Turns out to be the = key. I just double-checked it and it's true.
Do a calculation like 10 divided by 2. Every time you enter a number and then hit the equal key, it will be divided by 2.
You can download the manual from the manufacturer's web site at
http://www.usa.canon.com/cusa/support/office/calculators/desktop_printing/p170_dh#BrochuresAndManuals
You can download the manual from the manufacturer's web site at http://www.usa.canon.com/cusa/support/office/calculators/desktop_printing/p170_dh#BrochuresAndManuals
1. Press the calendar/clock button twice
2. Press and hold the Clock/Date Set (or Time Set) button for three seconds.
3. Use the numeric keys to enter the time -- four digits (i.e., 0730)
4. Press the AM/PM button to select
5. Press the Clock/Date Set (or Time Set) button
6. Press the C/CE button to return to calculation mode
Look for the key with the cal/clock pic on it. Use to switch between calendar or clock mode. It is next to the feed key.
(12/24) Key used to switch between 12 or 24 hour at clock mode.
(Time Set) Key used to set the date and time in calendar & clock mode.
(AM/PM) Key used to switch between AM or PM at clock mode time setting.
(Format) Key used to select date format between "YYYY/MM/DD",
"DD/MM/YYYY" or "MM/DD/YYYY" at calendar mode.
Hope this helps, play with it I figured it out with instruction sheet.
for calandar
turn on.
press clock calandar button, top row second from left.
press time set button, second row from left, 3rd button from top, (has time set printed diretly above)
enter numbers, say 03 05 2009
press time set button 3 seconds
press CE/E, red key at bottom left corner.
turn on
press clock calandar button once, date will show
press clock calandar button 2nd time, clock will show
press time set once
enter time
press am/pm button (below time set)
press time set for 3 seconds
press CE/E red button to return to calculation mode
To set the tax rate, slide the "GT" switch to RATE. Enter the tax rate (i.e., 4.5 for 4 1/2 %). The display should show 4.5 %. Slide the "GT" switch to OFF.
