Question about Health & Beauty
InvaMed Sovereign Mobility Scooter Model S888NR battery charger red light flashing to indicate fault. I have a multimeter and want to know how to test the charger. I need a wiring diagram and to identify the pin outs in the output connector.
  • 177 Answers
Hi. Its easy to identify the pins out. Put the probes into the socket on the scooter to read the polarity. the two terminals on opposite sides will be the positive and negative battery supply. The pin to one side is to disable the scooter when the charger is connected. This terminal is normally connected to negative when the charger socket is in place.
Most faults like this are caused by a broken wire in the charger plug orv by a faulty connection in the scooter. Sometimes the charger socket is faulty, check for heat damage or melted plastic.
Check the battery connectors. Good luck. Neil.
Posted on May 29, 2010
Why isn't my scooter charging when it's plugged in?
Your batteries may be too low for the charger to recognize they are there. Check each individual battery with a multimeter.
Disconnect batteries so you can check each individual battery. If you are unsure about doing this yourself, many battery places and medical equipment companies will check them for you.
Sep 04, 2014 | Merits Pioneer 9 Heavy Duty Scooter
My victory 4 mobilty wont charge the green light is very faint/the charger was tested working.so why wont my scooter charge
make sure battery cables are secure at battery terminals and clean.how old are the batteries.If the batteries run down fast they are no good.a good way to test them is put scooter against some thing solid and go forward.If the battery indicator drops to o the batteries are no good.It takes about 10 hours to charge the batteries
Mar 15, 2013 | Pride New Mobility Victory XL 4 Wheel...
Gogo elitescooter lights indicate battery fully charged but scooter will not go
Make sure the free-wheel lever is engaged and the charger is unplugged from the scooter before you try to turn the scooter on. If the battery gauge goes up when you turn the scooter on and there are no beeping sounds you should be good to go.If the battery gauge drops to the red when you try to accelerate slowly, your batteries are shot. (Typical replacement in 24-48 months).If there is any beeping when the key is first turned on then there is a problem and the number of beeps indicates the problem found by the computer during the POST. [Power On Self Test]
Dec 26, 2011 | Electric Mobility Mobility Electric Power...
Raggta 6 scooter not been used for 12 month,red light on charger flashing all time
A flashing red light orLED on most mobility scooter chargers means the Batteries have a defect as mostchargers also test the condition of the batteries. This has happen becausemobility scooters batteries loose charge when not in use, and need a maintenancecharge at least once a month (best once a week). If this is not done batterieswill fail! Get the batteries load tested to confirm that they are faulty,
Oct 26, 2011 | Health & Beauty
Does anyone have a link for the battery charger for a Scooter Store Jet 3 mobility scooter that defines the different light meanings. The scooter is 6 years old but before I purchase new batteries ($112.00...
saying to refer to the manual provided with the charger for a complete indication of these indicators do you happen to have a make or a model number on the charger or the manual? if you dont have the charger manual you may want to try calling this number its the scooter store and they can send you one for your charger and also answer any questions that you have Thanks again
Rick
Call us toll-free at
1-800-391-7237
Dec 19, 2010 | Jet 3 Ultra Power Chair
My mobility scooter batteries are put on charge but the charger green light to indicate that they are chaged no longer lights up
hi, now that could be one of three problems,
1. first check the charger ,is it possible to try the charger on another scooter ?
2. The batteries will no longer accept a charge ,this creates a fault condition with the charger. (try these batteries on another scooter if possible).
3. the actual charger plug in, you need to check the pins here , just the outside ones with a electrical meter, no voltage implies a bad connection to the batteries.
Regards
GeWiz
Please rate this reply.
Apr 22, 2010 | RTO Mobil Line Mobility Scooter Chair...
Scooter batteries will not charge. Green light on charger comes on briefly and fan tarts momentarily. Does green/yellow flash mean disconnection as indicated on the charger?
ok, this could be a dodgy connection with the batteries or the charger is at fault ?
1. try another charger
2. check the batteries if possible on another scooter.
3. check the connection on the battery and the charge socket connector.
Regards
GeWiz.
Oct 01, 2009 | Shoprider Health & Beauty
Health & Beauty Logo
457 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
