
